Question about Brother IntelliFAX 1270E Plain Paper Fax
How to erase memory - Brother IntelliFAX 1270E Plain Paper Fax
    Problem Solver:
  • 5 Answers
RESET THE MACHINE.Press MENU # 2864 THEN TYPE 01.the m/c will reset.
Posted on Sep 26, 2009
After locking memory card, do I then unlock it to take pictures and will that then erase the memory card or can you tell me how to so
Locking the memory card prevents you from taking and adding photos to the memory card. It also prevents you from deleting photos from the memory card.
If you want to erase all the photos off the memory card. unlock the memory card, go to the camera's Menu and scroll through the settings ti Format the memory card, then format the memory card.
Apr 10, 2013 | Cameras
Tip
Cleaning PC Desktop Memory Stick Contacts
The best way to clean the contacts on computer memory sticks is to use an eraser.The contacts on memory sticks get tarnished after being exposed to the elements especially inside a computer where theirs a lot of air flow happening so cleaning them with a pencil eraser will restore the contacts to allow good contact between the stick and the memory slot.This also works for any electronic equipment that utilizes flat male/female connectors like in tvs,garage door openers.Make sure that only the eraser comes in contact with the connections and be careful that you do not hit any of the smd(surface mount devices)located on the board.If your not comfortable using a pencil eraser you can get the same results by using just an eraser itself.I would recommend that if your using a pencil eraser that it be a brand new pencil,do not use a pencil whose eraser has been worn down,due to the erasers metal holder which if not careful can scratch and/or damage the piece being cleaned.This also applies to Laptop memory.Thanks and Enjoy
on Feb 12, 2011 | Computers & Internet
Fax memory full
To gain extra memory, you can turn off Fax Storage OR Print fax messages in memory (See Setting Fax Storage, page 48.) OR Expand the machines memory.
Retrieve or Erase a Fax
Press 9 6
then to
Retrieve all faxes Press 2, then enter the number of remote fax machine and then press # #. After
the beep, hang up and wait.
Erase all fax messages Press 3. If the data stored in the memory has not been printed before, it will be printed first and then erased.
Setting Fax Storage
If you set Fax Storage to ON, you will be able to retrieve fax messages from another location, using Fax Forwarding or Remote Retrieval functions. The screen will indicate when you have a fax stored
in memory.
1 Press Menu, 2, 5, 2.
2 Press left arrow or right arrow to select ON (or OFF), and press Set when the screen displays your selection.
3 Press Stop/Exit.
If there are faxes in memory when you turn the Fax Storage OFF, the screen prompts you to erase any faxes in memory.
If you press 1, all fax data is erased and Fax Storage is turned OFF. If the fax data in memory has not been printed before, it will be printed first, and then erased. If you press 2, data is not erased, and Fax Storage remains ON.
Feb 07, 2012 | Brother FAX-8360P Plain Paper Laser
How do I erase the memory on a Workio 1820?
go to the menu of the machine, check memory option, then, you will see the option to erase or store memory. select erase or remove memory.
Feb 04, 2011 | Panasonic Workio DP-1820E Copier
I HAVE A SHARP UX-A450 FAX MACHINE AND WANT TO EMPTY THE FAX MEMORY.
MEMORY IS FULL / SEE MANUAL (alternating messages)
The memory is full. You may have too many messages recorded in the answering machine. To erase messages, see below. This may occur during fax reception if too much data is received before the pages can be printed out. If faxes have been received to memory because printing is not possible (an additional message will indicate the problem), resolve the problem so that printing can continue (see Substitute Reception to Memory on page 66). If you are attempting to transmit from memory, see If the memory becomes full on page 57. If you are copying, see If MEMORY IS FULL appears on page 67.
Erasing received messages:
It is important to erase received messages after you listen to them to ensure
that the memory does not become full.
? Erasing all messages: To erase all messages, press FUNCTION, DELETE, and then START/MEMORY.
? Erasing a single message: To erase a single message, press DELETE while the message is being played.
If the memory becomes full while the document is being scanned, MEMORY
IS FULL and SEE MANUAL will alternately appear in the display.
? Press START / MEMORY if you want to transmit the pages which have been stored up to that point in memory. The remaining pages will be ejected from the feeder. After transmission, the memory will be cleared and you can transmit the remaining pages. You will also need to transmit the page which was being scanned when the memory filled up.
? Press STOP if you want to cancel the entire transmission.
Nov 25, 2010 | Sharp Office Equipment & Supplies
How can I erase the memory to make space for new
1. Press Menu/Set, 8, 4.
2. Press Fax start
3. Press Stop/exit.
This will print all faxes held in memory, per the manufacturer's manual I found online. It worked. No more clogged memory.
Jan 22, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
I cant erase phone memory
Hi buddy,
If u want to erase all ur phone memory then resetting ur mobile settings is a good option.
1.Just go to the settings option.
2.select reset factory settings option.
3.then enter the security code 1234 if u have changed it then enter that one.
4.In few minutes ur phone memory will be erased but remember to take backup of ur phone memory data before resetting.
I hope this will help u.
Aug 04, 2009 | Nokia N95 Cellular Phone
Erasing the memory card;
All pictures in the internal memory and/or on the memory card can be erased at once. This is accomplished through either formatting or the "all-frame erase" function. I copied the following instructions from the advanced manual, which can be downloaded here: http://www.olympusamerica.com/files/d545zadvman.pdf. Adobe reader should open that file with no problem. If it doesn't, that's another issue altogether.
1. Enter playback mode by pressing the play button.
2. Press the OK MENU button.
3. Press the right arrow button (next to the lightning bolt) to access [MODE MENU]
4. Then, press the down arrow to access the [MEMORY(CARD)] tab.
5. Select the [ALL ERASE] function.
6. Select Yes and press OK MENU.
(You'll need to use the arrow buttons to navigate the menus. Please see pg 16 of the manual for instructions on how to do so.)
Note: when the memory card is in the camera, it will erase the pictures off the card. When the card is removed, the function above will erase the internal memory.
Apr 22, 2009 | Olympus D-545 Zoom Digital Camera
Pny memory stick
once it is erased of your pen drive it is erased for ever
(you dont want to format it it will erase your date)
hope this helps :-)
Aug 31, 2008 | Electronics - Others
How do you erase the memory card?
You can format in the camera. usually you go to the menu on your camera and select tools or utilities, select format.
Your memory card will be erased.
Jun 23, 2008 | Olympus FE-230 Digital Camera
Brother IntelliFAX 1270E Plain Paper Fax Logo
121 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
