Question about LG WM2487H Front Load Washer
Ie error code on washer. Cleaned the bottom filter and disconnected water hoses to clean filter. Once reconnected, the hose leaks and water is not going into washer
  • kcoar Sep 23, 2009
    what is the water inlet valve? Where do I get it?
    IE error message on my washer. I checked the hoses and filters. Now the hoses are leaking and still coming up with code.
  • 11,896 Answers
The valves or seals are faulty and will need to be replaced. Feel free to ask any questions and make sure to check out this link for great info on your problem. Just copy and paste it in your internet address bar:
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Posted on Sep 23, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error IE means WATER INLET ERROR. This happens when the Correct water level (246) is not reached within 8 minutes, after water is supplied or it does not reach the preset water level within 25 minutes.
To resolve this error check the following steps to troubleshoot the issue--
  • Is the tap opened?
  • Is the tap frozen?
  • Is the water supply shut-off?
  • Is filter in the inlet valve clogged with foreign material?
  • If all above things are fine then you'll need to replace the Water inlet valve.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
THE SCREEN SHOWS IE
Hello there and thank you for choosing fixya
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
And finely if all of this does not work then the inlet valve on the machine needs to be replaced ok?
Hope this all helps
Aug 05, 2011 | LG WM1814CW Front Load Washer
Tip
LG Washing machine IE error code Solutions
Are the water valves opened completely?
Are the inlet hose filters clogged?
Are the inlet hoses attached properly?
NOTE: The inlet filters are inside the hose connections on the back of the washer. Because of their small size, take care when removing and cleaning the inlet filters so that they do not break.
on Jun 02, 2011 | Washing Machines
What is problem code IE and how do I fix it on my LG front load washing machine?
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. if this doesn't help then there are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly. wm_inlet_filter_removal(1).jpg
Hope this helps.
Mar 09, 2011 | LG WM-2277HW Front Load Washer
The machine is indicating an IE fault
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly wm_inlet_filter_removal(1).jpg
Mar 02, 2011 | LG WD-1280FHD Front Load Washer
I cleaned the pump filter after getting sud error. now i get F 21 code.
Press the pause cancel button 2 times this should clear it. If it does not and the filter and drain hose are clear you will need to replace the pump.
F21 Fault Code Repair
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
LONG DRAIN
NOTES:
Nov 03, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
IE error code
IE. is inlet water valve error.
Make sure someone did not turn off the water to the washer!!!!
Remove fill hoses and check filter screens on washer and fill hoses and clean if needed.
If problem continues water valve may need to be replaced.
Jan 16, 2010 | LG Washing Machines
Displaying IE fault code
This is an inlet error. Shut the water valves off and remove the hoses one at a time. Shine a flashlite in to where the hose screws into the machine. Check the filter screens in there for any type of debris. Yiu can remove these filter screens with needle nose pliers. Once they are cleaned and re-installed, try it again. If is still showing an error, you have a connection/valve/or control problem.
Jan 13, 2010 | LG WD-1045FH Front Load Washer
My whirpool duet washer is displaying F33 code. It doesnt spin at a high rate of speed to allow for the clothes to spin dry therefor the door latch will not open.
The F33 error indicates a PUMP DRIVE SYSTEM ERROR and occurs when the connection between pump and the Central Control Unit (CCU) is lost.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the pump and Central Control Unit (CCU).
3. Plug in washer or reconnect power.
4. Verify CCU operation by running a Diagnostic Test or any cycle.
System Leak - Select 'cancel' twice to clear error code. Check for any cracks or holes in the washer tub or pressure switch hose. Replace if damaged.
Also
1. Switch off the machine and disconnect the mains power.
2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray.
3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
4. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
5. Reconnect the power and switch the machine on.
If the problem persists then do the following.
6. Switch off the machine and disconnect the mains power.
7. Check the electrical connections at the pump and make sure it is operational.
8. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
9. Makes sure the pump appears clear and that the impeller looks in good condition.
10. Reconnect the hoses and then reconnect power and switch the machine on.
11. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fisher and paykel water leak
Code F1 indicates that Flood switch has been
activated which explain why you feel that it is overfilling.
Water leaking
Drain hose disconnected
from waste pipe.
Reconnect the drain hose to the waste pipe.
Supply inlet hose not
properly connected.
Ensure the inlet hose is connected securely.
Other leaks. Turn water and power supplies to the
Dishwaher off.
Mar 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Whirlpool washer f30 code
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
Jan 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2487H Front Load Washer Logo
54 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
