Question about Microsoft Xbox 360 Console
Xbox keep turning off power cord light turns red
The problem is your power supply is overheating you just have to keep it in a area that is cooler or has less heat . the best bet would be turn off your xbox let thepower supply cool down and then turn it back on . you might need a replacement the same thing happend to me
Posted on Sep 23, 2009
Xbox consol has red ring only 3 lines not full ring
This could be a mjor problem.. Kindly Check this picture here for reference..
Or, you could try doing there simple troubleshooting steps:
  1. Restart the console.
  2. If this did not work, there could be a loose cord or cable. First, any cables and power cords that can be removed should be disconnected. Unplug the power cable from the wall plug. Firmly reattach all cables and cords back into the console. Now connect up the power and turn on the console.
  3. If the above step didn't work, then try turning off the console, unplugging the power and then disconnecting the hard drive. Now plug into the power and turn the console back on. If console does not show the three red lights error, turn it off and disconnect the power cord from the wall. Finally, reconnect the hard drive, plug in the power, and turn on the console.
  4. If you are using a defective surge protector, plug strip, or extension cord, your xbox may not be getting adequate power. Try plugging the power brick directly into the wall. This sort of thing happens more often than you might think. My DSL connection used to be very unreliable until I bypassed my surge protector and plugged my modem directly into the wall. I should have done this in the first place rather than making a lot of angry (and useless) phone calls to my internet service provider.
  5. If you think that your machine has overheated, then turn it off and let it cool down. Ensure that the cooling vents are not blocked in any way and keep your Xbox 360 in a ventilated and open area.
    Do not place near it any sources of heat. There are obvious sources like heaters and radiators and such. But less obvious sources include the electrical devices that are sitting on top or beneath your xbox.
    Try removing any dust buildup inside the machine.
    Cool off your console with a small fan.
    Don't forget to keep the power brick cool, so keep it off of shaggy carpeting. Better still, place it on an elevated surface. You can even hang the power brick by its cord off of a hook.
    Keep the rear of the console clear. Don't push it up against a wall and keep any debris away. This includes not allowing any cords and cables to get all bunched up in this area.
    Don't do any all day gaming marathons. Limit your gaming to just a few hours, then turn it off and let it cool down for a while. The warmer the room temperature is the shorter your playing time should be.
if all else fails, consider of having your XBOX repaired by a local tech or the nearest XBOX service center. this could be a little expensive but a quicker option..
Mar 16, 2011 | Microsoft Xbox 360 Console
I have a red light on my xbox and it told me to look for consumer support. what do i do
How many lights are blinking??
Two blinking red light's on the power button means that your console has insufficient ventilation. The red light will continue flashing until the console cools down.
Let your console cool
  1. Turn off your console.
  2. Let your console cool for one hour.
  3. Turn your console back on.
If the solution worked, your power button should be green.
If your power supply cords are not plugged in securely, you may see one flashing red light when you turn on your Xbox 360 console.
Check out this site and follow along according to the symptoms face by the xbox360.
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/flashing-lights-wizard.aspx
Feb 11, 2011 | Computers & Internet
My xbox had the 1 red ring (e74) but now has 3 red rings. We repaired the x clamps but now when we turn it on, the light on the power cord turns green but then goes back to orange even though it's on. We...
only known fix for the three rings is to send it in to microsoft for a new after they have examined it to make sure it has not been tampered with or other means of voiding the warranty
Mar 30, 2010 | Microsoft Xbox 360 Console
Xbox won't power up, orange light is on the power brick
Are you using a plug and play kit? if so disconnect it, mine does that sometimes, if thats not the case comment me,I would write them all down but I am getting a bit fed up with writing lots of solutions to problems and getting no response from the person I give the time to help.
Feb 13, 2010 | Microsoft Xbox 360 Console
Power brick colour
Alright, lets fix this!
 Xbox 360 power supply light is orange or yellow.
Usually when the Xbox 360 power supply light is orange it's on standby so there is no problem with your Xbox 360 console but the power supply can't supply it with power !
First you have to try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for a minute then reconnect it all back , also try it on another wall outlet without any extension cords at all.
If it's still doing the same it will be definitely a fault with the Xbox 360 power supply.
So, in this case please contact Xbox 360 customer support to fulfill the Xbox 360 power supply.
Xbox 360 power supply light is red.
There is something wrong with the Xbox 360 power supply connection so try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for minute then reconnect it all back , also try it on another wall outlet without any extension cord at all.
If it's still red that would be for sure a fault with the Xbox 360 power supply .
So, then contact Xbox 360 customer support to fulfill your Xbox 360 power supply .
You can also find replacement power cords many places online. See if you can get your hands on another cord and try that to see if its the current power cord.
Hope this helps you out! Please don't forget to rate :)
Apr 10, 2009 | Microsoft Xbox 360 Console
Red Light on Plug in connecter thing
Sounds like there is something wrong with the Xbox 360 power supply, try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord. Give it a minute then reconnect it all back, also try it on another wall outlet without any extension cord at all.
If it's still red that suggests fault with your Xbox 360 power supply so will need to contact Xbox 360 customer support if its under warranty they should be able to sort it out for you. If out of warranty it might cost you for a new power supply!
Dec 13, 2008 | Microsoft Xbox 360 Console
I have an xbox 360 which is defaulted wen i turn on instead og green light there is a red light too.
turn off xbox, unplug the av cord from back of xbox.. power up unit without av cord.. wait til unit shuts off by itself.. reattach the av cord and turn it on..
Jun 30, 2008 | Video Game Consoles & Games
My xbox 360 has one flashing red light, and it keeps showing me the code E 74
Jun 29, 2008 | Video Game Consoles & Games
My xbox 360 power cord box messed up....
check your Audio/Video cable connection, sometimes those lights means that the plug isn't in the xbox/tv all the way
Jan 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
101 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
