Question about Kenmore 47772/47774/47779 Electric Double Oven
Oven locked and I don't know how to unlock
I was not cleaning the oven. I simply pressed clear and it locked. How do I unlock it? I do not have a manual
  • Anonymous Jan 05, 2008
    oven locked to clean, I pressed broil, not clean, how do I open, my roast is in there!
  • Anonymous Jul 19, 2008
    i Get F 7 and the oven switches are not working. How to unlock it. This is a Kenmore double oven
    Scholar:
  • 196 Answers
To unlock the oven. Switch the beaker off for 5 minutes. This will reset the integrated system. Turn the unit back on and if it doesn't unlock, set the unit for self clean and let it engage. Waite about one minute and cancel the self clean cycle. This should unlock the door(s).
Posted on Jan 26, 2008
I don't know the model # but its a kenmore oven and my daughter left her finger on the stop button too long and so the oven door automatically locked us out. I can't find the book for it
According to the eHow website,
"press and hold the stop/clear button for 3 seconds to unlock the door."
(it's the same to lock the door in the first place.)
According to the Just Answer website, either press and hold the stop/clear button for 3 seconds or 5 seconds, (A beep will sound. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked and the lock icon light has cleared.) or you have to press the button 3 times quickly.
Sep 25, 2012 | Kenmore Ovens
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    We used the self cleaning option and now we cannot get the oven door open. The lever is stuck in lock mode. Can you give suggestion?
    Thank you and thanks for using fixya
    Sep 29, 2010 | Jenn-Air JGW8130A Electric Single Oven
    How do we unlock the oven door! Accidentally pushed a button in front. We have no manual or SS#. Oven was in house when we bought it. We unplugged it to turn off and was able to open the door. Please...
    The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can un-lock (safety feature).
    Good luck with this!!
    Aug 18, 2010 | GE Profile JTP18 Electric Single Oven
    After self-clean cycle oven door won't unlock
    your lach might have given out on self clean. change it
    Feb 12, 2010 | GE Profile JTP18 Electric Single Oven
    The lock on self cleaning oven door will not release
    Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
    Jul 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Oven does not work
    According to the manual, the self cleaning latch could be stuck.
    If the oven door is open, press STOP/CLEAR to clear display, then depress and hold switch plunger for 6 seconds (Located in the upper right corner of the oven front) and the oven door will unlock.
    If the oven door is locked, press STOP/CLEAR to clear the display then apply pressure to the upper right corner of the oven door and the door will unlock. If the "F" code reappears, contact a Sears trained repair specialist.
    Sep 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Door Keeps Locking and Unlocking after Power Outage
    Located the switch - resetting fixed my stove as well.
    Dec 17, 2007 | GE Profile JTP18 Electric Single Oven
    Kenmore 47772/47774/47779 Electric Double Oven Logo
    431 people viewed this question
    Top Kenmore Ovens Experts
    Marvin
    Marvin
    Are you a Kenmore Oven Expert? Answer questions, earn points and help others
