Question about Garden
How do you remove the electric clutch from a Husqvarna riding mower?
  • 389 Answers
Remove the primary belt and mowing deck to give yourself some room to work.
Locate the wires from the clutch and follow them toward the frame until you find the plug and unplug it.
Remove the bolt and washer from the center of the clutch going up into the engine crankshaft and slide it off the shaft. It is quite heavy so be careful when it comes free.
Posted on Sep 23, 2009
My Husqvarna LGT 2554 deck hung up on high spot mowing. Turned off deck & mower pushed by hand. Engaged deck,started to mow, wound to stop. Belts fine. Pull up on knob to engage, you get nothing.
The engine runs but the blades do not engage? Make sure the wire connecting the electric clutch is still plugged in. If all is connected and the belt is really fine, there is a problem with either the electric clutch or PTO switch.
May 21, 2015 | Husqvarna Garden
On a Husqvarna 2005 ELS 2448 riding mower, PTO switch burns up, and wont blow the fuse first? Why?
I used to see this on the Kawaski engine machines with an electric clutch, they put a diode between the two clutch wires so as so as to stop any electrical feed back throught the clutch, when the machine is running without the clutch engaged it can turn into a generator.
Oct 17, 2012 | Garden
Pto, electric clutch
check the wires they rub on sharp edges
Mar 23, 2012 | Husqvarna Garden
Is not working electric clutch for cth 1736 husqv. ride on repairable ?
Unplug clutch wiring from clutch and apply 12v directly to two small terminals in plug, polarity doesnt matter. This will test clutch. The clutch is not repairable.
Jan 31, 2012 | Husqvarna Garden
My 54" Poulan Pro riding mower dies when the
battery weak replace or charge, mower has electric clutch which pulls amps from battery
Jun 26, 2011 | Husqvarna 24HP 54" Yard Tractor ()
2007 Husqvarna Riding mower blade will not engage when switch pulled out. Fuse blows & mower dies! Help!
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Apr 25, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Remove blade clutch from a Husquavrna 4817iz zero turn more.
Remove the footrest. Apply pressure to the belt tensioner to loosen the belt, slip the belt off the pulley opposite the tensioner. Remove the belt from around the electric clutch. Unplug the electric clutch (2 pin connector With a socket wrench, remove the bolt in the end of the crankshaft which holds the electric clutch in place (you may need a piston stop or other device to keep the engine from turning in order to do this), then remove the clutch. Installation is the reverse of removal
Oct 25, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I would like to know the part number of the electric clutch on my Husqvarna YTH1700 mower (42" cutting deck).
went on the husqvarna website and couldn't find a yth with a 42 inch deck - found a yth1746, though and the part number is 532145028
Aug 20, 2009 | Husqvarna Garden
Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
Jul 31, 2009 | Husqvarna Garden
Garden Logo
445 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
