Question about Kenmore Dishwashers
The dishwasher makes a whining sound after 2-5
The dishwasher makes a whining sound after 2-5 minutes into cycle
  • 909 Answers
The main wash motor has a bearing issues. They need to be replaced. Take RHSide cover off and remove motor to do repair.
Posted on Sep 23, 2009
Still making a sound after a cycle
That whining sound is most likely the small fan Toto has to "cool" the electronics. Very similar to a laptop PC fan. The fan will eventually go off, ~ 20 minutes. If you would like it to go off immediately, simply push the power button on the seat - off, and then again for on. Do this action while you are not sitting on the seat, otherwise the cycle will start again. :)
May 01, 2015 | Toto Round Washlet S300 Toilet Seat -...
Dishwasher is making a loud noise
Sounds like there is something in the filter trap that is right before the mini disposal that is a fan blade, on top of the motor.
Aug 04, 2012 | Frigidaire Professional Series 24 in....
LG dishwasher error code after 2 minutes
fault with the programe as it has stoped in mid cycle
Aug 01, 2012 | Whirlpool Dishwashers
I have model #FGBD243KF1, Gallery 24" stainless. The wash cycle is taking almost 2 hours. Should it take this long? Also, when switching cycles during the wash time the motor whines a bit. Is this...
these units are pre programmed they can wash that longer and sometimes up to two hours and fourty five minutes. there are alot of factors involved.your unit sounds like it is running normally. at this time
Mar 27, 2011 | Frigidaire Dishwashers
Dishwasher makes a whinning noise during the washing cycle. I have opened to check inside, and the dishwasher is ok for a few minutes, then it starts whinning again. The dishwasher is just over a year old,...
If wash quality is OK leave it. Pump will make whining noise due to its' ball/bush bearing problem.
Some times if the water inlet flow is not free in flow also results in noise.
Clean the inlet water filter and check the flow before re- connecting to the machine.
Aug 30, 2010 | Dishwashers
A loud whining noise from motor area...diminishes during cycles but resumes at times.
it sounds like to me the water pump on the bottom of the dishwasher sounds like its getting tired the bearings are going an as the water gets stronger its lubricating the beering making it dimishe
Jul 10, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Our kitchen aid dishwasher is about 7 years old, recently it has begun making a high pitched whine while the wash cycle is running. The dishes are still clean, but the noise is new and annoying not to...
Sounds like it could be the bearing in the wash motor. If the sound is only present when you can hear water being thrown around then this would confirm it. Not sure about spares availability on a 7yr old machine though
Jan 18, 2018 | KitchenAid 24 in. KUDI01FLSS Stainless...
Bosch dishwasher whining
if you listen to the appliance and the noise is louder on the rhs and low down this is probably the main wash motor they sometimes do whine if you can live with the noise leave it alone if not you basically have to take the whole applianmce apart for access to the motor costly repair would take a trained pro about 90 mins to replace the motor
if the noise is coming from the front of the appliance more to the lhs and is intermittant ie when it first starts up and then about half way through its likely to be the drain pump relitively easy to replace and you dont have to take the appliance to bits just go at from the front
good luck
Mar 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore automatic dishwasher
Sounds like a Bad Solenoid. Locate the part then tap it with the back of the Screw Driver during the cycle. see what happens.
good luck
Kashif.A
Mar 06, 2008 | Dishwashers
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Dishwashers Logo
276 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
