Question about Samsung SGH-T619 Cellular Phone
Blue tooth will not activate
Each time I attempt to activate my cell phone Blue tooth mode, all I get is " Blue tooth activate error". Is ther a fix fir this problem?
Need help with activating sim card tried last nite didn't work
Hello, friend! I also meet this error about my cell phone, I get many help from this forum, and also bought many DIY repair tools from china supplier , and vipprogrammer help me fix this error. maybe you can try it.or contact ther WhatsApp:+ 8615986801289 website: http://www.vipprogrammer.com. They've solved my cell phone problem and I hope it will help you with your mobile phone trouble.They have professional repair tools.
Oct 17, 2017 | Cell Phones
My Bluetooth on my j700 wont turn on. help me to fix it
I'm sorry to tell you this, but the fact is that, most Samsung phones are having blue-tooth problems. Some times it might work and other times it might not work. Blue-tooth on most Samsung phones don't work at all and yet they claim to have blue-tooth.
I am saying this out of experience and you can ask other Samsung users confirm this.
I have come across a lot of Samsung phones with this problem, but the fault is from the maker (Samsung) of the phone.
So, you can adapt to the phone like that, or go for another product like Nokia that has an efficient blue-tooth,
Take care.
Sep 22, 2010 | Cell Phones
Dear sir my Samsung j700 Bluetooth is not active .its taking long time for opening the blue tooth but never open .and after long time is answer that your Bluetooth is already active but he was not active...
once do the hard reset on your phone.before doing that please take a backup of data.and also keep the bluetooth is temporary visibility mode
Sep 09, 2010 | Cell Phones
What do i have to install on my pc to be able to take off pictutes from my phone to the computer?
If you have blue tooth in your PC then use blue tooth to send the photos. First of all open blue tooth setttings to activate, there will be a request for a passkey. choose a common name to be entered in both as it is detected. Now confirm and the phone will be logged with the PC and viceversa. you can send and receive files now.
Aug 30, 2010 | Motorola Mobility RAZR2 v9 Cell Phone
Bluetooth not working in sony W580i phone
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
After attempting on this process, if doesn't work,that means thee blue tooth is corrupted and to restore bluetooth, you will to flash the phone. Flashing the phone will restore back blue tooth.
You can use this links to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Take care.
Jul 03, 2010 | Sony Ericsson w580i Cellular Phone
My phone doesnt connect to bluetooth it takes ages but doesnt do anything just says "activating" one time i left it all night and it just said activating in the morning
my phone doesn't connect to blue tooth it takes ages but doesnt do anything just says "activating" one time i left it all night and it just said activating in the morning
Feb 18, 2010 | Samsung J700 Cellular Phone
''device not found'' on motorola I465 when attempting
you have to turn on the discovery mode on the phone in the blue tooth settings....usually will last for like a minute or so then hit the search or pairing button on the head set.
Oct 02, 2009 | Motorola Cell Phones
Does the lg vx4650 have blue tooth capability for hands free
Looking at the spec sheet for it www.lgmobilephones.com it does not have bluetooth, but does have voice activation.
Jan 24, 2009 | LG VX4650 Cellular Phone
Motorola Razr 2 V8 blue tooth will not power on
my motrola v8 b tooth can b powered on , and it can recieve data but i cannt send data to any blooth tooth device , the send botton in the last not working, cn u tell me why.....
Oct 18, 2008 | Cell Phones
Samsung SGH-D820 bluetooth static problem
find somebody else with blue tooth on their phone or get a device that is blue tooth ie hands free kit then on your phone select search for bluetooth devices if it finds any then select the item you want ie a friends phone or blue tooth if it says it is active then your blue tooth is working but to use the item with bluetooth you have to select the item it should come up as a list of items select the one you want then this should pick it up and this should solve your problem if not post back and i will try again hope this is some help.........................
Nov 01, 2007 | Samsung SGH-D820 Cellular Phone
Samsung SGH-T619 Cellular Phone Logo
85 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
