Question about Cell Phones
My mobile phone is not gong have tried charging it and have tried a new battery
My phone switch on and white display and restart it why this problem solution
If you see white screen for a long time and after that your mobile get switch off then I think this is a battery problem. This problem also occurred when your mobile don't have charge and you try to switch on your mobile phone. make sure your mobile phone is properly charged. If you charged your mobile phone regularly and you still not able to switch on your mobile, then try to place new battery in your mobile and then try to start your mobile phone. hope it works for you. Or there may be chance of virus, but I'm not sure. Better you check for it. if your mobile don't support any antivirus then try to scan your mobile with connecting pc. You can connect your mobile phone to pc. And then scan your mobile for virus. If you found any virus then remove it from your mobile. If not found, then definitely its not a virus.Then it is the problem of battery. thanks
May 15, 2011 | Computers & Internet
Tip
IS YOUR MOBILE PHONE IS SAFE TO USE ?
Mobile have become a part in our life as mobile technology is developing day by day new mobiles are arriving in the market day by day
Have you ever checked that is it safe to use ?
Beacuse their are incidents like exploding mobile phone
mobile phone emits radiation etc
a simple mobile phone does not make such severe problems
All the problems are coming from the Battery of the mobile phone
they are responsible for emitting radiation and exploding and also over heating
and not mobile device or not the tower of service provider is emmiting radiation
If you wants to remain healthy Keep the mobile phone away from you and reduce the usage of it
when you talk or send SMS or using internet the mobile will take power from battery and
the battery produce charge with some chemical reaction
so when this chemical reaction takes place it emits radiation which cause cancer etc
Tips to make your phone safe to use
1) Dont talk or use mobile phone when the phone is charging its battery
2) Hold Your phone in hands or keep it inside bag don't put any where else
3) Only Charge your mobile when it shows " LOW BATTERY "
4) dont use mobile if any water particals get inside the phone
5) use only orginal battery
6) Dont over charge your mobile
7) Dont talk more than five mintues in your mobile phone
8) Use the mobile to talk only when the network signal is high else use sms facility to communicate
9) Change the mobile battery as soon as possible if it damaged
10) Use only original charger to charge the battery
11) when you try to remove battery make sure that the phone off
12) if the phone is not using in long time remove battery and keep it safe
13) Dispose the battery safely if its life is over
on Feb 02, 2010 | Cell Phones
I had replaced with a new battery and its just worked for one and form after next days it dont get charged.....the shopkeeper says the mobile is not getting charged.......
In case the battery is not getting charged. It can be due to 3 reasons
1. The power adapter through which you are tryiing to charge the battery is u/s Check with another adapter and see if its charging then the problem is with the charger else.
2. Take out the battery and put it on another phone and try to charge it. If it is charging then the problem is with the mobile charging point and not the battery. If not charging then the problem is with the battery only.
3. Mobile charging point is not working due to which the battery is not charging to check this out just put your battery on another phone and check if its charging. If charging then you are required to get your charging point on your mobile repaired.
Feb 04, 2011 | Motorola Mobility ROKR E8 Cellular Phone
Charging problem
hi :) have your phone has been water damage ?? most after water damage,phone mother board's charging piont will be pro,tat only way u can do,pls send to mobile shop for repair it.
Jul 08, 2010 | Nokia N70 Cellular Phone
Nokia 1112 not charging
Hi 2 ways of gong about this.
It would be better if you take it to your mobile phone supplier. Where you can check a new battery,if the battery is ok then ask for a try with another charger.
If itsnot the above ,then its another fault.Hope i`ve helped.
Dec 09, 2009 | Nokia 1112 Cellular Phone
New cell phone battery trouble
Dont talk or use mobile phone when the phone is charging its battery and charge your mbbile battery for 10 hrs continusly before intinal use Only Charge your mobile when it shows " LOW BATTERY " Dont over charge your mobile Use the mobile to talk only when the network signal is high else use sms facility to communicate Use only original charger to charge the battery
Oct 22, 2009 | Sony Ericsson TM506 Cell Phone
Problem with charging nokia 5800
If your phone was bought in the last 6 months you can go to nokia care center and demand for a new battery and charger or repair the existing ones provided you have the warranty card.You should get it done for free of cost.If 6 months exceeded then
Did u try another charger of the same mobile company,if yes ,and it works ,the problem is with your charger.You can either buy a new charger or get an all battery charger ,a china piece that recharges all batteries of any mobile company.You can get it below 2$ .
If your battery doesn't charge even with other charger of the same company then the problem is with your battery.If you are a nokia user ,here is the price list of all nokia batteries.
http://www.priceindia.in/mobile-phone/nokia-battery/
Sep 17, 2009 | Nokia 5800 XpressMusic Smartphone
We had a new battery it Razr/V3c and the phone is working but try to charged the battery and it say "unable to charged" i need to know why it not working.
hi ... i think your battery charge is gone under minimum limit ... Please try charging your mobile with another battery and try to switch on your mobile and after five min remove the battery, charge with your battery and see whether its charging or wat??
May 30, 2009 | Motorola Mobility RAZR V3c Cellular Phone
I have a T-Mobile dash and cannot get it to charge.
Do you have other phones or chargers? Most Motorola cell phone chargers will fit the dash as will some digital camera chargers.
Apr 07, 2008 | T-Mobile Dash Smartphone
Battery
you have to get you charging port replaced, take the phone to a mobile service center or mobile technician close to you and have them service it for you.
Jan 26, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
