Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
The Screen is giving me three images
My Samsung is creating each image three times one right behind the other.
  • 4,402 Answers
Convergance ic bad.
· Samsung parts for convergance problem
Posted on Dec 18, 2007
Samsung monitor 204b screen image is split in to two parts; the upper part OK but lower part is gibberish, ghosty?
Interference. Separate the wiring so it doesn't touch. Touching wires create cross-talk of signals and keeps from running normal.
Feb 11, 2014 | Samsung Computers & Internet
Wide screen stretches all my photos
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.
Dec 09, 2011 | Samsung Computers & Internet
I have a toshiba tp50h50 rear projection tv and their is a blue shadow behind the words and makes the words a little blurry
Sounds like you need to do a color convergence. If you still have the owner's manual, it will give great detail on how to do this. The convergence menu is accessed from the video menu on the tv.
The tv has three color picture tubes, red, blue and green. The convergence alignment adjust each tube so that color from each tube overlaps each over to create a white image on the screen. Most tv's only allow you to adjust the blue and red colors.
Convergence should be performed each time the tv is moved and at least once annually.
May 16, 2011 | Televison & Video
Samsung syncmaster 914v monitor problem. right side of display is darker image. can see dots like a newspaper print or looking through a screen. when display is black it almost appears like an image is...
This is likely the LCD panel itself - you are describing a left/right image error that can be only created by the left/right division by the LCD driver wrapped around the outside of the LCD panel.
If your monitor uses a separate circuit board to drive the LCD, it could be this driver board.
Either way, it will require an LCD panel - $$$
Mar 29, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Samsung hdtv HLP5085wx no image. Smelled something burning and sparking, turned off the tv. Tried turning it back on = have sound, NO image!
OMG! Dude, your screen is just plain fried. You don't need a new screen though, You just need a new bulb for it. See, behind the screen is a light bulb (unless your T.V. is plasma screen), sometimes two or three, and that burning smell was the bulb blowing (like when you need to replace a light bulb in a lamp or something). I don't know where you can find a new bulb, but once you replace it everything should be fine.
Oct 05, 2008 | Televison & Video
Copy counter in the Workcenter 45
  1. Press the [Machine Status] button on the Control Panel (the bottom button of the three to the right of the display).
  2. Select the [Machine Information] tab on the Touch Screen.
  3. Select the [Billing Counters] button. The following counters will be displayed, depending on machine configuration:
    NOTE: C13 (Total Marked images) will in general be greater than C1 + C2, or C4 + C5. C13 is incremented whenever an image is created, and will include counts of internal test patterns and reports. The other counters are not incremented when these system images are created.
Jun 04, 2008 | Office Equipment & Supplies
Blurred images at start on samsung monitor
This is CRT Base Problem Simply Replace it
Thank You
Mar 09, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Image Retention
burn in is not supposed to occur on an lcd tv, however I have an lcd from Proview that leaves images on the polymer layer the white horizontal address bar is the most prominent. if I leave the monitor off for about 3 days the images disappear, this may or may not help you, if Samsung has created a ticket on this issue you may well receive a prepaid shipping label to return the tv for repair.
Jan 10, 2008 | Samsung LN-S4051D 40 in. LCD Television
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
53 people viewed this question
Jerry Greenberg
Jerry Greenberg
