Question about E-Machines Computers & Internet
What can i salvage from my dead emachine? What do I need to remove before discarding? Where/ how do i dispose of it?
  • budgirlt Sep 23, 2009
    should i do anything else to protect any info? or is that all on the hard drive? Thanks again for your help and time
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 153 Answers
You should remove your hard drive, which you can use in another pc if you like. There is not much else that you should remove, unless you want an additonal cd or dvd rom drive. other than that, everything else you need will come with your new pc.
Your local city operations dept, or garbage department will have information on how to properly dispose of your pc, there may be a small recycling fee with this though.
Posted on Sep 23, 2009
Testimonial: "thank you so much!"
How do i change my battery
REMOTE CONTROL HANDSET: (sEE Figure 3)
NOTE: PLEASE REMOVE THE PROTECTIVE STICKER FROM
THE REMOTE CONTROL BATTERY BEFORE OPERATION.
This unit includes one lithium battery, CR2025/3V.
Remove battery before discarding the remote.
Battery Replacement
a) Locate the battery compartment on the back of the
remote control handset. Slide the battery cover out
with your thumb.
b) Remove old battery.
c) Place new battery into battery compartment.
d) Slide battery compartment into the remote control
handset.
NOTES:
• Remove the battery from the equipment when it is not
being used for an extended period of time.
• Remove the used battery promptly.
• Do not discard used batteries into household trash
containers. Contact your local government for disposal
or recycling practices in your area.
Jul 01, 2015 | Bionaire BT200RCU Tower Fan
How do I dispose of Carbon Monoxide Alarm & Fire Alarms?
If it's no longer working, just discard in trash. It doesn't contain any hazardous materials. If it's still working, then donate it.
Sep 23, 2014 | Kidde DC-Plug-In Carbon Monoxide Alarm...
drain coolant into a drain pan. discard at a disposal point (usually local auto parts store). remove top and bottom radiator hoses. If you have a transmission cooler remove bolts mounting it to the radiator. you will also probably have an electric fan shroud that will need removed. if removing an electric fan shroud be sure to remember this fan can start at any time and it is bests to have battery terminals disconnected. the rest is simply a matter of unbolting accessories and other obstructions the remove radiator. once you reverse the remove process and have every thing re connected be sure to bleed the cooling system very well air bubbles will cause overheating issues.
Jul 18, 2014 | 1996 Jeep Grand Cherokee
C7280 diagram hp parts
doesn't have that kind of memory that stores stuff when pwr is turned off.
Oct 19, 2013 | HP Photosmart C7280 Printer
I think I ground up a plastic bag in disposal....I have cleared out as best I can, turned the blades with a wrench, re set the button, but it won't move, just humming....does the unit need to be...
Don't keep running the disposal when it is humming or motor will burn up.
You might need a plumber, and/or might need to replace disposal.
1) If the disposal cutter disc turns freely, and motor will not start then disposal has gone bad.
2) If disposal cutter disc is still stuck, then you might be able to salvage by removing two nuts on p-trap below sink.
P-trap drops free.
Remove 2 bolts holding tailpiece to side of disposal so you have access to plastic bag from below the cutter disc.
Keep removing plastic bag and keep working the wrench from below. It should eventually give way.
Put wood broomstick down sink opening and wedge broomstick against sink opening to get cutter disc to rotate.
Spray WD40 into opening to help lubricate the struck parts.
3) I wrote ez disposal replacement steps that also cover tips for reassembling p-trap.
http://www1.fixya.com/support/r7929008-replace_garbage_disposal
Sep 22, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How open norelco reflexplus 6 model 6863xl to replace the battery
Hi rafael110807,
This Norelco Razor contains rechargeable Nickel-Cadmium batteries, which must be
disposed of properly.
Batteries should be removed only when the razor is to be discarded. Batteries should be recycled or disposed of properly. To recycle the batteries please call 800-8BATTERY (1-800-822-8837) for a location in your area. If you have additional questions or need further assistance, Consumer Care can be reached at 1-800-243-3050. You can also visit this product's Support Site @ http://ow.ly/6j5Ep for chat, FAQ's, manuals, and more. Hope this helps. If so, let me know by rating this solution.
Sep 01, 2011 | Norelco ReflexPlus 6863 XL Electric Shaver
Where do dispose of full toner waste bags?
It depends on where you live.
Do a Google search for " what's the best way to dispose of full toner waste bags?" And add your city,or state on the same line. It will return a list of places to recycle the toner.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Ricoh Aficio CL3500N Laser Printer
Emachin
Sometimes this problem happens when your CMOS battery already dead. Replace the CMOS battery and run F4 to setup the date and time. Save it and you back to business.
Mar 27, 2008 | Dell (E210882) Motherboard
Computers & Internet Logo
46 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
