Question about Brother MFC 7840W Printer
Unable to send or receive faxes. - Brother MFC 7840W Printer
3 Suggested Answers
SOURCE: Cannot Send or Receive Faxes
brother mfc 240c cannot receive fax. it can send fax only.
Posted on Sep 01, 2008
  • 60 Answers
SOURCE: Screen says
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Posted on Feb 04, 2010
Unable to receive faxes. Can send
make sure there is no light burning next to manual or ans hook up!If there is one press the button till they all gone!
Mar 15, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
Able to send faxes but unable to receive faxes.
You probably have to set something up in your settings.
Usually this goes: Settings>Fax Setup>Receive
Of course, this is generic, and all Fax machines are different. Is there a model number?
Jan 15, 2010 | Compaq Office Equipment & Supplies
I am unable to send/ receive any fax. the screen states "sleep, time, MNL".
I am unable to send or receive faxes I do not know whats the problem.
Aug 20, 2009 | Office Equipment & Supplies
Able to send and receive faxes. some numbers
It does not sound as if there is a problem with your machine. The receiving parties may have given you the wrong number to send to.
Call those numbers from a regular phone and listen for fax tones.
Aug 19, 2009 | Minolta bizhub 180 Black and White Copier
Fax not sending or receiving
hear fax can send but fax is recevieing so what is the solution
Jan 19, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Unable to send & receive the Fax
Try calling your fax machine with a cell phone to see if the fax answers. If not, check that the phone wire to the fax is plugged into the LINE socket, NOT THE PHONE SOCKET on the fax machine. Next, go to the MENU on the fax.You may have to check or change one or more of the following settings by trial-and error to fix the problem. BEFORE YOU CHANGE ANY SETTING, WRITE DOWN OR PRINT OUT THE ORIGINAL SETTINGS. In the MENU, find FAX SETTINGS, FAX SET-UP, or INITIAL SETUP settings. Try changing one or more of the following: PULSE/TONE, RECEIVE MODE, SEND MODE, RING DELAY, RING TIME, OVERSEAS MODE, etc.
Nov 26, 2008 | Office Equipment & Supplies
unable to send fax through power line carrier communication. only some part of the document received
Apr 28, 2008 | Brother IntelliFAX 560 Plain Paper Fax
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Doesn't receive from two fax numbers outside the UK
I would suggest there is nothing actually wrong with your machine, as you can indeed receive faxes from other parties. The problem mostly likely lies with the equipment and/or lines of the sending party. One thing you might suggest to them is to turn off ECM (Error Correction Mode) and/or lowering the sending/receiving speed of the machine - preferably the sending speed of the sending party.
Nov 09, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Brother MFC 7840W Printer Logo
181 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
