Question about Microwave Ovens
Use micro wave 3 times in a row,its ok.go to use it the 4th time,have to wait a few minutes before it will work.tried another microwave,same thing circuit problem ? lg made in korea
  • 909 Answers
You will find possibly the Magnatron has over heated and the sensor on top has activated. This can be possibly because the air intake to the magnatron is blocked or restricted. Clean vent and make sure it is not blocked off when oven is back in place. Need at least 120 mm air gap for good operation.
Posted on Sep 23, 2009
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    When power went off and then came back on, screen on micro wave continually shows demo and I cannot set time
    The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for about 5 minutes and try again.
    If it still won't work, then you may have a bad membrane keypad / DP circuit.
    If your model is NN-P295SF, the service is here.
    Parts can be ordered from Encompass here.
    Aug 19, 2011 | Panasonic NN-P295SF Microwave Oven
    When pushed, the 30 sec button says 3 minutes. none of the display buttons work.
    Have you inadvertently programmed your microwave for "autostart"?
    Your model microwave has the ability to be programmed to go on at any given time of the day/night, even when you're not home so that you can have a defrosted and cooked meal waiting for you when you get in.
    I know that if you hit the 30 sec button or the minute button when your micro is programmed to autostart it will tell you the time that it's programmed to autostart or the amount of time that's left for it continue cooking.
    Have you tried unplugging it for a few minutes?
    This should clear it's memory and then all you'll have to do is set the time on the regular clock if you want.
    Here's where you can download and read your owners manual for further instructions on how to use the autostart feature and everything else:
    http://www.fixya.com/support/p113437-emerson_mw8107wa_1000_watts_microwave/manual-11318
    Dec 26, 2009 | Emerson MW8107WA Microwave Oven
    Sparks and strange noise when microwave is turned on even when empty inside. i have a ge jvm1850smss over the oven microwave.
    YOU SHOULD NOT RUN MICRO WITHOUT ANY THING IN IT / THIS WILL OVER LOAD THE MAG TUBE . AND SOME TIMES FRY IT .. The sparking and arcing is probably a bad wave guide . this is sometimes caused by food splater / it gets in the cracks and corners and then cooks till it truns to carbon which conduts the micro's and thus arching .. clean it good and touch up any burns in the metal and repl wave guide cover. mm hope this will help .. mm
    Dec 20, 2009 | GE Spacemaker Over-the-Range Microwave
    Loss of all power when trying to cook/defrost
    The cost of repairing the micro wave will out cost the replacement value. If its new then use gaurrantee for replacement
    Sep 03, 2009 | Microwave Ovens
    Microwave will count down the time but will not heat up
    Only one thing heats in micro wave. If every thing works but heat, sounds like you have a bad mag tube. (Magnitron)
    Sep 02, 2009 | Kenmore 62622 Microwave Oven
    I cannot set the clock on my LG MS1949G Micro wave
    After spending 25 minutes on hold while LG try to find out how their own product sets the clock, I now know that the LG MS1949G Microwave open does NOT have the ability to set a clock that shows the time of day.
    Jul 11, 2009 | LG LTM9000 Microwave Oven
    Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
    Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
    A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
     Q - My microwave is running and sounds like it is working but will not heat up anything.
    A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
    Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
    A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
    Mar 03, 2009 | Amana Radarange Microwave Oven
    Micro wave does not work EM-Z2100GS
    First you check the fuse at the out put of highvoltage of the transformer. If the fuse is ok, replace the magnetron.
    Feb 28, 2008 | Sanyo EM-Z2100GS Microwave Oven
    Kenmore Microwave Problem
    "d" may mean demo mode.
    The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
    Let us know if the hard reset doen't fix it.
    Oct 13, 2007 | Microwave Ovens
    Microwave Ovens Logo
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
