Question about Nokia N72 Cellular Phone
How can i delete shortcut in n72 nkia but retain the application that is where is the shortcut located
How can i delete mobile games???????
installed apps should be found on application manager, i'm afraid that those pre-installed aps couldn't be remove
Mar 06, 2012 | Nokia N72 Cellular Phone
My shortcuts on my desktop do not work it states Application failure
the application you are trying to use is either corrupt or uninstalled, delete the old shortcut, unsinstall and reinstall the application and create a new shortcut on your desktop
Dont forget to say thanks!
Aug 11, 2010 | Dell Computers & Internet
When i click on the Google Chrome desktop icon Chrome WONT start. Instead i get this message: ''The item 'chrome.exe' that this shortcut refers to has been changed or moved, so this shortcut will no longer...
You might want to try restoring your system (using "System Restore") to a day when you remember the application running correctly. If you cannot do this than yes you will have to uninstall/ reinstall the application. Thanks, Dana
Feb 14, 2010 | Google Chrome
Iam loss my nokia security code and i will how to flash the mobile,please give me the code
  • Soft Reset (*#7780#): This is a normal reset. It will load the original settings from the phone's ROM. However, it will retain the user's own data. Like images, music, installed applications etc.
  • Hard Reset (*#7370#): This method completely reformats the C: drive (Phone Memory). All the user information will be deleted. Like images, music files, installed applications etc. Hence, the phone is set to the default factory settings.
On performing any of above methods of formatting the phone, device will ask you for a security/lock code. Default code is 12345.
Aug 06, 2009 | Nokia N72 Cellular Phone
I have a problem with my Nokia N72 cell phone it is not displaying anything just a white colour is displaying"
nokia n72 has a slow operating system which gets even slower if the battery is low and thw problems are doubled if the memory is near full. Sometimes unsupported applications hang on it which can only be stopped by removing the battery and restarting the phone.Restarting may take a lot of time but have patience and once the phone restarts delete the application which caused the hanging. An advice is to keep the memory card half empty.
Mar 20, 2009 | Nokia N72 Cellular Phone
Lock Nokia N72 phone
first u got a complain in against lost ur handset and ur sim . then next u r register to nokia site and complain stolen my handset to nokia . u have also mail the scan copy of ur mobile paper . nkia block ur phone imei.
Mar 13, 2009 | Nokia N72 Cellular Phone
N81 Format
when formating your phone, the default settings, pictures and other application will be restored, but other application like ultra mp3, or cam coder surely it will be deleted unless it is installed on your memory card cause the only thing that will be formatted is your phone memory,
Jan 01, 2009 | Nokia N72 Cellular Phone
I want to reinstall my symbian os in my nokia n72
http://wiki.forum.nokia.com/index.php/How_to_format_an_S60_device
OR
Switch Off the device.
* Press and Hold down the keys Green/Talk + 3 + *.
* Switch On the device.
* If everything goes well then you will see "Formatting" screen.
The link above will explain how to restore the phone to its original condition. This effectively reinstalls S60. It also wipes out everything else on the phone so be sure to use Noia PC Suite to back up what you need to keep and to restore it after the reinstall of S60.
Nov 26, 2008 | Nokia N72 Cellular Phone
Faulty nokia n72 phone
  • Nov 19, 2008 | Nokia N72 Cellular Phone
    Old shortcuts
    1.click on start then program then accessories then system tools
    then run disk cleanup
    2. either find the path of the shortcut and delete them
    Mar 04, 2008 | Toshiba Satellite L25-S119 Notebook
    Nokia N72 Cellular Phone Logo
    67 people viewed this question
    Top Nokia Cell Phones Experts
    270rexton
    270rexton
