Question about Panasonic AG-HVX200 Mini DV Digital Camcorder
At random intervals my hvx camera will vibrate as though some gears are trying to be engaged. I am not using the zoom when this happens. it seems to happen when the camera has been in use for 15 minutes or more. The odd thing is that it will also stop vibrating after 10minutes or so. It has been doing this on and off for the past few months. Any ideas?
  • 126 Answers
Try the OIS function off,if it continues and you are sure no obstacle inside lens then camera board must be replaced,
Posted on Oct 13, 2009
Screen zoomed in zoom out
this is likely a virus, trojan issue... have you done a thorough virus scan with current software???
superantispyyware.com... free
Aug 17, 2013 | Sony Computers & Internet
My wife has a Sony SuperShot DSC-T300 camera that periodically (for no apparent reason) starts to vibrate and prevents her from taking clear pictures. It seems to happen randomly and go away randomly...
This is a common problem with Sony cameras. They fixed some of them for free for awhile. You should complain, complain, and complain some more to Sony.
Mar 01, 2011 | Cameras
I purchased my G11 end of Nov 2009, and just started to have problems this morning. When shooting, the directional buttons, control dial and func/set button won't work. Also, if I zoom in on a subject the...
It could be a bad battery. Try using AC power or getting a new battery. What is the temperature. if it's cold try bringing the camera slowly up to room temperature.
Nov 30, 2010 | Canon PowerShot G11 Digital Camera
Zoom error on J27 fuji camera - brand new can take photos but can't use zoom feature
There is a problem with the gear system for the zoom feature, most likely a damaged gear, or something tricky. If it's still under warranty, take it back for a replacement, or send it off to repair. You have to disassemble the entire camera to fix something inside the lens assembly, and they usually just replace the whole assembly, from what I understand, and it's pricey. If the unit isn't under warranty, or they won't cover it with this problem (sometimes they will say it's neglect or abuse to the lens assembly), you can try to push the zoom button and gently pull to try to help the gears engage, if they're just stuck, or some sand, etc., got inside the gears. But first, try to blow any dirt or sand, etc., out of the lens assembly with some compressed air. If that doesn't work, place the unit flat on something soft, and hit the zoom button while you try to lift and gently twist the lens. Do this a few times, but beware that you might do further damage, so go easy on it. If this doesn't work, the unit will have to be serviced. Get an estimate first- that can get pricey, and sometimes it's just better to get a new camera. Hope you get lucky and get it working.
Apr 24, 2010 | Fujitsu Cameras
Sony 18-70 kit lens vibrates badly
This is a lens problem, the AF motor of the lens is trying to engage the gears. Sometime it works, sometimes it does not... It happened to my sigma 70-300. The only solution is to have it repaired. If under warranty it should be free, if not.... might be cheaper to buy a new lens.
Sep 28, 2009 | Sony A100 Digital SLR & 18-70 Lens Kit...
Vibration mode cycling at random
Went to a Verizon store and they updated my software. This seems to have solved the issue.
Jun 24, 2009 | LG VX9400 Cellular Phone
Dont know how to use the harddrive with camera
Make sure you turn your other settings in the menu while in camera mode to ext, both or chain. Ext. mode, means pushing record on the camera makes the hard drive record, but not to tape, Both means that both tape and hard drive will record, Chain means when you run out of recording onto tape, the hard drive will automatically start recording as the tape runs out.
Mar 25, 2009 | Panasonic AG-HVX200 Mini DV Digital...
Zoom Error, Lens won't close
There are several causes for this to happen.
1. The lens assy is out of alignment and stuck; stalling the motor.
2. The motor itself is defect
3. If you can hear the motor working , then it will be a stripped plastic gear between motor drive and lens assy.
DIY repair not recommended (possible)
Mar 07, 2009 | Fujitsu Cameras
Lens motor
You are nearly right or even has stripped gears. Check out Olympus for a possible repair I do not think you will be jumping for joy at the price though.
Aug 21, 2007 | Olympus Camedia C-4000 Zoom Digital Camera
Image size over
change a brand new original memory stick
Jan 15, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Panasonic AG-HVX200 Mini DV Digital Camcorder Logo
60 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
