Question about Saeco Incanto Classic Espresso Machine
Grinder will not stop
The grinder keeps going. The only way to stop it is to turn off the power. When the problem first started I could turn the power back on and it would then make coffee. Now the grinder just continues until the light showing no coffee lights up. Of course there are plenty of coffee beans in the holder.
It has been back to the Saeco distributor 3 times to fix. He blamed it on the coffee I am buying. However the problem persists even though I am buying the coffee from Saeco now.
Help!!!!
    Sergeant:
  • Saeco Expert
  • 223 Answers
Try these grinder cleaning instructions.
http://www.cerinicoffee.com/custompages/Tech/Grinder_Adjustments_for_Italia.pdf
Great espresso Beans for superautomatics try:
http://cerinicoffee.com/Espresso_Coffee_Beans.asp
Posted on Dec 19, 2007
When i turn on the grinder the grinded coffee keeps going on.What should I do?
they usually keep grinding until the compartment with the grinded coffee gets full or until you turn off grinder. should turn off after compartment reaches full state.
Jun 25, 2016 | Mazzer Coffee-grinder SUPER JOLLY Electric
Krups burr coffee grinder - When I push the power button it flashes on briefly and then stops. It has briefly ground some beans so it working to some extent. Any ideas what is causing the grinder to...
Empty the grinder and see if it will run with no coffee bean in it. Some times debris will get caught in the grinder because it got mixed with the beans from the factory. If it runs your good to go. If not then the mother connection are not solid and it will run off and on at will.
Oct 14, 2013 | Krups Burr Coffee Grinder
I have a dewalt dw818 angle grinder when i press the trigger it starts spinning but if i tilt the grinder a little it stops spinning done the brushes already help please
Check your power cord. Turn the grinder on, then pull and twist the power cord, especially by the boot coming out of the grinder. If there's a break in the line, it's possible for it to work in some positions but it will die if you change the orientation of the cord to the tool.
Jul 21, 2012 | Heavy Duty Dewalt Dw818 Heavyduty 412"...
Saeco Primea Cappuccino must be reset I recive error mesage : error 1 I replaced grinder with a new one but the error message remained on screen and do not know how to reset
Hi,Ive just recieved an email saying that your having some problems with your machine. Its hard to keep up with all the error codes on the hundreds of machines on the market. Faulty grinder usually dont give an error code. The grinder will just not work if its faulty, which tells me theres a problem with grinder. If your showing an error 1, i'd be looking at the steam heating circuit. Faulty thermoblock, thermostat, solenoid, etc. Anyway, something has led you to replacing the grinder, so ill see if I can help. Some machines need to be told that it has been fixed, which is done through the programming. You know when you go in to the cleaning program, thats where it may have to be told. The grinder also has other electrical sensors which maybe at fault. On one of the wires that connect to the grinder is a little square thing that sits in a holder on the grinder. It maybe faulty.(not common fault that part). The machine will usually reset itself when you turn it off at the main toggel switch, and unplug it from the power point. When you turn the machine back on, it will do a self dianostic before it starts to heat. but as I said before, the grinder usually isn't part of the self dionostic on start up. If you turn it back on and error code comes back up, id be looking at thermoblocks or thermostats. If your still having troubles, give me more details on how the machines full operation is working. If the grinder is at fault, everything else should be working. Thanks Darryn
Oct 08, 2011 | Saeco Primea Cappuccino Touch Plus Coffee...
My ryobie bench grinder keeps tripping the rcd within a second of turning it on?
Assuming your local tech confirms that your bench grinder tests ok. The problem is probably that the grinder draws too much current for the RCD and is therefore detected as an earth leakage. High amperage devices often do that. Your best bet would be to plug it in to a socket which is on a non-rcd circuit. Maybe you have an RCD on the whole house though? I would start with returning the grinder and trying a different brand with a lower amperage/wattage rating. If that doesnt work, I would call an electrician to discuss installing a different RCD or running a separate circuit for your power tools.
Mar 03, 2011 | Jet Industrial Bench Grinder 6in new
Espresso coffee grinder stopped working
many grinders have resetable termic fuse, some of them require manual reset, so you should search for termic fuse attached to body of motor(open the grinder from below) usualy they are round black termofuses with red reset button.
usualy this happenes when we have loud music and we dont hear that grinder is on and he works long time.
Mar 28, 2009 | Isomac Gran Maccinino Espresso Coffee...
Grinder starts and stops on startup
if this is a cap start motor and not a centrifugal start run motor then bad cap is good place to start
Nov 25, 2008 | Wilton 17202 8" Bench Grinder
Saeco odea go
Try to use another brand and more dry coffee.
Apr 10, 2008 | Saeco Odea Go
Saeco Incanto Classic Espresso Machine Logo
155 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
