Question about Dishwashers
BEKO DE2541FS dishwasher - starts up, sounds like it's taking in water but then doesn't run through the cycle.
  • nwatson74 Sep 23, 2009
    Thank you - it's brand new - switched it on, starts up, found out it's not actually taking in any water, just sounds like it's starting up the cycle, then just sits with wash indicator light on not progressing through the program, nor taking in any water. Gone through all the correct stages of the 'starting - up' manual but no joy.
  • 909 Answers
Most modern washers dont have pressure switches but a water pulsating module which sences how much water that goes in the chamber. If the pulsator does not function correctly(assuming the water pressure is correct) ,then it wont send the correct water input signal to the processor.Could be a few other reasons, but info given is limited.
Posted on Sep 23, 2009
  • Terence Fourie
    Terence Fourie Sep 23, 2009
    Most modern washers dont have pressure switches but a water pulsating module which sences how much water that goes in the chamber. If the pulsator does not function correctly(assuming the water pressure is correct) ,then it wont send the correct water input signal to the processor(Hence, motor wont start.).Could be a few other reasons, but info given is limited.
Beko dishwasher doesn always fill with water but makes sounds as if it does. Other times it works great any ideas?
depending on chosen wash cycle washers are not always supposed to 'fill' just use enough for that cycle .
If you mean sometimes no water at all and sometimes water with same settings check hoses and valves .
make sure valves are fully open hoses securely attached and hoses from valves to washer are not pinched twisted or damaged.
Hopefully the water not getting in the washer isn't leaking all over your floor below the washer.
Jul 18, 2016 | Beko Dishwashers
I have a Beko DE 2541F Slimline Dishwasher and it fills and empties the water but the cycle does not start. The water does not get to the spray arms. I have tried on pre wash cycle as well so I do not...
If there are no problems of drain valve stuck, then the problem with the micro controller board.
When the water is full in the tank, the wash cycle will start with the spray arm in action. Lastly block the drain hose and see. Here water full will be detected & the machine will start if the level sensor is OK .
If m/c works here, you have to check the Solinoid valve of the drain.
Otherwise the micro controller.
For this pl take the help of the service provider as lot of programming versions are there. Some may suit or may not. If we try the will not accept after selling the board to u.
Apr 07, 2010 | Beko 24 in. D3731F Free-standing...
Beko dwd4310 not running
Hi Kirsty did you solve this? I have the same problem.
Jul 22, 2009 | Dishwashers
Hot & Cold Water connection - can I connect just to cold?
Yes it may take a little longer to process a cycle but yes all new machines are cold feed only now.
Jul 22, 2009 | Beko 24 in. D3731F Free-standing...
Beko dishwasher wont start it comes on wont fill up
hi there...have you checked the water supply to the dishwasher.......sounds either no water to the appliance or a faulty water inlet valve to the appliance
regards Sir Galahad
May 15, 2009 | Beko 24 in. D3421F Free-standing...
Brand new dishwasher, doesn't drain water and will not work now!
hi,
try this site
http://www.cookshomeappliance.com/dishwasher_troubeshooting.htm#Constant Noise During Washing or Drying
please rate my suggestion..
Apr 11, 2009 | Beko Dishwashers
Beko washing machine fills with water when not in use!!
hi there.....you got a faulty water inlet valve on the machine ..change this and all will be fine again...
regards Sir Galahad
Dec 05, 2008 | Beko 24 in. D3421F Free-standing...
Beko 2431 dishwasher not working
dishwasher seems to try to wash but not get anywhere.
have tried tipping dishwasher to empty excess water out, filters and arms cleaned.
dishwasher just takes in water, hums for a bit and then the cycle ends after about 20 mins but obviously dishes are not clean
Jun 05, 2008 | Beko 24 in. D3421F Free-standing...
Beko DE 3762F
Dave, Could you provide more details ? - Does it drain out water at the beginning of the cycle? - Does it fill with water ?
Aug 07, 2007 | Beko 24 in. D3421F Free-standing...
Dishwashers Logo
278 people viewed this question
Top Dishwashers Experts
