Question about Mitsubishi DD-8020 DVD Player
The door wont open or close
The display indicates "Opening" however the door will not open or close.
0 characters
1 Points
JVC DR-MV80B display says hello then shuts itself off.
On electric board you need to change the STR,and work fine.....
Sep 09, 2012 | JVC DR-MV80B DVD Recorder / VCR Combo
The machine will not open the DVD Drive. When I push the eject button the display indicates "OPEN" but nothing happens. Is there a way to open the drive manually?
No,if u forced it,will damges the little motor that help it to open the dirve door.Unplug the unit,hold the unit in ur hand tight over head shake it a few times,this will help,what caught inside that stop the drive door from opening.Wait like about an hour later to replug it back in the unit,will be resetting itself back to the factory setting,will help help the unit too.
Dec 11, 2010 | Samsung DVD-V4600 DVD Player/VCR
The door of my dvd player will not open. It sound like it wants to, but nothing happens.
This sounds like a problem with the mechanism of your player,it is probably stuck.
What you should do is to open up the player and try to open the door with your hand by pulling it,check to see what is stopping it from opening and clear the object stopping the door from opening automatically
Please note that it might just require oiling the door wheel to make the door open and close automatically.
Aug 20, 2010 | Sanyo DVW-5000 DVD Player/VCR
The dvd is stuck mid way not opening or closing
Try unpluging unit, then plug back in and press open/eject.Also look for a tiny hole on front door used to insert paperclip end, push in this will open tray.
Sep 04, 2009 | Yamaha DV-C6280 DVD Player
Dvd drawer opens and closes continually
the inter relay swich on the door is molfushing,or the open and close butten is bad'', try closeing the door and at the same time that the door close's unplug the power and then plug it back in after a few seconds and see what happens it my stay closed and then you can play it,, and it my stop doing that ''if not you will have to take it in to a repare shop'''' my names is ''james ''' let me know if this works for you''' you can e-mail ' me back at '' .
Jan 30, 2009 | GoVideo VR3845 DVD Recorder/VCR
The Dvd's door keeps opening and closing
Did you drop the dvd player or bump it at all? if not there is a small object stuck in the tray housing(more than likely) also see if the tray is off kilter especially if it's closing then opening. It's really hard to tell w/out seeing it but that's probably what's wrong.
Aug 27, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Door opening and closing
leaf switch is defect. It tells if the door is closed or open. not very expensive, thing is to try to find it. usually two wires. good luck
May 23, 2008 | Apex Digital AD-1165
Keeps opening
may have a microswitch that signals that the door is closed that may be faulty. look for a switch that is actuated when the door closes.
Nov 06, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Tray confused
I have an LG DVD player and recorder model # RC7423W and i have a similar problem, when i open up the disk tray it displays open and the tray opens for 2 seconds only and then closes. when i press the open/close button to open it again it opens and never closes back with a "Disc Error" on display until i close it manually by pushing it back inside.
I cleaned it from dust many times and tried to reset it but no reset button. i just tried to unplug the wire and plug it back.
let me know if there is a way that i can reset the hardware or a solution to my problem. my system is around one year old
Oct 22, 2007 | LG DR787T DVD Recorder
Mitsubishi DD-8020 DVD Player Logo
47 people viewed this question
Top Mitsubishi DVD & Blu-Ray Players Experts
Yoav Shilon
Yoav Shilon
Are you a Mitsubishi DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
