Question about Tomtom GO 700 GPS Receiver
How do you connect the ribbon connecter clip for the screen on tomtom go720
  • 66 Answers
Had mine open just yesterday to see how difficult it would be to replace the battery, so I had the same experience reconnecting the ribbon. You first need to make sure that the little gray release tabs at either end of the connector are in the up position, then , where the ribbon is creased, you need to straighten it slightly. This will allow you to stand the screen up a bit straighter and make access to the connector easier. The end of the ribbon gets inserted on the top side of the little gray strip that you see running the width if the connector.with the ribbon inserted you then need to carefully push the little gray tabs back down into the locked position (flat with the top of the connector). Make sure the ribbon is straight and fully inserted, and don't forget to plug the speaker connector back in. try searching TomTom replacement battery on line and you should find excellent directions & photos on the entire procedure. Good luck.
Posted on Jan 30, 2010
Hi, i have just been given a tom tom 720 which isn't working. I suspect it has got a serious problem but would be grateful for any comments which you have about the problem.When turning on the tom tom it...
You could try gently inserting a straightened paper clip into the small round reset hole in the base of the Go720 and pressing/holding slightly on the reset button for c.6 secs. This should reset most basic problems.
Do you have the TomTom Home software that was supplied with the TomTom machines - if you open that on your PC and then attach your TomTom via the supplied cradle or USB lead it should provide a screen asking you if you want to connect to PC. If it boots straight past this you would normally reset it, as above, then restart and accept the question. This should then check the software on the device for updates etc.
Otherwise if no screen display it could just have been dropped and damaged, might be worth opening up to check if the backlight has been broken, though I'm not sure you can get spares (certainly not from TomTom). There is a firm at www.satnavrepairservice.com who will quote you for repairs that need parts.
HarrisonIT
Apr 06, 2011 | Tomtom GO 720 GPS Receiver
I have forgot my password on tomtom go720 how do
OK remove the Battery from inside, and look for a little "Hole" and push a ... say, a straightened Paper Clip and press it, hold for a second or so, & reassemble. You should be all good.
Feb 12, 2010 | Tomtom GO 720 GPS Receiver
CANT GET THE TOMTOM GO720 RIBBON CORD TO STAY
Hi the USB plug at the end gets loose inside and goes bad. Target sells a direct replacement for it.
If you can't find it in their electronics department look in the automotive section. I believe it cost around $17
Jan 03, 2010 | Tomtom GO 720 GPS Receiver
TomTom Go720 cannot boot up/frozen screen/no response. Need repair
Try resetting it. Use a pin or straightened paper clip to push the reset button thru the hole marked "Reset" on the bottom. hold the reset for 15 seconds. then push and hold the power button for 5 seconds to complete the reset. Good luck.
Oct 27, 2009 | Tomtom GO 720 GPS Receiver
Tomtom go720
most of ebay purchases are sold with maps from other devices and then played with alittle to get them running on your device, so when you update, say bye bye to your map, do not update if you buy from ebay, unless you buy the real map then your fine
Aug 13, 2008 | Tomtom GO 720 GPS Receiver
Downloading Free Maps for TomTom GO 720
I want dowloading free maps for tom tom go 720
Apr 02, 2008 | Tomtom GO 720 GPS Receiver
Tomtom GO 700 GPS Receiver Logo
213 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
