Question about Homelite Mighty Lite Lawn Trimmer
Every time I put a new spring in where the spool is and then hit it for more string to come out, the string flies away...what am I doing wrong when i put the springs in?
5 Suggested Answers
  • 130 Answers
SOURCE: string wont advance from spool
sometimes thows automatically spool go bad
afterwhile.get a new one
Posted on Jul 21, 2009
woobie dog
  • 1273 Answers
SOURCE: my homelite trimmer string keeps getting stuck
It's sticking pretty good. Try what I do: Pull the head off and clean it out pretty good. Also clean where the spool attaches to the trimmer. Before you reassemble it, give it a shot of powdered graphite (I get mine at the hardware store. It's for locks). Reassemble the spool onto the trimmer. Bump it on the ground several times to distribute the graphite within the head. Now, press the head in and pull on the trimmer line. It should dispense a little line and stop, just like when the machine is in operation. If it works, you're done! If it doesn't work, you will need to replace the spool. They are available at the major hardware stores. Even if you have to replace the spool, the graphite trick is a good one. It'll keep the head dispensing line smoothly. I add the graphite probably every 7th or 8th time I rewind the spool.
Best regards, --W/D--
Posted on Aug 09, 2009
  • 150 Answers
SOURCE: Featherlite/Mightylite 26ss pull cord will not
They don't spin with the engine, however pinning them together isn't your fix. The spring has to be fixed at both ends, sounds like one end or the other is comming out of its keeper. Check if the ends are broken
Posted on Oct 01, 2010
#1 Taper
  • 1040 Answers
SOURCE: I have a Homelite Trimlite model UT20706 trimmer.
Here is a link to one of my Tips: www.fixya.com/support/r6270682-trimmer_weed_eater_string_replacement
If you need more help, let me know.
Good Luck!
Jim
Posted on Oct 04, 2010
How do u put on replacement spool???
This sounds like a trimmer question and was categorized wrong, if so most rimmers simply unscrew @ the bottom of the head and then you can access the spool dolly @ which time you wind the string in the direction of the arrow. Make sure to follow manufacturers recommendation on thread size. Also make sure you replace the spring as you took it off
Jul 12, 2011 | Garden
I just returned my new Poulan Pro Line Trimmer b/c the spool and shaft overheated to the point the spool melted away from the shaft. What am I doing wrong?
I don't think you are doing anything wrong unless this is like your third time returning it, probably just a lemon your new one should work fine Poulan is a good name.
Jul 17, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Refill line on spool of toro electric model 910
Onve you remove the cover the spool should pull straight out. Be careful, there's a spring under the spool that can fly out and get lost. You need that spring to re-assemble.
Apr 11, 2010 | Toro& Electric String Trimmer
Need info on putting line on troy bilt 4-cycle string trimmer. Need to know how to get spool off trimmer to replace trimming string on the spool.
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Mar 27, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
How do you Replace string on the trimmer head spool
Take the spool off and turn it up side down take out the centre and wind the left side 6 times to the left and the right side 6 turns to the right then put the ends through the holes and refit to stud and screw on butter fly nut...
Dont try winding them both the same way as when you try to get more out 1 side will come out and the other will go inside so you will be back were you started
Sep 27, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Pull string for Weed Eater Featherlite Plus came out
If you have the starter spool out (the one the rope goes in)...Here is what to do. Take the starter spool and change the rope out putting it back exactly as it was. Leave the rope hanging. Hold the spool and set it down on the rewind spring. Turn the spool on the rewind spring until you feel it is tight enough. While turning, hold the rope in the little slot in the spool so it can go around without hanging up. Once it is tight, get the rope in line with the spool opening and SLOWLY let the rope rewind. Put on the handle and put the unit back together.Good luck...Lee
Sep 06, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My homelite trimmer string keeps getting stuck and when i tap it to release more string it doesn't the spring in it doesn't spring at all. I constantly have to stop take it apart pull enough string to edge...
Aug 09, 2009 | Homelite Garden
B & D trimmer feeding too much line
Do you remember putting the spring back in when you filled it with new line. You mite check to see that it is in there.
Good luck
Aug 07, 2009 | Black & Decker 14" Grass Hog Xp...
Threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
Jun 19, 2009 | Black & Decker Garden
Homelite Mighty Lite Lawn Trimmer  Logo
140 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
