Question about Campbell Hausfeld 26 - Gallon Air Compressor
Hitachi twin chamber/MDR 21 Pressure switch
110vac Starts and fills fine. as soon as pressure release stopps releasing the motor trys to start.I adjusted the Main calibration nuts out
to cut out at a much lower setting like 40psi. Still does it trys to start then trips my 15 amp breaker. Is this an indication that the windings are possible cause. I did find the load side wires (motor) were very lose
on the pressure switch. For how long I have no idea. I fixed that problem.
  • 1 more comment
  • albrightrona Sep 23, 2009
    The motor stops then trys to restart
    Yes it bleeds off.
    sorry about the rating ill fix that
    President:
  • 1,167 Answers
Buddy what do you mean when the compressor bleeds off the air the motor wants to keep going
Posted on Sep 23, 2009
Testimonial: "Thank you thought i might have to replace motor"
  • 2 more comments
  • ollie reece-jones
    ollie reece-jones Sep 23, 2009
    buddy what ya doing i asked a question dont give me a rating yet i need more info to help you
  • ollie reece-jones
    does the air bleed off as i dont understand when you said it tries to to restart
  • ollie reece-jones
    hi buddy this is a faulty pressure switch the pressure switch controlles the on and off its either the pressure switch is sticking or the terms are weak buy these off ebay cheap hope this helped buddy
  • ollie reece-jones
    thanks buddy my dad has been working on these machines for 30 years i have been for 10 so any more questions get back to me buddy im here to help
I switch the pressure washer on motor starts pressure builds up motor stops. OK pull the trigger on the lance the moter starts sounds different water pressure low. Release trigger motor still runs.
It isnt very clear your explanation of the problem but what type washer do you have first? It sounds like you have a bad unloader or need a new variable nozzle tip. Can you explain in more clear detail. Thanks
Feb 16, 2015 | Garden
EC89 HARD TRIPS RESET ON COLD STARTS.SOMETIMES WONT FILL AT ALL.WHEN IT DOES WILL NOT FILL PAST 50PSI
Several things to check. Check amp draw with meter to make sure that the reset is not bad. It amp meter is showing low amp draw when it trips, then replace reset. If reset is good check condition of the cold start valve. The valve will not allow pressure to build until motor is at full rpm and the pump is making good pressure/volume. If cold start valve does not close, check pump for leaking or broken reed valves. If cold start valve is good, check the capacitor for at least 10 percent of rated valve. Low pressure /volume is usually leaks from tubing or leaking /broken reed valves or burned gaskets in the head of the pump. Finally, make sure that the check valve or non-return valve is not leaking pressure from the tank causing back pressure. Good luck
Mar 23, 2014 | Hitachi EC89 4 Gallon Twin Stack Air...
I have a whirlpool ultimate care II that won't fill with water it just starts agitating. Sometimes if you hold the load size switch in between load sizes it will start filling but you have to hold the...
The problem is quiet obvious and it is the water level pressure switch behind and connected to the load size switch knob. The pressure switch is stuck in the full position that's why the machine doesn't fill and it goes directly to agitate. Holding the load size switch in between load sizes releases the contacts from full position and allow the machine to fill as long as the switch is held on.
Disconnect power then release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Behind and connected to the load size switch under the console is the water level pressure switch with a clear hose attached to it.
Remove the pressure hose from the pressure switch then reinstall the console and reconnect power. Start The pressBlow air forcefully into the pressure swic
Feb 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
The overload keeps tripping
I have had a Hitachi EC89 compressor for a couple years now. As an Mechanical Engineer with a minor in Electrical, I observe that the motor assembly/capacitor is undersized for the mechanical energy it is asked to produce upon start up. The motor consistently struggles to get up to speed, requiring too much electrical current and then the breaker pops, and you're back to time zero. And the cycle repeats. In other words, the fundamental EC89 design stinks and it should not have been released onto the market in this way. I replaced the capacitor on mine with a more robust G.E. version and it has improved, but fundamentally, there are not enough motor windings to get the system going good & strong, each and every time. Shame on you, Hitachi.
Feb 08, 2011 | Hitachi EC89 4 Gallon Twin Stack Air...
Why does my compreeor switch release the air after reaching the required pressure instead of holding the air at the required pressure??? I've just purchased and fitted a new automatic cut off switch to my...
There are two valves in play here. There is a relief valve that opens when the motor kicks off to release the pressure in the compressor itself. That is normal, and is required so that the motor can restart next time without having to overcome that pressure. The other valve is the problem. It is a reed valve between the compressor and the tank. This valve's job is to prevent the air in the tank from returning to the compressor. Think of it as a ratchet for the air. It is this reed valve that has failed.
May 27, 2010 | Northern Industrial 2 Hp Twin Tank...
Keeps on cycling on and of when not in use?
I believe you have a faulty pressure switch. The black hose reports to the switch what the pressure is and either starts or stops the compressor through the switch. Air is bleeding out of the hose ...causing short cycling ... for some reason. Fix the leak - fix your problem
Thanks for using FixYa.com
positive comments always welcome
a
Oct 27, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi ec12 motor hums after drop in pressue
There should be a pressure switch adjustment under the cover of the switch remove the cover and reset.
Feb 03, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Air leakage through pressure switch needle
1)Let your unit pump up.
2)Turn it off.
3)Find the supply line from the pump to the tank.
4)Remove the supply line from the pump head.
5a)If you hear air coming from the tank you have a bad check valve.
5b)If you do not hear air coming from the tank, you have a leaky
pressure switch.
Feb 02, 2009 | Campbell Hausfeld 26 - Gallon Air...
Whirlpool Washer Completes 1 Cycle then won't fill
Sounds like you have sticking water level switch, due to possible blockage in the pressure chamber or pressure chamber hose..
You need to check the pressure chamber and the small hose that is attached to it for a blockage,. This problem will cause all of the symptoms you have described.. When it is stood for a while that is why it will work, the pressure releases and the switch will work until the pressure builds up and then it sticks again. The pressure chamber hose goes up to the water level switch
Please rate this solution
Dec 15, 2008 | Whirlpool LSR8233J
Start up problem
The problem that you describe is caused by the in-tank check valve and/ or the unloader at the pressure switch. When the compressor cycles off the pressure switch releases the air that remains in the air line thru a small valve. There is a 1/4 " plastic tube extending from the check valve to the switch. Listen for the release of air as soon as the compressor stops. There is a small metal tab that pushes on the unloader valve that may need to be adjusted. The motor does not have enough power to start pumping if there is air/backpressure in the air line. If these parts are working correctly then check the value of the start capacitor and use meter to measure. The cap should test within 95 % of stated value. Parts are available at www.chpower.com. Enjoy
Dec 12, 2008 | Campbell Hausfeld 26 - Gallon Air...
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
138 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
