Question about A-Top XBlade Mid-Tower Case
Front audio connections
Hi ive got a an-m2hd motherboard and a xblade case all it says on the box is 703a-x in the mb book it says
hd audio xblade case
pin 1 mic2 L return r return L gnd
pin 2 agnd mic in mic bias
pin 3 mic 2R spk out L spk out R
pin 4 avcc
pin5 fro R
pin 6 mic2 jd
pin 7 f io sen
pin 9 frol L
pin 10 line 2 jd
please can you help
  • 1 more comment
  • kuss Apr 24, 2008
    i cant work out how the usb and audio fit thers nothing writen on the mother board 661fx-m7
  • strokerx1 Sep 09, 2008
    the audio settings for my mother boerd receives audio but it cant get out by the mic .My mother boerds specifies on a hda cable that i dont know if its compatible whith the one i have on my xblad
  • amg1975 Nov 14, 2008
    hi
    just bought an xblade tower wtih an abit a-n68sv motherboard. when connecting it up though the connectors for the hd audio differ from the motherboard descriptions
    can u help please.
  • 92 Answers
OK, let the speaker cable be your guide, its a for pin female connector, form there you should find your way.
let me know
Posted on Feb 07, 2008
ASUS P5KPL AM/PS front audio not working
Is the front panel audio connected to the motherboard? With any problem involving Wigglies(electirics) you should check your connections first, then fuses. In your case just the connections.
Mar 08, 2012 | ASUS P5KPL-AM/PS Motherboard
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
Asus P5LP-LE Motherboard Front Panel Pinouts
N/C Reset Gnd HDLED- HDLED+
GND PWR PWLED- PWLED+
Mar 11, 2010 | ASUS P5LP-LE Motherboard
Sound cable connection
Look more closely at your motherboard, for a 4-pin "PC Speaker" label.
The "HD Audio" is _OUTPUT_ (left front, sub-woofer, right front, left back, right back) to Surround Sound speakers.
Dec 31, 2009 | Foxconn (945G7MA-8KS2) Motherboard
I cant wire up my XBlade case's audio!
look through your motherboard manual it should have a layout in there
Jun 23, 2009 | A-Top XBlade Mid-Tower Case
Front panel audio connection to asus pk5 se mobo
Hi Tracybow,
The Front Panel Audio connection should have a couple of wires to plug in into your MotherBoard. Usually, the connectors are named and all you need to know is the exact location in your MotherBoard.
I would suggest you to visit your MotherBoard manufacturer and download the manual for your MoBo. You will find in the manual a diagram of the MotherBoard which shows the location for those wires.
Hope this helps.
Best regards
Eduardo
Oct 03, 2008 | Computers & Internet
To fix front usb and audio to the mother board
Consult the user manual for the motherboard. It should have a layout diagram showing all connections. Or go online to manufacturer's website and download the user manual there. Also, using a bright light and magnifier you may be able to read the small print on the motherboard by the connectors.
Apr 24, 2008 | A-Top XBlade Mid-Tower Case
Front panel how too
Hi slider1958,
You want to connect the new case's front sound & mic.
Just about every case will come with a pre-assembled connector for front USB's & sound & mic. Your board has a set of ten pins used just for this. They are loacted just under the boards rear external sound / mic silver housing. Noted in your manual on pg. 15. Named AUDIO1.
def37da.jpg Notice there is one pin missing. Line your case connector to match.
The manual is uncleare if you are able to use both rear speaker & front speaker at the same time. I would think not. Newer boards with HD do allow this.
Good Luck & Kind Regards.
& please vote.
Mar 18, 2008 | Intel Motherboard
No sound from front panel of GIGABYTE GA-MA69G-S3H
Aloke,
It does mention in your manual (top of pg. 28 -notes), that in order to use the HD Front Panel Audio connector the pin configuration are different than the AC97 connections. Your current case is set up for AC97. You will have to contact Mfg. for the case click the link for Gladiator support:
http://www.a-top.com/jsp/info.jsp?number=3
You can try this, open up your control panel, look for an icon that's named Sound Effects Manager. Open it. Click speaker configuration.
This is part of Realtec's software. This is where you can setup & check both front & back ports (Audio & Mic).
If this part of Realtec did not install goto Gigabyte & down load your audio software & re-install it. (Just a suggestion).
http://www.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2554
Hope this helps. If you make the call it will be a fix.
Good luck.
Mar 14, 2008 | Computers & Internet
Intel D101GGC Motherboard front headphone mic not working becoze wire not attach in motherboard
Simple dear connect the wire on Motherboard. The pins you will get near the outer portion of your motherboard.
Feb 24, 2008 | Intel D101GGC Motherboard
A-Top XBlade Mid-Tower Case Logo
505 people viewed this question
Top A-Top Computers & Internet Experts
David Payne
David Payne
Are you an A-Top Computer and Internet Expert? Answer questions, earn points and help others
