Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
It appears that the overload keeps tripping on the compressor
Fan runs, condenser coils vaccumed (they were pretty dirty), evap coils not iced up, how long does it take to reset the overload? I can here it clicking...
I would imagine this is something we do not want to bypass.
  • Whirlpool Master
  • 909 Answers
Almost certainly the compressor sounds to be faulty. That alarm is possibly the warning that the temp. is not correst. I would switch the system off for approx. 1 hour then retry. if it starts to clck again then it proves the compressor is faulty.
Posted on Sep 23, 2009
Refrigerator wont get cold
If compressor is running check and make sure your cond. fan and evap fan are running. Also check in freezer and make sure evap. coil is not covered in ice. Also clean your condenser coil. You could be low on refrigerant. There are quite a few things to check.
Nov 01, 2012 | Frigidaire Refrigerators
True gdm 26 no longer cooling. Internal tem 80 degrees, Condensor fans running, Coil is not showing any frost or icing. Removed cover and cleaned coil and removed dust and dirt. Went out "all of a...
sounds like the compressor is not running. The condenser fans are located at the compressor. The fans in the conditioned space are the evap fans. A refrig usually does not have any device controlling the evap fans, they are to run 24/7. Freezers have other controls. Start there and let me know if I can help further.
Nov 20, 2010 | True GDM-26 Refrigerator
Compressor temp overload trips and eventually trips circut breaker
Could be several issues causing this problem. Let's start with some basic observations.
Is the condenser fan running?
Is the condenser coil dirty? (Not only the outside but all the way through the coil. Check by looking for light coming through coil. You can even try shining a flashlight through the coil to see if it is clean.)
If the fan is running and the coil is not plugged up or covered with dirt, or other obstructions (air is freely able to move through the coil), then it could be an issue with the system being over charged.
Another possibility (but not highly likely) is there may be non-condensables in the refrigerant system. Usually these will only be present if the system was recently serviced or charged and air and moisture was allowed to enter the refrigerant system (piping).
More information is required to try and diagnose this further.
Sep 04, 2010 | Frigidaire Heating & Cooling
Compressor kicks off on overload/relay. Even after replaceing overload/relay and cap. It will run ok for a week if you let it cool down.
This is often found in small compressors when they heat up too much or too often. check to be sure the condenser coil is clear and has good airflow. If so and it still trips on overload then the compressor is bad. Hope this helps. Good luck.
Mar 23, 2010 | Amana ARB8057CSR Bottom Freezer...
Motor is hot?
Which motor is hot...compressor or fan?
Also need to know the model number.
Is this a 3-phase or single-phase unit?
Let's assume it is the compressor...Is it so hot that you can't touch it for more than a second or two? Is the compressor shutting down on internal thermal overload?
Compressor body hot can be caused by a number of things:
1. Low charge (the freon acts as a coolant for the compressor).
2. Electrical imbalance (3-phase only). (check line-to-line voltages)
3. Bearings in compressor failing (check amp draw).
4. Condenser dirty or airflow blocked in some way.
5. Condenser fan(s) not running or running backwards.
6. If water cooled condenser then water flow problem.
Hope this helps you get started.
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Scotsman Ice Machine, Cuber, 1930 lb....
Kenmore side by side compressor trips the thermal overloads? When the system is reset it runs and makes ice for about 16 hours then gets warm.. Repair guy charged me 85 bucks to clean the coils...don't...
Your condenser coils were probably very dirty and covered with dust, which TRAPS heat and does not allow your unit to get rid of its heat - this causes the compressor to run excessively. Did he also check door seal gaskets and over frost on the evap (defrost issues)? Did he take measures on the compressor as well ?
What a rip-off - cleaning condenser coils is something you can do yourself with a special brush - you should have spent this money on having him check other problems.
Sep 27, 2009 | Refrigerators
Ckl60-1l outside fan runs good,compressor do not run
Reasons for icing up are dirty filters,dirty indoor evap coil or low on refrigerant. Check these. Your compressor is probably overheated. Let it go for a couple of hours if you are in a hurry. Run a water hose over it. Rus
Jul 15, 2009 | Goodman CKL60AR60 Air Conditioner
Rudd 2 ton 10 S
The small copper line should not be really hot its supposed to be carrying liquid refrigerant which has already had the heat "pressed" out of it by the compressor and carried of by the air flowing over the condenser coil. This could indicate a few things; that your unit is overcharged, you have a mismatched evaporator coil and condenser, an ineffective condenser fan motor or a clogged condenser coil and as a result your compressor is shutting of due to an overload condition from the building heat and back pressure between the compressor outlet and the evaporator inlet.
First make sure your condenser is clean and that adequate air is flowing over the fins of the condenser coil. Then be sure your equipment is a matched system. A indication that your condenser fan motor is not at speed is slow starting a humming sound and excessive heat. In my experience this complaint is generally the result of a bad condenser fan motor that over heats and shuts of after a short period and the build up of heat in the liquid refrigerant line of course trips the compressor overload circuit- which by the way usually takes hours to reset. I hope you've already resolved this, but in case you haven't......
Aug 01, 2008 | Ruud Matching Split Air Conditioner
Compressor Stopping
compressor is running overloaded possible problems bad relay/overload /capacitor dirty or clogged condensers if the unit uses a condenser fan suspect a bad fan. and defective thermostats are notorious for short cycling. id check the coils first and if dirty clean up maybe that can be the major problem.
Apr 22, 2008 | Frigidaire 9 cu. ft. / 255 liter Chest...
Beverage air ucr48 A problem
yes check the condenser coils if dirty, clean it
2nd you can be having a defective evaporator /condenser fan, make sure both fans are running.
3rd you can have a relay/start capacitor/overload problem i'd suspect this if compressor hums and trips.
Touch the discharge line of compressor it should be hot, if not, compressor ain't turning on.
If your coils iced up, suspect a faulty thermostat.
but before all of this i'd check for an iced coil.
Apr 21, 2008 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
120 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
