Question about Coffee Makers & Espresso Machines
I inherited my Mother's coffee pot. It has a metal insert with a handle which has a place on the bottom side that looks like a cord should attach. The metal insert has writing on the bottom: 120 VAC only 62IW corning ware P-80. Is it electric? Can it be used on a stovetop? . Is there a book for it? I would really like to use it but am afraid I will ruin it if i don't have the instructions.
    Scholar:
  • 176 Answers
Hi, go to eBay and look for corning ware parts.
Posted on Aug 11, 2010
What does the classic saucepan look like?
Saucepans are round pots with flat bottom used for cooking, heating and making sauces. It has varying size and depth with comfortable handle.
You can see the different Saucepans and pots at
GroomNStyle Top 5 Best Saucepan and Pot reviews 2015
Jan 14, 2013 | Home
My coffee maker wont turn on
Many coffee makers use neon bulbs to indicate that power is on. These do burn out after a while, but replacement is usually somewhat difficult. In this case, the coffee maker still works; you just don't have the immediate visual indication.
Many of the urn-type coffee pots have problems with the power cord breaking where it goes into the pot. To fix this, you need to remove the bottom, cut the cord where it is broken (on the outside of the pot), strip it back to match the part of the cord remaining inside the pot and crimp on new terminals of the same kind used on the original ends. The hardest part is squeezing the strain relief clamp where the cord enters the pot to remove it, and putting it back on. Study it carefully as it you remove it from the cord so you know how it works. To avoid a repeat of the same problem (and buying a new cord), be careful not twist the cord or bend it too tightly at the strain relief. NOTE: one of the wires in the power cord has a rib on the outer jacket. This is the neutral wire. Make sure it connects to the same place inside the pot as the original neutral.
Other failure points are at the power switch, or (rarely) the heater element. I've seen a programmable coffee maker with a burned-out relay (magnetic switch in a black plastic box on the circuit board). The clock and timer worked, but the heater wasn't getting any power. That part is about $5.
The easiest way to identify the problem is with an ohmmeter. Start by removing the bottom of the coffee maker (unplug it first!). Identify the heater terminals (the heater looks like a small version of the one in your oven and has either screw or slip-on terminals). Connect one of the ohmmeter test leads to each heater terminal to measure the heater resistance (typically 5 - 20 Ohms). If you have a basic (non-programmable) coffee maker, turn on the power switch and measure the resistance from each terminal to each prong on the plug. You should read either nearly zero ohms, or the heater resistance plus not more than a few tenths of an ohm. If you read open to one prong of the plug, you are on the track. Trace where the wire from that heater terminal goes. If it goes to the power switch, check the resistance of the power switch in the on position. If the reading is more than a couple of tenths of an ohm, the switch has dirty contacts, or it's broken or burned out. If you have a good connection from the heater to the power line side of the switch, but you get open from there to the hot side of the plug, the power cord is bad. Likewise, if you get an open reading from the other heater terminal to the neutral side of the plug, the cord is bad.
Programmable coffee makers have a similar troubleshooting procedure, except that you have to check for live AC voltage with the pot plugged in - this is not something to try if you aren't trained in the safe way to do this.
Sep 09, 2011 | Microwave Ovens
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
Need plastic handle on Rival Crockpot lid.
For what it's worth, when the handle on my mother-in-law's crockpot broke, I went to Home Depot and bought a cheap wooden drawer knob (about $1 as I recall). I put a plastic washer between the knob and the glass and another under the screw head from the bottom (to prevent cracking the lid), tightened the screw and good as new.
Feb 20, 2009 | Rival 38601 Smart Pot 6-Quart
Cuisinart COD 4000 coffeemaker
Use Safety. Unplug. If You want to Handy Try, Open Bottom by removing Screws. Find ac Power cord wires and in loop should be a METAL small Tiny Protection Temperature Thermal Device that is Probally open. Your Local appliance place can sell you this as You need to get right temperature. Can Plug in Replacement or Twist with wires for support. Switch could be Intermittent ( Open ) also and a Replacement should Snap into Place and Leads attached as original or a safe way. A Simple Meter ( Harbor Freight ) Digital Meter only $3 will work for testing.
Aug 16, 2008 | Cuisinart Coffeemakers
Revere Ware old fashioned coffee pot
1) Boil the water you’ll need in another pot.
2) Put 1 tablespoon of ground coffee (drip grind, not percolator grind) in the reduced diameter, perforated bottom of the brewing chamber.
3) Put the grind/water separator (the perforated, flat handled plate with cup markings on the handle) in the Brewing Chamber, over the coffee grounds.
3) Put the Brewing Chamber on top of the Holding Chamber.
4) Pour the appropriate number of cups boiling water into the brewing chamber; put the lid with the black knob on the brewing chamber.
5) Let the water drain through the coffee grinds (5-10 minutes).
6) Remove Brewing Chamber, clean out the coffee grounds, and replace the lid on the holding chamber.
7) Enjoy your coffee! Keep it warm on the stove at LOW heat setting.
for the most information on the Revere cookware lines, go to: http://mysite.verizon.net/vzeoywo4/theshineshop2/id1.html
Charlie
Jun 16, 2008 | Coffee Makers & Espresso Machines
Warming plate boils coffee.
Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
Feb 08, 2008 | Bunn VPR Coffee Maker
Coffee carafe band
has anyone purchased the Walgreen brand pot as a repleacement and has it worked?
Oct 29, 2007 | Haier HDC10LBS Stainless Steel 10-Cup...
Inherited coffee maker I have a Faberware ?138? Automatic Peculating Coffee Maker I inherited from my Grandparents. It's in great shape but I have no idea how old it is. It's a great little unit, but...
There realy not much of a manual for this type of coffee maker. put water in to water line, put coffee in the metal basket, put the lid on the metal basket, put lid on the coffee maker, set it on the stove until it starts peculating let do it for 10-min then stop.
Sep 06, 2006 | Faberware FCP412 Coffee Maker
Coffee Makers & Espresso Machines Logo
87 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
