Question about Jenn-Air WW30430P Stainless Steel Electric Double Oven
Jenn air ww30430p led controls are dim can't see temp. Need to change what part? and the doors never closed correctly
    Scholar:
  • 54 Answers
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the
design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, Using as small a soldering iron as you can find De-solder it and replace with new, match polarity marks and don’t use any more solder than needed.
If you run into trouble drop me an e-mail to dltatsjc@aol.com and I’ll try to help.
Good luck.
Thanks for this site..
Link to Photo sequence of capacitor replacement (Captions still will not link):
http://picasaweb.google.com/dltatsjc/Photos?authkey=Gv1sRgCJPKv9CRgsXxNA
Posted on Oct 12, 2009
  • Tom P Jan 06, 2012
    Thanks Dennis & BrianGem! I was able to repair my Jenn Air display problem in less than thirty minutes and for less than $5 thanks to you! I was able to order the capacitor online athttp://www.mouser.com/ for cents + s&h
    Thanks again!
  • Vince Tornillo Aug 16, 2012
    Dennis, Thanks a ton!! It took me longer to gather my tools and set up that it did for the repair! Pictures were a big help! Here is a link to the part I bought for 12 cents! and $5 to ship. Saved me over $494.http://www.mouser.com/ProductDetail/Pana... 88
  • 909 Answers
Ask for the LEDdisplay board for the oven. Quote the spares dept. the model no.and the long 8 to 10 digit no.on the sticker stuck somewhere on the oven.
Posted on Sep 23, 2009
I wish I had done it myself like solution #1. I had a repair man come and replace my board when my temp went dim, and now I can't get the oven to self clean without a fault lite going on.
I'm not very impressed with this oven.
Posted on Jan 27, 2010
Some touchpad buttons don't work but some do. Cancel button for bottom oven doesn't work. Have to flip breaker to turn off. CLock works
Jenn-Air WW30430P Oven User Manual - ManualsOnline.com
fitness.manualsonline.com > ... > Jenn-Air Oven
Free kitchen appliance user manuals, instructions, and product support information. Find owners guides and pdf support documentation for blenders, coffee ..
Sep 24, 2015 | Jenn-Air WW30430P Stainless Steel Electric...
I need the Start Amprege for a Jenn Aire #WW30430P
phone jen air tech support daytime Eastern Standard time:
1-800-JENN-AIR (536-6247)
Dec 20, 2013 | Jenn-Air WW30430P Stainless Steel Electric...
Door will not close all the way...
This is likely one of two problems. Either the fiber gasket is getting in the way or if it is like ours one of the hinges is broken or bent. The Hinges can be replaced for about $13 a piece and is not a difficut job. On our the oven was also opening more then 90 degrees and wouldn't close more then to about 1.5 inches away from full closure.
Jan 09, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Am negotiating a home inspection on a house with WW30430P Jenn Air Wall Ovens; neither of the doors close. Is there a solution?
There are several models of Jenn-Air ovens that had issues with the door closing. The only solution is to replace the door hinges (unless the doors themselves are bad, you can see this if you open the door, the porcelain on the door will be bulged and cracked right where the hinge joins the door). If the doors are bad, the hinges and the interior door panels need to be replaced. Hope this helps!
Dec 16, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Jjw9630aab panel is dim
See other posts regarding replacement of capaciter #C3 on control board, cost of capaciter approx 65 cents.
work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, De-solder it and replace with new, match polarity marks and don’t use any more solder than needed. TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
Good luck.
Mar 25, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
LED Display fading
As noted in solutions to other Jenn Air ovens, this is often solved by replacing the capacitor labeled C3 on the circuit board that contains the display. Oven heat apparently causes it to fail over time. This is a solder connection to the circuit board. Not hard if you have any experience with this kind of soldering it is straightforward.
Seven phillips sheet metal screws to remove panel assembly, plus two electrical connectors. One ribbon connector from touch panel to board, then four 1/4 hex sheetmetal screws to remove circuit board from touch panel and metal frame. Then soldering iron.
It did work on a 40300 dual unit, which is same as this model except for cosmetics.
Capacitor is 35 volt 68 microfarad. Radio shack has 100 microfarad, which one report says works. Radio shack doesn't have a 68, but they do have 22 and 47 which mounted in parallel give 69, which is within tolerance. That's what I used. The capacitors cost $1.29, less than 1% of the cost of a new circuit board.
Jan 15, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Problems with Jenn-Air Electric Double-Wall Oven
that board supplies power to the light unit and it is very easy to replace if that is what is wrong. it can also be the led display unit also. cost about $150 each i think.
Oct 26, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
The electrical panel does not light up
I'm afraid you are going to need a new display board. Not very hard to change but a pricey item. Have seen this problem a few times. Good Luck!
Oct 05, 2006 | Jenn-Air WW30430P Stainless Steel Electric...
The oven door are not closing all the way
spot, Maytag put out a service bullitin on this issue....TDC-0017B-B, They put out a new hinge kit...part #12002111 for single and 12002112 for double units. This may be covered under this service flash. Call Maytag service and inquire about the above mentioned service bullitin. Problem addresses doors not closing...Catriver..post back.
Sep 03, 2006 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air WW30430P Stainless Steel Electric Double Oven Logo
1,021 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
