Question about Alpine IVA-D310 Car DVD Player
Not powering up
When turning on my ignition the screen comes out but stereo doesnt come on any suggestions?
  • 1 more comment
  • cossie dave Dec 17, 2007
    no the stereo doesnt power up at all all that happens when i turn ignition on is the screen comes out and when i press source nothing happens
  • Anonymous May 26, 2008
    the radio has power but the screen will not work
  • mjbradley198 Oct 04, 2008
    My unit flips out but then nothing happens for a good 2 minutes then it turns on and there is just a frozen screen i can't do anything, such as volume, change menu's, and etc
    Scholar:
  • 143 Answers
Do you loose your presets everytime?
Posted on Dec 15, 2007
Radio wont turn off when engine is turned off
does it turn off with ignition off and open one of your doors? my98 blazers radio doesnt turn off until ignition is in off position & one of my doors are opened or hold power off button on stereo regaurdless of ignition position or doors open.if niether of those will work to turn off your stereo you acc power is connected to a direct power lead connect it too a power lead that turns off with key in off position.
Aug 09, 2014 | 1999 GMC Jimmy
Car stereo comes on with lights
The only thing I can suggest is,the person who installed the stereo must have hooked up the main power wire to the light fuse in the fuse panel.
Mar 07, 2014 | JVC AM FM CD DET FACE CAR STEREO
I replaced my ignition switch in my 98 k2 jetta and after my stereo won't turn on but will eject cds and insert them?
The red wire from the stereo is 12v signal, basically when you turn the key on it send 12v to the red wire to make your stereo come on. Everything else is fine since you can insert and eject cds. You may have pulled the signal wire loose when you changed the ignition switch, check the wires behind the radio and the wires to the ignition switch.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Bosch 1998 Volkswagen Jetta K2 2.0L...
Car stereo not working,, could be in safe mode ?
Sorry to tell you this needs to have the code reset once you remove the battery the stereo needs to be reset only a garage can do that there is no doubt about it. Hope this helps Best wishes, Malcolm Campbell.
May 09, 2017 | Vauxhall Cars & Trucks
Amplifier doesnt cut off with car, battery dies every time
I assume you are speaking of the car battery, and it gets drained when the ignition is turned off.
Your problem is you have connected your system to the wrong power connection. Automobiles have wiring lines that supply power all the time, to other parts of your vehicle. You need to find a power connection, preferably from your fuse box, that stops supplying power when the ignition is turned off. This will also help provide a back-up fuse incase of any other problems you might incur.
Sep 09, 2009 | Dual TOA IP-600D Channel, 400W Power...
When I replaced the stereo in my daughter's car I lost power to the Ignition. I still have dash lights. But no power at the stereo and the car will not turn over. Also the keyless entry stoped working. How...
car stereo that come with car is program to car pcm security system.when you change stereo.the pcm dont recognize the new stereo.the pcm goes into anti theft mode it disable ignition.system.
May 17, 2009 | 1999 Saturn SL
My in-dash won't come on
yellow lead on car stereo should be going to a permanent live on car stereo wiring loom, (always 12 volts regardless of key being in or out) red lead on car stereo should be going to aux in car stereo wiring loom, (12 volts only when key in and ignition lights on) green lead on car stereo goes to earth to allow you to watch dvds whilst driving (highly illigal whilst driving!) read the manual, if this doesnt work fuse in car possibly gone?
May 10, 2009 | Car Audio & Video
Unit doesnt turn on
well let me noe if ur throwing it cause i can use the face mines broke off my little cousin... email me Emoney-cashflow@yahoo.com thanks...
Mar 30, 2009 | Alpine IVA-D310 Car DVD Player
Problem with aftermarket stereo wireing
seriously the answer is very easy the yellow wire from the deck is constant power weather the truck is on or off it should always be hot. The red is the ignition wire which simply turns the deck on when the ignition key is turned on and the black is ground besides the actual speaker wires these are the only wires that need to be connected. if they are properly connect there is a good chance that there is a short somewhere
Mar 16, 2009 | 2006 Ford F-150
Alpine IVA-D310 Car DVD Player Logo
50 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
