Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
Deleting files but doesn't reflect more free space
    Guru:
  • 597 Answers
This explains a lot of troubles with memory sticks.
file system on them just like your hard drive does. Most of these drives are small (<= 32 GB) so they use FAT16 as the file system type. FAT16 is an older file system and writes to the disk are simply done on demand. If the power to the machine is cut or the drive is simply yanked out during a write, this will result in incomplete data and possibly a corrupted file system on the drive. The "Safely Remove Hardware" bit calls for all programs accessing the drive to complete whatever reads/writes they need to as the drive will be removed. When all I/O is complete, the OS removes the drive from its list of usable drives and then pops up the bubble telling you it's safe to remove it.
If you formatted your memory card/USB stick yourself and put a journaled file system like NTFS, ext3, XFS, ZFS, HFS+ or ReiserFS, then the removal is different. All writes to the drive are first written to a journal, which is a temporary space on the drive. Once the data is written to the journal, then the data in the journal is written to its final location on the drive, overwriting the original data. Yanking out the drive will cause the following things to happen:
1. Yanking the drive out before the data has been completely written to the journal causes the original data on the drive to remain safe. The changed version of your file that was being written to the journal is lost as the FS sees that there is an incomplete write to the journal and flushes the journal the next time the drive is accessed.
2. Yanking the drive out after the data is written to the journal but before it can be completely written to the file system results in the partially-modified file in the file system being replaced with the good copy on the journal the next time the device is accessed. The user would never know that the final write never completed.
3. Yanking the drive out before any writes to the journal occur or after the data from the journal was successfully copied to the file system cause no issues as the drive is idle.
Safely removing a disk with a journaled file system causes the same actions as with the non-journaled file system but will also cause the disk to make sure that all of the journaled data has been written to disk successfully. Journaled file systems are more modern and much more reliable than non-journaled file systems. They still should be removed safely, but the consequences for not doing so are basically that it takes a longer time to access the disk upon the next access (due to journal-file comparison and flushes.)
The reason that journaled file systems do not commonly appear on UBS sticks or camera cards is because of Microsoft. Most people run Windows computers and Windows computers can only recognize FAT16/FAT32 and NTFS file systems out of the box. ext3 support can be easily added via a driver, but the other file systems require some external program to access (ReiserFS) or are completely unreadable in Windows (XFS, ZFS, possibly HFS+ as well.) NTFS isn't used on removable devices because it is covered by Microsoft patents while the FAT file systems are direct descendants of the original DOS file systems and are in the public domain. Device makers would have to pay MS a royalty fee for every device shipped if it was pre-formatted with NTFS. So the device makers have a few options:
1. Ship the drive with FAT formatting for free even though it's sub-optimal.
2. Ship the drive with NTFS formatting and pay MS $0.25 (IIRC) per unit shipped.
3. Ship the drive unformatted for free and require the user to format it on their computer, where they can format NTFS for free. This axes out-of-the-box working ability.
4. Ship the drive with ext3 for free and require that the users download the Windows ext3 IFS driver for free. This also axes out-of-the-box working ability and renders the device unusable on computers where the user doesn't have admin access to install the ext3 driver (work computers, public terminals.)
Most manufacturers want easy-to-use and cheap rather than good so they ship FAT-formatted drives. I leave mine formatted as FAT as cameras won't support anything but FAT16 and since I don't run Windows, I can r/w to FAT but basically only read from NTFS (write support is VERY limited.) I'd simply format my USB stick ext3 and be done with it, but I use my drive a lot on university computers and I highly doubt that the techs would install the ext3 drivers for me.
Posted on Oct 01, 2009
Seagate Freeagent external Hard drive won't increase free space when files are deleted?
How are you deleting the files? If you're simply moving them to the trashcan/recycle bin then they're still taking space on your drive. Try emptying the trashcan/recycle bin.
Mar 21, 2013 | Seagate FreeAgent Computers & Internet
Is it ok to defragment my 2T goflex portable hard drive?
Yes. Defragmenting simply takes the pieces of empty space on the drive and groups them together. When you delete data from a drive or it is deleted as part of a program's function (such as deleting files only needed during installation) it leaves a blank space, but files are lined up on the drive. So if the files are like so:
2GB File ' 3 GB File ' 5.5 GB Free Space ' 1.5 GB File ' 4 GB Free Space
Then defragmenting would try to rearrange the files like so:
2 GB File ' 3 GB File ' 1.5 GB File ' 9.5 GB Free Space
So, in short, yes, it's okay to defragment your drive.
Mar 08, 2013 | Seagate FreeAgent GoFlex Desk Desktop...
No disk space to uninstall programs
Uninstalling requires a bit of space free. Try deleting a new files to free up some space which will allow for uninstalling!
Nov 04, 2012 | Sony VAIO PCV-RZ49 (T99861234) PC Desktop
Hello! when i press the shutter button, it makes 3 beeps and doesnt take any video or photo even if there's enough place. what can i do?
I found out that my GoPro was saving data on the card that was not in any file. If you have lost data, when the camera runs for a while and the PIC file shows zero K, then when you delete the file, the random data stays. I got the first few minutes of a couple of sessions, then the camera shut down. Put your card in a card reader on the computer and right-click and check the card for usable space. You might find that it's full of random data not assigned to any file. Then you have to reformat the card to clear it. Just deleting any PIC files so it says 'no files found' doesn't mean the card is cleared.
If the card has space, you have some other problem, sorry. But I regularly reformat the cards just to make sure they are clear after deleting files. The GoPro doesn't care, it just thinks it's a new card and inserts it's file routine.
Aug 07, 2011 | GoPro Digital Hero 3 Digital Camera
Currently my 500 GB WD External Drive has 353GB as free space. But when I try and add a 6GB file I get the following message "Error Copying File or Folder Cannot copy filename: There is not enough free...
How many directory deep is the file going that you are trying to save? I believe the maximum NTFS file (location + name) of file length can not exceed 256 characters total.
Example: C:\user\documents\file.exe is OK
But: C:\user\documents\folder\folder\folder\folder\folder\this folder name 230 charicters long\file.exe BAD
Feb 05, 2010 | Western Digital My Book Essential Edition...
My sansa clip has maxed out space and won't turn on
Sandisk has an Answers support site for the Sandisk players.
Searching for answers on the item space, links to next page:
http://kb.sandisk.com/app/answers/list/kw/space/r_id/101834/search
The first answer on not enough space for musicDB will give 2 options for deleting files, see next page:
http://kb.sandisk.com/app/answers/detail/a_id/848
Option 1 for normally erasing files.
Deleting selected files:
http://kb.sandisk.com/app/answers/detail/a_id/41
Method 1: deleting files on the player itself .
Method 2: deleting files when connected to a computer
when using method 2, switching USB mode from MTP to MSC or vice versa may be needed to see the files in the folders.
Information about the problem "hidden files", see:
http://kb.sandisk.com/app/answers/detail/a_id/447
How to change the USB mode of the player, see:
http://kb.sandisk.com/app/answers/detail/a_id/207
Option 2, erasing all files on purpose or when memory is corrupted .
Formatting the device, deleting all files:
http://kb.sandisk.com/app/answers/detail/a_id/107
This help page shows how to perform a format of the player using
disk management. The player has to be in MSC mode when performing
this action.
How to switch to MSC mode is mentioned before, see link:
Manual for the Sansa Clip in pdf format:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
When more help is needed, just post a comment.
Nov 20, 2009 | SanDisk Sansa e250 MP3 Player
Deleting files does not free up disk space
Note that "deleted" items move from their location into the "Recycle Bin".
So, "empty" the Recycle Bin, in order to reclaim the space.
Or, when deleting:
1. click ONCE to select a file/folder to be deleted
2. hold the SHIFT key down
3. click the DELETE key
4. release the SHIFT key
This will "permanently" delete the file/folder, immediately freeing-up the disk-space.
Oct 27, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Deleting files is not creating free space on my coby mp705-8g mp3
Ok First, Open Your MP3 player
2) Go To Setup
3) Then Go to system
4)Then Usb Mode
5) there will be auto or MSC
6) choose msc and then plug it in the files will be there.
Mar 11, 2009 | Coby MP-705 Digital Media Player
Error Message
If you want to check hard drive space, open my computer and select the details view. OR right click on the drive icon and pick 'properties'
Freeing up space can be tricky. Use the disk cleanup utility first.
Start/Run/Accessories/System Tools/Disk Cleanup. The only caution is "don't compress files!!!"
Then it's a matter of deleting old documents [I back mine up to CD before deleting.] pictures, videos, etc. You can also add space by adding a hard drive and moving big files, like videos, to it.
Aug 14, 2008 | Canon PowerShot A510 Digital Camera
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
311 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
