Question about Poulan Pro Chain Saw 46cc 20"
Poulan Pro 18 inch saw. Once the unit is warm it
Poulan Pro 18 inch saw. Once the unit is warm it is really difficult/impossible to start. It also does not idle well. Any suggestions on how to correct?
    Problem Solver:
  • 5 Answers
Start saw when cold and work it hard. if it stalls or quits remove spark plug and hook the plug wire to the plug and ground to the cyl head have switch on and pull the start rop briskly a few times or use a test plug. if there is no spark disconnect ign switch from from the ign wires and pull rope a few more times.spark?= replace ign switch,no spark until engine is cool,replace coil.
Posted on Sep 24, 2009
Testimonial: "That was great! It was the coil. "
Can I put a 18" bar on my Poulan 35 CC, If not why.
yes you can put an 18 inch bar on this saw. you could even go with a 20 or 24 inch bar as long as it will fit the saw. I wouldn't go much bigger though because it really doesn't have enough power to handle a much bigger bar. And, getting into the dirt makes the saw chain really dull really quickly. Dig around those roots if you don't want to be stuck sharpening your chain every 10 seconds. Take it to your local saw shop and they can fix you right up! Hope this helps...
Jun 26, 2013 | Poulan Pro PP3516AVX 16" 35CC Gas Chain...
I have a Poulan 2000 chainsaw that I tried to adjust the carberator after using it one afternoon. Then it wouldn't start at all. How do I set the fuel and air "set screws" properly.
Start with "H" and "L" needle valves 1.5 turns CCW from lightly seated. Then tune for performance like this.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. Good Luck. HTH
Lou
Feb 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Carb adjustment for a Poulan Wild thing 2375
Start at 1.5 CCW from lightly seated then tune for performance like this:
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Feb 19, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
18"poulan chainsaw
Start at 1.5 CCW form lightly seated then tune for performance like this:
I think your starting procedure may be the cause of flooding. Flooded is the #1 cause of hard starts in 2-cycle engines. Read carefully the recommended start in your manual. most miss the second note. It should be similar to this (read 3, read it again):
Warm start in the manual says 1/2 choke BS. Close choke, (sets fast idle) open choke, pull rope.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts (usually first pull).
If you still have trouble reply as you did before. I will get back to you. HTH
Lou
Feb 18, 2010 | Poulan Garden
Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Feb 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Adjust carbureton
Initial starting point 1.5 CCW from lightly seated.
There are 2 wav (sound - idle & full – not highlighted) files that I find most helpful, I think you will too. HTH
Lou
Dec 16, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
508 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
