Question about HP OfficeJet 6210 All-In-One InkJet Printer
I have a document in the que which I can't delete
I have a document in the print que which I can't delete for some reason and it's blocking any other print job; how can I cancel it and get it off the que? This is an HP Office Jet 6210 all-in-one, but I think the problem is not with the printer
  • rmperk1 Sep 24, 2009
    Worked like a charm--thanks.
  • HP Master
  • 4,338 Answers
Shutdown the PC . Then just pull the power plug from the back of the printer for 30 secs.
Afterwards turn on the printer first, then the PC. It should clear out.
Posted on Sep 23, 2009
Testimonial: "fast solution."
    President:
  • 2,976 Answers
Go into the control panel and select "Printers". Right click on your printer and check properties. Look for pending print jobs and cancel them there.
Documents in printer que, but does not print
If a print job get hung up in the print que it may stop and not be able to be deleted, this will also block other print jobs from printing. Here is a link to an article that shows how to clear the print que and purge the stuck print jobs so printing can resume. I hope it helps.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Dec 10, 2012 | Sharp Mx-2310u Color Copy/print/scan
Print que on hp 4300 says "printing" but nothing happens and I cannot clear que
This is a common problem with Windows machines. If a print job gets corrupted in the print que it will stop and block all other jobs from printing. It will also block the job from being deleted normally. You have to stop the print que service and then delete the print jobs from the que. Here is a link to a full article that shows how to stop the que, delete the print jobs and restart the que to restore printing.
Nov 29, 2012 | HP LaserJet 4300 Printer
I have an HP printer. There is a full page photo that will not print. When I try to cancel the job is states deleting but does not delete. It deletes other added print jobs but not that one which is...
You have to clear out all documents one by one in the print que before you can delete the one causing the trouble. On the bottom right side of your pc screen, find the picture of the printer and right click with your mouse on it. Open your print que and right click on each document and choose "delete" until therer are none left in the print que. If this does not clear that last document, then unplug your usb cord that connects the printer to your pc and wait a few moments, and then plug it back in. This should clear it out.
Sep 08, 2010 | HP Officejet J4680 InkJet Printer
There has been a pending document in the que. I tried to delete the document but now it states deleting next to the document in the que. Can not print anything.
Open the Print Que and see if it will let you pause the print job. Then close the que and turn the printer off. Open the print que again and see if it will let you delete it. For some reason every now and again a que will hang. This process should reset the que. It will dump everything in printer memory and should release the document to delete the job. In any event pausing the job should release the printer to print other jobs.
Sep 05, 2010 | Office Equipment & Supplies
Today i was trying to print a document, but then when it came out of my printer, its not how i wanted it to be printed. So i pressed cancel on the printer itself. When i tried printing the document again,...
You must clear the que.
You should be able to download the print driver. Id try clearing the que first. do the three finger wave if necessary to find the process - terminate it - then reopen the que - see if the document is gone.
Unplug your printer - ower and signal ... go get a soda . when you get back plug the stuff back in ... remember - shut the stuff off first!
I hope this helps
a
Sep 23, 2009 | Office Equipment & Supplies
Dell 948 printer will not delete a document
try putting a sheet of paper on the printer and hit the print button..
Aug 11, 2009 | Dell 948 All-In-One InkJet Printer
HP photosmart C5280 document stuck in print que
Delete document manually from the path mentioned below:
1) Press windows + R an then type spool
2) Go to PRINTERS folder.
3) Delete the files present in there.
If not able to delete then
1) Open command prompt.
2) type "net stop spooler" and then delete the files
3)Again type "net start spooler"
Your stuck document is now cleaned. You can start printing your document again.
Mar 30, 2009 | HP Office Equipment & Supplies
Can not delete document in print q - nothing else will print
Open task manager,(Ctrl +Alt +delete) and end task on print spooler,delete the file.print spooler will restart automatically.
This works best if you have the que window open first.
Please rate this fixya
Jan 25, 2009 | Lexmark X3550 All-In-One Printer
Printer not printing documents in que
my printer hp psc1315xi all in one printer copier, scanner will not print any documents, not even a test print, there is also a doucument in it that am not able to delet from the printer
Jan 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
182 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
