If everything appears to work as normal but does not heat, then the magnetron will be faulty. This is the device which cooks the food, however this can be an expensive part to replace & may not be economical to fix.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE General Electric Microwave
My GE JES1656 will not work. Check the fuses and nothing blown on the panel. Tried other appliances...
(More)
My GE JES1656 will not work. Check the fuses and nothing blown on the panel. Tried other appliances in the same outlet and they work. Microwave oven is about a year old...any fixes??
I have a G E microwave model # JES2051DN. Will not heat food. It comes on and will run but nothing...
(More)
I have a G E microwave model # JES2051DN. Will not heat food. It comes on and will run but nothing gets hot. Is there some kind of reset or something. This unit is less than 1 year old and has only been used for 6 months.
i have a ge xl 800 microwave the other night it made a noise; kept turning and the lights were on-...
(More)
i have a ge xl 800 microwave the other night it made a noise; kept turning and the lights were on- just no heating of the food!!! nothing gets warm.... how do i fix it? thanks
my microwave does alot of sparking around the small pad inside the microwave on right side . model #...
(More)
my microwave does alot of sparking around the small pad inside the microwave on right side . model # jes1290ml01
GE Microwave Sensor Oven JES1656SJ02, worked fine -- 5 minutes later went to turn it on -- no clock...
(More)
GE Microwave Sensor Oven JES1656SJ02, worked fine -- 5 minutes later went to turn it on -- no clock or power at all. No symptoms of any problem prior to not working
