Question about Motorola Mobility RAZR V3
Phone locked up while I was adjusting volume, probably hit other buttons at the same time. Now even after removing batery (it won't shut-off normally), when restarted the screen is black and all buttons are locked.
I accidentally hit the auto-adjustment button on my monitor. Now, the an inch of of my screen from left to right is black. Not even my mouse can go into the black space.
Did you try hitting the Auto adjust again to possibly shut it off. Quite often the buttons work as off and on buttons such as the Caps Lock. you hit it and it's on. You hit it again. It's off. If you hit the Auto adjust it might shut off and re-adjust your screen to the original setting you had. ....don't forget that you made other adjustments to compensate for the mal adjustment that will need to be fixxed. good luck.
Dec 22, 2014 | HP W2072a 20in. LED-Backlit LCD Monitor,...
Broken volume button, in-call volume won't go up
Hit volume down then use on screen slider to move it up it will appear at top of screen to the right is volume up.
Feb 09, 2014 | Motorola Mobility MILESTONE XT720 Cell...
Pioneer 4000 shuts off when touching anything
Reload software from Pioneers support web sight.
Jul 23, 2012 | Pioneer AVH-P4000DVD Monitor
Volume is mute
There is probably a button or key you can press to unmute the volume. Most times you have to Press and Hold the FN function key at the lower left portion of the keyboard then hit the key that has the megaphone with the x across it.
You could try right clicking on the megaphone at the bottom right near the time and adjust the volume or properties. Remove the check mark from mute.
Or you can look for the Audio Sound properties in the Control Panel. Click Start/Control Panel and look for Audio Sound. Open it and remove the mute check mark if it is on the volume controls.
Apr 29, 2012 | Computers & Internet
My inspire seems to be locked on one screen that has a red triangle with an exclamation running through it. The phone will not shut down. It is frozen.
It is the boot rom menu for the device. Just power it off then back on. IF it comes back then your OS on your phone is toast.It means your phone is in recovery mode. Hold down the volume up and power button at the same time, then select the option to reboot by going up or down with the volume keys and pressing the power button to confirm your selection.
Dec 06, 2011 | HTC Inspire 4G Smartphone
How do I adjust the volume control on my samsung t255g cell phone?
Main Menu Settings Sound Profile Find your selection (example "Normal") Hit the "OK" button Then there are three categories to choose from on this next screen (call, message, phone) use the left/right keys around the "OK" button to choose which one you want. Use the up/down keys around the "OK" button to modify the selection For example, use the right key to go to "Phone" and then the down key to make adjustments. Keep hitting the down key until the writing in the yellow menu says "volume" Hit "OK" From there you can adjust the volume
If you want to adjust call volume, highlight "call" with the left/right keys Use the down key to go in the yellow area and keep pressing the down key until you see "ringtone volume" then hit "OK" and it gives you an option to adjust ringtone volume
Hope this helps!
Feb 27, 2011 | Cell Phones
Is there a way to disable the voice recognition button on my Samsung intensity??? Whenever I go to slide it, I hit the button, and my phone talks, even when i hav the volume on vibrate only.
I have the same problem with my Intensity every time I keep it in my pocket. Unfortunately, you can't disable the voice recognition function completely, but you can make it more managable.
You can get rid of the voice that says "Please say a command" when you hit the voice recognition button, and instead make it just a single tone by following these steps:
- Hit the voice recognition button on the side of the phone
- Press the right option button to go to the Settings
- Go to #5, Prompts
- Select Mode
- Select Tones Only (the last option)
- Hit OK
You can also reduce the volume by changing the output from the speakerphone to the ear piece, to make it quieter. Go to the Prompts menu like you did above, and select #2, Audio playback. Set it to "earpiece" and hit OK.
Now, when you accidentally hit that button, the phone will just emit a short tone that you probably won't even hear. Hope that helps!
Jun 07, 2010 | Samsung SCH-U450 Cell Phone
My g502 is turning off by itself what can be the problem
Hi Shantishalon
You have not specified under what scenario you are facing this problem
Pls check if you face this problem while not using the phone if it's idle, or do you face this problem while powering the phone on, or does it go off by itself while charging the phone.
however one common problem could be as follows:
If your phone turns itself off when being transported, something in your pocket or bag has probably activated the on/off button. To avoid this you can turn on the automatic key lock function.
Please note that if you click the on/off button for more than 10 seconds the phone will turn off, even if the key lock feature is activated. This is to ensure that the reset function is always available.
Nov 24, 2009 | Sony Ericsson G502 Cellular Phone
Volume will not adjust on Treo 755p
This may resolve the problem. My Treo 755 stopped hotsync some time ago and then I noticed that the volume control side buttons had no effect. On suggestion from this site, I removed the battery for several minutes and then reinstalled it and the phone has returned to normal activity, hotsync-ing the first time and volume buttons working fine.
Jan 08, 2009 | Palm Treo 755p Smartphone
Volume
hi pkeyes40, my phone is a differenet model number, but on my phone you raise the volume by hitting the hands free button, then press the delete button several times to adjust the volume ( 1-4), then press the hands free button to confirm. then hit delete to exit. hope it works the same for your phone. good luck. and if you would like me email you with the manual i have for my phone, an innovage lcd phone/caller id 1507102, it might give you some pointers. my email address is all8upinwv@yahoo.com
email me and i reply with the manual. hope i helped ya out. good luck.
tammy
Mar 27, 2008 | Innovage Touch-panel Phone 1502084
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
