Question about Xerox Phaser 8500/DN Printer
Xerox XRX 951L Laminator The carrier is not feeding through the machine
3 Suggested Answers
SOURCE: the lamination paper is stuck.
pop it open take the top wheel off and finagle the paper out with a flathead then reassemble
Posted on Aug 15, 2008
you need to use the carrier (cardboard cover) that the lamination paper comes with.. if you dont use the carrier your plastic will stick to the hot rollers... you will need to take it apart and clean out the plastic.. easy to dow hen it is cold peels off easily... pain in the neck getting it back together as the wires in the front interfere with the front screw post...
Posted on Jan 15, 2009
Why is my GBC Ultima laminator beeping?
It will beep when you turn it on to acknowledge power. It will also beep when it reaches ready condition. Your laminator has safety switches for the lower feed tray and upper heat shield. Any time the upper shield is lifted the power is shut off. When you lower it down the power is turned back on, causing a beep. The same is true for the lower feed table. When it is removed and then re installed the machine beeps. These are safety features so that the laminator doesn't turn on when you are reloading it or unjamming it. Check that the safety switches are fully engaged if you get unnecessary beeping.
Oct 25, 2016 | Gbc Office Equipment & Supplies
I have a xerox laminator and it will not feed
Unplug the machine. Then try to look, using a flashlight, if there are any obstacles that may interfere with the feeding. try to gently tilt the machine and try to remove any obstructions. If you can't see anything, try to force something through the feeding path and see if something is stuck in there.
If this doesn't work, them you might want to take it apart.
Nov 16, 2012 | Xerox Staples XRX-LM1910 Laminating...
How doses the plastic feed through the xrx lm1910 laminator
You will need to make sure that you are using the right type of plastic. also, is the plastic the right size? Also, you need to check if you are trying to feed at all. Are you able to feed the paper?
Jun 08, 2012 | Xerox Staples XRX-LM1910 Laminating...
The unit was heated up and when I insert the laminator pouch with the document to be laminated it does not feed. it just cooks the front edge of the pouch. do I need to let the unit cool and start...
Hi, there's a seperate switch for the moter on my laminator. After the device is heated up you need to turn on the switch, so the mechanism starts to pull in the pouch.
Mar 14, 2011 | Xerox Staples XRX LM1910 Laminator
How do I obtain more Xerox return labels in order to return used toners? We're a central supply warehouse which receives used toners; the individuals who used the toners have not always saved the labels...
Hi!
Have you tried this option from Xerox?
Green Boxes, it seems like you order boxes for free from xerox to send back used toner cartridges.
This is the website:
http://www.xerox.com/perl-bin/product.pl?mode=recycling&referer=xrx/enus.html#
Take care!
Feb 28, 2011 | Office Equipment & Supplies
The sheet im laminating rolled up inside, cannot get it out
Water-based cleaners will not work with this type of adhesive. Rubbing alcohol or a citrus-based cleaner (eg, Goo-Gone) will be required.
Feb 22, 2011 | Xerox Staples XRX LM1910 Laminator
I have a Lamiart-3201 laminator and the rollers are not working - or i cannot feed my item through the laminator. Usually I just put it in and the laminator feeds it out the other end...
Make sure your laminator is heated up properly before feeding material through. Usually, for a low-end laminator, you will wait anywhere between 10 to 20 minutes before it is completely heated up, allowing you to use it. There should be a red button that will tell you it is NOT ready yet, and a green button will tell you it is.
Nov 16, 2010 | Office Equipment & Supplies
The lamination paper is stuck. never went thru the other side. How do I open it and un jam it? Please help ITS THE XEROX XRX-951L laminator. I couldn't find t n your list
May 26, 2008 | Xerox Phaser 8500/DN Printer
Flashing 4h
http://www.xerox.com/xrx-search/MainSearchServlet?Xcntry=USA&Xlang=en_US&hostName=http%3A%2F%2Fwww.xerox.com%2F&gateway=%2Fgo%2Fxrx&searchString=H+codes&Search.x=0&Search.y=0&Search=Search http://www.support.xerox.com/go/prodselect.asp?Xlang=en_US&metrics=HDR These 2 sites should guide you in the right direction. Good luck, Tim
Mar 06, 2007 | Xerox WorkCentre XD130DF Laser Printer
Xerox Phaser  8500/DN Printer Logo
649 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
