Cartridge light will not stop blinking and the printer will not begin to print
  • 375 Answers
This can be a result for low cartridge ink. Also check what type of document size are you printing. Some sizes are not supported due to specific reason. Also check that the printer is supplied with all softwares it needs. Check manufacturer's website for software upgrades. You may need a cold reboot. Turn off and plug out printer and all sockets for couple of minutes. Also remember, have you printed many documents at a time. Refer to computer and see that how many print jobs are on line. If some how, the printer got jammed and you gave it more jobs, it may do this and show more than one work on line. And at last at the First priority, get a quick internal check for any paper jam. This error is usually caused when the printer is internally jammed by any substance or mainly paper.
Thank you Sir, Have a nice day.
Posted on Sep 23, 2009
HP920c cartridge light wont stop blinking, printer wont print
Please refer below for detailed troubleshooting of the specific condition:
PRINT CARTRIDGE light RESUME light POWER light Blinking Off On c00106873.jpg c00106862.jpg c00106865.jpg Problem
The printer top cover is open, or there may be something wrong with the print cartridge.
Solution
  1. Close the printer top cover.
  2. If the PRINT CARTRIDGE light continues to blink, continue with the following steps:
    1. Open the top cover. The print cartridge cradle will move and then stop.
    2. Locate the yellow arrow on the top of the print cartridge cradle. The yellow arrow points to a drawing of a cartridge that represents a symptom. Perform the task associated with that symptom.
    3. For a list of symptoms, refer to How to use the cartridge drawings under the top access door on a 900 series Deskjet .
May 12, 2010 | HP DeskJet 920c InkJet Printer
Tip
The green light is blinking constantly and the printer won't print
When the green lamp constantly blinking this mean one or both print head are defective.Here we can find which cartridge is defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
This printer can work with only one cartridge.If you don't use color printing just remove the color cartridge.
on Oct 26, 2009 | HP Deskjet 3845 InkJet Printer
Light is blinking but will not print
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
Nov 09, 2009 | HP Deskjet D1341 InkJet Printer
Not printing, on light flashing
Nov 08, 2009 | HP DeskJet 3650 InkJet Printer
Hp 5550 deskjet not printing
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
If this not help your printer has problem in carriage unit and need repair.
Nov 04, 2009 | HP DeskJet 5550 InkJet Printer
Green light blinks continuously, printer will not print. Has always worked well until now. Cartridges are in place, printer has paper, is connected to power and to computer. Is there a reset?
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.If this not help your printer need service.
Oct 29, 2009 | HP DeskJet 3650 InkJet Printer
Sep 29, 2009 | HP DeskJet 3650 InkJet Printer
Actually for a HP deskjet 990cxi
Alignment:
1. Turn on the HP DeskJet.
2. Disconnect the USB cable from the all-in-one.
3. Press the sequence of front panel buttons below to start the print cartridge alignment process.
The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
1. Press and hold Cancel .
2. While holding Cancel , press On .
3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
4. Press Cancel again.
5. Press Copies .
6. Press Paper Type .
7. Press Color Start Copy .
The alignment page will begin printing.
If the alignment page does not print, repeat the button-press sequence in this step.
4. When the alignment page has printed, place the page face down on the scanner glass and press Scan .
The alignment is complete when the On light stops blinking.
5. Reconnect the USB cable.
Jun 03, 2008 | HP DeskJet 940c InkJet Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
    1. Turn on the HP PSC 1200 or 1300 series product.
    3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
      5. Press Copies .
      7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
    4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
277 people viewed this question
k24674
jasbo
jasbo
