Question about Yamaha RX-V730 Receiver
Unit powers up for about two seconds and then dies.
I had the reciever in storage for about a year or two and just took it out. when i plugged it in and turned it on, the power is on for a second or two, and then it turns off. it does this repeatedly and will not stay on. what can i do? Thanks,
DF
    Genius:
  • 1,175 Answers
Are all the speakers connected?
Most A/V amps will go into standby if the speakers arent detected
Posted on Feb 24, 2008
How to Set Up the Kbox Pro Digy (FTA Receiver)?
-Extract files (factory bin & version bin)
http://www.abadss.com/forum/983-kbox...te-v2-0-a.html
-from remote, menu-config-system recovery & select delete all channels then factory reset
-insert USB into port in front of reciever, menu-utilities-data transfer-data download (from USB storage)-factory bin (version 1.81)
-menu-config,system recover y and select factory reset
-menu-utilities. data transfer, data download from usb storage-select latest bin (version 2.18)
-menu-config-system recovery-factory reset
-plug khub into reciever using black serial cable, also plug into network cable running to your router or switch
-from controller-menu-utilities-data transfer-data download from USB storage, then select khub activation
-menu-installation-options and make sure all AU options are set off and mode is set to network
-menu-installation-dish settings & config satellites you have setup dishes, then press red button on each satellite to scan in channels
-menu-config-network and change mode to DHCP press green button on remote and wait for it to be complete
-once previous step is complete, turn reciever off with remote, then from back. Wait 30 seconds, turn unit back on
Oct 20, 2016 | Video Game Consoles & Games
Stats ignights and goes out
Other similar questions on this site state that this is a problem with the water flow sensor. Although if that is the problem the flame would likely light for only about one second before going out. The water flow sensor fix discussed does not require any new parts. This YouTube video will talk you though it. Good luck.
Apr 02, 2013 | Coleman Hot Water On Demand
My Behringer PMX (or PMH?) 3000 powered mixer won't power on
Hi Robert,
The problem with ceramic fuses is that you can't tell if it's blown unless you put a meter on both ends to check for continuity. You probably have a friend that has a multi-meter sitting in a drawer somewhere, or a trip to the local Radio Shack will tell you right away - as well as likely finding the correct value fuse. Replacing it with a ceramic is not as critical as matching the AMPERAGE of the fuse (the Behringer site might be helpful: http://www.behringer.com/EN/Support/Find-Answers-or-Ask-Behringer.aspx
And no, the fuse didn't die on it's own, but are most prone to failure at turn on - so this time when you plugged it in after 3 years - it was time to go.
Mar 16, 2013 | Music
We have a briggs and stratton mower that has been in storage for 5 years with very few hours on it, it will start but dies shortly after.
needs to have carb cleaned out. most likely the main jet in the carb is plugged. symptoms include only running on choke and dies when choke is turned to run. or if you only have a primer bulb, it will only run for only a few seconds every time it is primed. if you are qualified to work on the carb, dont forget to start with fresh gas and possibly new fuel line and filter. R
Sep 03, 2012 | Poulan Pro 22inch 625 Series Briggs ...
I have a jl 500/1 . The distribution block is lit showing 12v plus. no green power light on the amp? I disconnected pwr and ground and reconnected. the green light came on for 10 seconds and shut off. all...
The amplifier will not power on unless/until it recieves the turn-on signal from the head unit.
It seems the issue is with the head unit in this case.
Check the fuses and verify constant and switched power with a multimeter.
Once the Head unit powers on - the amplifier should also.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 18, 2010 | Jl Audio 500/1 Car Audio Amplifier
No Power From My Reciever
Mook_trakzz, your device is most likely roasted and ready or scrap. Sorry.
Guest, check if the cables are connected properly, specially the cable between the device and the sub is quite easily shifted thus losing your sound.
timtlc, seems you have had some powerfailure during that night, you can try to remove the powercable for at least 15 seconds, that should reset the device.
to all, information from Philips on this device:
  • Press the STANDBY ON button on the front of the DVD system to turn on the power.
    If the device powers on at the unit and not the remote, the unit may have been turned off with TV selected as the source on the remote. The standby button on the remote will operate most Philips TV’s when TV is selected as the source. Change the source to disc or any other source than TV on the remote.
  • To completely reset the player, unplug the AC cord from the AC outlet for 15 seconds.
Feb 21, 2009 | Philips HTS3450 System
Yamaha HTR-5230 will not power on
check yhe fuse inside the unit?
Jan 03, 2009 | Yamaha HTR-5730 Receiver
SUBWOOFER
Sounds like the power supply in the subwoooooooofer box is dying.
Replace the whole thing . It's going to be the best way out.
Oct 25, 2007 | Sony STR-DE345 Receiver
Terrible sound
Maybe your tape monitor button is pushed or something along that line of thought. Check all your switches and buttons in front and back of the unit for proper position.
Jun 28, 2007 | Technics SA-AX540 Receiver
Yamaha RX-V730 Receiver Logo
138 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
