Question about Storkcraft Baby Cynthia 04550 Crib
NO LONGER AVAILABLE
I just bought a second hand storkcraft, and the clip that pushes in to release the rails on either side to lower or bring up the rail is broken. I emailed storkcraft and it is no longer avail. I think I will fix the rail on the one side with a screw so that it will no longer be moveable, and then just use the other side to go up and down.
I don't know which model of crib it is, since it came second hand, but its glossy white wood, kinda sculpted headboard/footboard. romantic looking.
  • 302 Answers
Be careful with used cribs as they can be quite dangerous.
I'm not sure if your idea will work,as both sides of the rail need to be raised up and down. Or do you mean that both sides of the crib go up and down?
If I had a picture it would help.lol
Make sure that if you can't fix the sliding rail that you leave it at the highest position so that baby can't pull itself up when he/she gets to that stage.
You could try finding another one(for parts) at a second-hand store,yardsale,etc.
Good luck.
Posted on Sep 23, 2009
How do I fix drivers window that wont go up or down on a 2000 dodge durango
This is a common problem in these model years of Chrysler vehicles, Be patient and you can easily DIY. The mechanism consists of a motor and two cable/two guide rail assembly. The guide rails hold the window onto the cable with a clip on each rail. It is better to buy the whole assembly new rather than just replacing a bad motor or just the guide rail/cable assembly. I have been burned just replacing one or the other only to learn when popping open the cable spool that 1) cable is shredded or 2) it ain't easy winding the cable back up as tight as the mfr had it and the window won't roll up with the same speed as the other one. You will need a Torx set... a 25 or 30 size if I remember will remove the guide rail bolts. Some models have the motors riveting on with soft aluminum rivets. Just drill them out... like butter. Others have torx bolts on them with the nuts encapsulated inside a grommet. Put your hand behind and inside the door panel to hold them with your hand when removing the torx bolts. Their are two holes on the inside of the door panel... one guide rail is extracted through one of them, and the other one through it's own hole. Push the window up first, have an assistance hold it halfway up for you so you can see and pull the guide rail release clips with needle-nose pliers. Push the window up all the way and tape it using a good tape around the door sill at the top. Then you can start removing/replacing the motor and guide rails. When your done, plug the wiring harness back in and raise the guide rail half way up using the motor and then unplug the harness again. Have your trusty assistant lower the window down gently, insuring it's inside the groove and stopped by the guide rail clip assembly. Insert the clips back in and test your work before re-assembling your door panel. Crutchfield makes new door panel liner, if yours is crispy. A heat gun sometimes help remove them more intact. Good luck!
Oct 05, 2014 | 2000 Dodge Durango
2004 f150 dome light with center roof rails, how do you replace the light bulb on the drivers side. This is the type that you push on and push off.
Double check, the rail system roof console should be held on with just spring clips ( check for a screw facing down, or to the side, pull out the rail accessory boxes to be sure ).
If so, start on one side with a hook plastic trim tool and pull down to release the spring clip, and work your way around.
On the back of the roof console the bulbs are installed in 1/4 turn bulb holders, remove form the back to replace the bulb.
Oct 28, 2010 | 2004 Ford F150
Is this crib recalled wm-1633-0
Storkcraft had a recall on some of their cribs.IF it is a Storkcraft you have to call them and give them the model number.
These cribs were made between May 2000 and November 2008.They were sold until Jan.2009.
Even if your's isn't a Storkcraft you should be able to call the manufacturer of your crib and ask them.
Storkcraft,for one,did not post the model numbers that were recalled.
The manufacturing date can be found on the lower right hand corner of the instruction sheet which is glued on the mattress base.
The cribs were sold in various styles and finishes. The manufacture date, model number, crib name, country of origin, and the firm's name, address, and contact information are located on the assembly instruction sheet attached to the mattress support board. The firm's insignia "storkcraft baby" is inscribed on the drop side teething rail of some cribs.For more information, consumers may contact Stork Craft toll-free at 866-361-3321 anytime to order the free replacement kit or log on to the newwindow.gif firms Web site.
These cribs have had recalls as well:
Jenny Lind crib model 6982 with lot numbers 8021, 8024, 8025, 8052, 8053, 8055, 8056, and 8070 and model 6983 with lot numbers 8022, 8023, 8026, 8027, 8031, 8032.
Aspen 3 in 1, Aspen 4 in 1, Nursery-in-a-Box, Crib N Changer Combo, Chelsea and Pooh 4 in 1. The recall also involves the following Simplicity cribs that used the Graco logo: Aspen 3 in 1, Ultra 3 in 1, Ultra 4 in1, Ultra 5 in 1, Whitney and the Trio.
The recalled cribs have one of the following model numbers, which can be found on the envelope attached to the mattress support and on the label attached to the headboard: 4600, 4605, 4705, 5000, 8000, 8324, 8800, 8740, 8910, 8994, 8050, 8750, 8760, and 8996.
13 babies in the US alone died as a result of the Simplicity cribs...in Canada most of them were sold in Zellers...but don't try to take it back there.
pinehurst.jpgLaJobi and CPSC announced two recalls for 4,900 cribs.
First, 2,000 Bonavita "Cabana" cribs were recalled for slat failure -- the slats can come loose and/or break. LaJobi had ten reports of slats coming out of the rails and six reports of slats breaking.
Also, 2,900 Babi Italia "Pinehurst" cribs and Bonavita "Hudson" cribs were recalled for drop side failures.
Step 1 Register your baby crib as soon as you bring it home so you will receive product recalls automatically. Usually manufacturers ask you to register to validate warranty information but this will also register you to receive product recalls.
  • Step 2 Check the U.S. Consumer Product Safety Commission website regularly for recall information. This is a dependable resource that many consumers are not aware of.
  • Step 3 Visit your crib manufacturer's website occasionally and type in your crib name or number under their search option.
  • Step 4 Monitor the recall website www.recalls.gov that constantly updates recall information on all consumer products including baby cribs.
  • Step 5 Stay up to date with current news reports and printed media outlets. They are often the first to announce safety recalls and possible product issues.
  • Sep 22, 2009 | Dorel Alexander
    I have a storkcraft 3 in 1 crib. I want to
    Vancouver-based manufacturer Stork Craft is voluntarily recalling more than a million baby cribs in Canada and the United States over a potential suffocation hazard.
    The cribs were manufactured in Canada, China and Indonesia between May 2000 and November 2008, the company said in a release.
    About 494,000 of the cribs were sold in Canada and 535,000 in the U.S. in several retailers such as Wal-Mart, Kmart and J.C. Penny, as well as on several websites, including Amazon.com, Babiesrus.com, Costco.com and Walmart.com, the U.S.Consumer Product Safety Commission said in an advisory Tuesday.
    IF you call them they will send out free replacement parts...maybe more?
    Remove the rails.Use the previously drilled holes for the bottom of the side rails as the guide for the bed rails.
    Did that make sense?
    Aug 21, 2009 | Storkcraft Baby Rochester Crib
    Storkcraft plastic rail lock broken need new part?
    Apparently if you call them they may give you free replacements. Assuming the one you have is one of them.
    I would try new/used stores,etc. if your's isn't one of the recalled ones.
    Aug 15, 2009 | Baby Gear
    Can not get side of crib to come down!
    You pull up and push in with you knee on the lower part at the same time.
    Feb 28, 2009 | Storkcraft Baby Aspen Stages Crib
    Barrel nuts busted for toddler bed side-rail.
    JUST BOUGHT 1 PACK OF 4 BARREL NUTS FOR STORKCRAFT CRIB AT CANADIAN TIRE FOR $3.59. WORKS GREAT!
    Jan 09, 2009 | Storkcraft Baby Rochester Crib
    Trying to find replacement parts
    Hi, replacement parts can be found on amazon, click here: Amazon com Storkcraft Baby crib parts and take a look. Wish you best of luck. Cheers
    Sep 09, 2008 | Baby Gear
    Side rail
    It is kind of hard. I use my foot. Push in on the bottom of the rail with your foot as you push down on the top. It has to unlatch on each side. Sometimes you have to giggle it.
    Jul 26, 2008 | Storkcraft Baby Rochester Crib
    Storkcraft Baby Cynthia 04550 Crib Logo
    134 people viewed this question
    Top Storkcraft Baby Baby Gear Experts
    paulcarew
    Tom Chichester
    Are you a Storkcraft Baby Baby Gear Expert? Answer questions, earn points and help others
