Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Suction of freezer door
Hi, I just have a technical question - How does the suction that occurs when you close the freezer door happen -is an electric sensor involved ?
    President:
  • 704 Answers
No, that perceived suction effect is the magnetic door seals 'grabbing" onto the fridge cabinet and pulling the door(s) shut firmly and securely.
Typically as the fridge gets older, you'll need to clean off both the fridge cabinet edges and the door seals to maintain a proper seal, which is essential to keeping the fridge operating properly.
Hopefully you find this Very Helpful and best regards!
Posted on Sep 23, 2009
Is there any way to increase the section on the freezer door? It is the lower half of a fridge freezer unit.
There is not a suction to bring the door into seal. the closing is done at the hinges. Either the door is warped (twisted), or the door gasket has failed. To check this take a half sheet of paper and close the door on the paper at six inch intervals around the door perimeter. If you can pull out the paper easily at any point the door seal has failed at that point. take a close look at the gasket at the failure point. Is it crushed? if so replace the gasket. If there is a large failure point and the gasket is in good shape the door has been twisted. This can happen if you try to force the door shut with an obstruction inside. I.E. (large Turkey dish). This can usually be corrected by twisting the door back into shape, using the paper to test with.
Sep 18, 2014 | Refrigerators
Electrolux Built in freezer door not closing.
I'm suspecting the door also because of the lack of suction power. you have to check the gasket more. Frost around the door is a great indication of where warm moist air is coming into it.
Aug 14, 2013 | Refrigerators
I have a frigidaire stand up freezer model #lffh21f7hw, and the door isn't vacumn sealing the door, why?
If you have too much weight in the door or someone pulled down in the door, it gets twisted. Try lifting up on the bottom outside corner of the door to straighten it up. You might have to loosen the top hinge to reseat it.
Jan 17, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have problem with m refrigerator door.As soon as I open the door,after closing it,I can not open again.I have to wait 4-5 minutes to poen it again. It seams to be stiked to to the refrigerator.Please...
Is the same thing happening to the freezer? There may be a vacuum being created like a suction cup, in your fridge due to the high quality seal you have... your door becomes hard to open... maybe try closing it slower/softer or place a "small" flat fridge magnet on the TOP of the door where the seal meets it, to allow for a small amount of air to prevent the suction. Good luck!
Jul 24, 2011 | Refrigerators
The freeszer door on my Sub Zero does't have suction anymore
what is the mod num> 650, 700? no a lot help. check the freeze inside the upper part for any ice build up
Apr 02, 2010 | Sub-Zero Bottom Freezer Refrigerator
Freezer whistles after closing door; new sound after a freon rech
yes sir,your unit is working well right now, at this stage, freezer section is already at the peak of its performance, it creates suction motion as you close the door (frzr). with this, sometimes you can hear whistling sound or most of the time.it is only a sign that the cooling system is working well.as the temperature goes down it happens, to see it, watch the gasket how it behaves during that moment sir.there is a suction sound.blower is also in suction motion because it diverts airflow going to ref section thus creating this behaviour on the gasket and the door as a whole, dont worry sir that is normal, or try to clean the tip of the gasket to reduce the slipping sound.
Mar 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Why does the door stick if opened,closed and reopened
Hi, what I think your referring to is "suction". If you open the door and then close it when finished but then you decide you want to open it again and it is really tight or "seems" stuck, that is normal and I'll explain why. It's all related to the second law of thermodynamics which states "hot will always migrate to cold" or at least that's the jist of it, we'll keep it light for this lesson, and NO there won't be a test tomorrow lol. What takes place when the door is opened is this. The warmer ambient air which is at room temperature rushes into the fridge, (actually migrating to the freezer/evaporator) and pushes all the cool air out. When the door is then closed a vacuum or suction if you prefer is created via the warm air in the unit being "pulled" to the freezer. This action usually only last's several second's, hence the door will open easy again shortly there-after. Sometimes if you listen closely you can actually hear a slight whistle or whoosh sound from this action occuring, it's actually pretty COOL...pun intended lol. Hope that help's, let me know please. I should also add if the door is just simply opening when at rest or when it shouldn't, check the seal and magnet around the door perimeter. The magnet is just there to insure a good seal,(contrary to some believing it should "pull" the door closed...nope. I mean it will to a small degree, but it just help's keep it closed and insure it seals) but should be in contact with the cabinet perimeter around each section. Good luck. macmarkus :)
Nov 21, 2009 | Whirlpool GD5SHAX Side by Side...
Freezer doors opens slitghly every time we open the fridge. The suction for the freezer seems too low to keep it closed firmly.
Hi thanks for the question. tilt the fridge back . Unscrew the legs, so that the fridge is now higher . this will make the doors heavier . and will close better . thanks the appliance doc
Oct 06, 2008 | Maytag Refrigerators
Refrigerator suction/vacuum noise, rear section when freezer door is closed
there is no suction system. flush your defrost drain tube with boiling water and a turkey baster. should get some pretty nasty sludge out and sound will go away.
Dec 28, 2007 | Whirlpool GS6SHAXMQ Side by Side...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
685 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
