Question about Canon Rebel XT / EOS 350D Digital Camera
Error 5 I cannot take a picture, I keep hearing a clicking sound, and I get an error 5.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 24 Answers
I have just gotten this error myself. I beleive the clicking sound is the mechcanism for letting the flash pop up. I have temporarily over come this by manually lifting the flash or selecting a mode that doesn't require the flash. The cause on my own is due to a piece of dirt but I have not done anything with it yet. Hope this gives a temporary respite.
Anthony (Ireland)
Posted on Sep 30, 2009
Picture and sound come and go on antenna or dvd
Try another lamp. Error 5 is Lamp power supply, but its usually always the lamp bad.
Mar 27, 2014 | Sony Grand WEGA KF60WE610 60" Rear...
I cannot change the cartridges as yhe holder seems to be stuck
Welcome to FixYa!
Note: When removing and inserting back the print cartridges, you need to use a small amount of force because of its safety locks. Just be careful not use excessive force, it might damage your printer.
If your printer has Two Cartridge System with no latches, here's a proper way to remove and insert the print cartridge. Please refer to the image below.
1. Press down the tip of the print cartridge and pull it away. You will hear a "click/tick" sound while pressing it downwards.
2. Make sure to remove the protective cover of the print cartridge.
3. Slide in the new print cartridge in its holder.
4. Lock it by doing the figure #4 in the picture below. You will hear a "click/tick" sound which indicates that it is locked.
If your printer has Two Cartridge Systems with latches, here's how to do it.
1. Pull up the latch. You will hear a "click/tick" sound.
2. Pull away the print cartridge.
3. Make sure to remove the protective cover of the print cartridge.
4. Slide in the new print cartridge.
5. Close the latch. You will hear a "click/tick" sound.
Thank you for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP DeskJet 940c InkJet Printer
I have a Canon Rebel. When I try to take pictures the flash "hood" or something automatically pops up but somehow the light doesn't flash and all I hear are 3 clicks. Then the screen says error...
Aprilm,
Error 5 is a flash error. What sounds like it happening is the mechanical part of the flash is working allowing for the pop-up, but the camera thinks there is an external flash present. A repair shop should be able to address the issue. Usually it's a problem with the micro switches "inside" the flash shoe.
Please let me know if you have any more questions.
Thank you.
Feb 20, 2011 | Canon Rebel XT / EOS 350D Digital Camera
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Have sound no picture lamp does not appear to be bad when looking at it yellow light blinks the shuts off tv then tries to start and can hear sound but no picture it will keep doing this till i turn the tv...
listen for the colorwheel noise
you'll recall hearing it "wind up" as the tv came on
many of these will go bad and then it will never fire the lamp because the colorwheel doesn't get up to speed
if you don't hear it, suspect the wheel, its hard to get since toshiba never had it as a seperate part
if you do hear it, its probably a bad lamp driver, but unlikely
let the tv go and go, it will try like 7 or 8 times and then eventually spit out an error. your user manual has the error codes, it will tell you if its the colorwheel i belive.
let me know if you need further assistance
Jun 06, 2010 | Toshiba 56HM195 56" Projection HDTV
RCA SCENIUM HD50LPW166 worked fine, then "POP!!" has power
you lamp is bad. even if it looks good, its not firing (you're seeing the spark gap fire, indicating this). the lamp is customer replacable and roughly $200. the 5 blink error is a general shutdown error
Dec 08, 2008 | RCA HD50LPW175 50" HDTV
6 red blinking codes
Below is picture of error code table of Sony TV KP-57WS500You can check what is error 5 and 6
Oct 31, 2008 | Sony KP-57WS500 57" Rear Projection...
Samsung HCN4226W 42 in. Rear Projection
My 5 year old Samsung HCN4226W is not coming on (no picture and no sound). When pressing the "ON" button, I can hear a "click" like it wants to come on, but nothing happens. HEL
Oct 10, 2008 | Samsung HCN4226W 42" Rear Projection...
No picture or sound
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source)
Sep 08, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Canon Rebel XT / EOS 350D Digital Camera Logo
121 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
