Our Ricoh Aficio 350 Serial # A7809857354 is making dark streaking lines across the page. Do you know what it might be?
    Guru:
  • 389 Answers
The Problem with developer Unit Ricoh Aficio serieses
On distant the block an проявки "Phoenixes" offen add a little the carrier. But this not defect of the compaction between strictly develop unit and bunker of the toner, but result of the offset to axis of one of the mixers that can be conditioned both defect of the assembly, and careless service apparata.
This is because beside given device much is interesting executed drive of the magnetic gross; besides, anything numbered six mainly косозубые. And that notable, detail of the interfacing the drive of the device and block проявки not podpruzhineny.
So when installing the block (at condition of the mismatch teeth) than with greater power he "pressed" in device, that greater effort is sent on axis. It As a result is mildly displaced mixer, tossing carrier on magnetic gross, and on distant полуоси from body mildly leaves V-figurative compaction, openning road for particles of the carrier, which in this instance execute the role abraziva.
But further - a deal of the technology. Developer gets between bearing of the slide and axis. Since time in bearing is formed hole and appears "drain" developer on distant hlase of sheet the develope unit.
In the event of faulty assembly it is enough careless to install the mixer - and all ready!
The Repair is concluded in change the mixer and two bearings skolizheniya.
"Guerrilla" method consists in additon on axis of the mixer of some soft polymeric material (for instance, polyethylene). Good luck!
Posted on Sep 23, 2009
What causes black streak lines on the entire copy
open the right door and look at the drum, lines on it? If not, its the hot section/fuser. -Carl
Jun 26, 2014 | Ricoh Aficio 2035E Digital Copier. 35cpm...
Ricoh aficio 1027 Printer leaves harsh black streaks on copy
There are three likely causes for your streaks:
1. If they only happen when you put originals in the document feeder to copy or scan, and if the lines stop about 1/8" from either edge of the page, the problem is dirt, correction fluid, or debris on the small glass just to the left of the large platen glass. Clean this strip of glass and your problem will go away. If you can see the Wite-Out or other dirt, just wipe it off with a dry rag... otherwise, clean the glass strip with alcohol.
2. If the marks are solid lines across the page, the problem is the photoconductor unit (PCU). This unit is a whole replaceable all-in-one unit -- replace the PCU and that will fix your problem.
3. If the marks are slightly uneven or if they feel raised, the problem is most likely a scratched or damaged hot roller, in the fusing unit. If this is the case, you'll need to have a service technician replace your hot roller to fix the problem.
Thanks for using FixYa!
Dec 01, 2010 | Ricoh Aficio 1027 All-In-One Laser Printer
Horizontal streaks and smears across whole page. Still does this with lightest setting. Can't read copies at all. Model- ricoh aficio 1018
sounds like the recycling pipe is blocked or cleaning blade has worn out
You need to take the drum unit appart and vac out the recycling coil and clean the cleaning blade.
Nov 21, 2010 | Ricoh Aficio 1018D Copier
I have long yellow streaks on copies.
Hi, Sounds like the yellow PCU is faulty, pressuming the streaks are vertically down the page.
If they are horizontally across the page it is probably another issue.
Nov 02, 2010 | Ricoh Aficio SP C410DN Laser Printer
Aficio 1035 Drum problems
if you clean the drum unit, but the copy is dark push the drum unir forward because the luck is not locked
Feb 07, 2009 | Ricoh Aficio 1035 Copier
Ricoh Aficio CL 2000N printing problems
If the colors are good and solid with no fades, only black streaks, then black is the culprit. I suggest replacing the black cartridge.
Feb 20, 2008 | Ricoh Aficio CL2000N Laser Printer
Streaking
Hi there it will be either the drum unit for the color streaks you are getting or the fuser unit. Check the drum units for the streaks on them also check the fuser but the clue is when you have the streaks in different places. Most likely to be the drum units. You will need to replace.
Thanks J
Oct 30, 2007 | Ricoh Aficio CL7000 Laser Printer
49 people viewed this question
k24674
jasbo
jasbo
