Question about Sony Cyber-shot DSC-W200 Digital Camera
I droped the camara and the lens is stuck out and it just comes up with try turn off and then on again??aany ideas and how much to fix???cheers sony cyber shot w200
    President:
  • 1,197 Answers
If ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards
iversh
Posted on Sep 27, 2009
Hi. my problem with my camera is that my niece play with it and she pushed the lens mechanism while the camera is on. now, the lens was stuck and doesn't comes out anymore. when i'm turning on
Force it out like it was forced in. Try to rotate the lens. Remember it has to be off. As soon as the lens is half way out, turn the camara on and the lens will go to its position. If not, while the lens is out turn it left or right until it's back to its position.
Good luck.
Aug 24, 2012 | Sony Cyber-shot DSC-W55 Digital Camera
Enciende mi camara pero no toma fotos,dice pague y encienda la camara.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
Jan 30, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
When i turn my camara it tell me.... please turn camara off and then on again.. so i do it and it tell me the same thing i dont know what to do or were to take it
It seems your camera's Battery is not holding a charge, you need to replace it with another one.
Also this issue usually comes due to the lens getting stuck and is unable to come out, so please try charging your battery and check for any dust/foreign material stuck in the lens preventing it to come out properly.
If the problem still persists, take your camera to an authorised service centre.
Good luck
Mar 16, 2010 | Panasonic Lumix DMC-FZ30 Digital Camera
I have a Sony Cybershot DSC-W30 camera. This morning, I took a picture of my daughter, and turned the camera off. Right when I was turning it off, she asked me if she could see the picture, so I quickly...
MY LENS IS ALSO STUCK OUT. I pressed on the lens by accident while it was on. Now it won't turn on and the lens is stuck out. I tried twisting it left as recommended by aplynn09 but didn't work. SOMEONE PLEASE HELP!!!
Jul 16, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
CAMERA LENS STUCK OUT
chech and make sure that your lens isnt bent to the side, because i had the same problem and as soon as i bent my lens back it turned on and worked like new
Aug 26, 2008 | Samsung S630 Digital Camera
Sony n2 camara problem
ok guys, I was getting the same "Access" black screen on my dcsn2. I would turn it on and the lens would pop in and out I would get the black screen with the "Access" on it. What worked for me was the following:
As the lens came out i grabbed and pulled while it was fully extended
The "Access" screen disappeared and my camera was back to normal.
hope this works for u guys! :-)
Sep 09, 2007 | Sony Cyber-shot DSC-N2 Digital Camera
Sony DSC W70 lens stuck!
This is what I found out on this and how I fixed it. This is all relative to my camera. What I found out was the view finder has a small detent which rides in a groove. When droped or bumped it falls out of the groove. To fix this I had to remove the lens assembly and realign the view finder guide. I was a fairly simple procedure.
Aug 12, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Lens Error
There is nothing to fix. Something is broken thats for sure, but nothing I would imagine a repairer could do. So own up and save up for a new camera
Apr 27, 2007 | HP Photosmart M425 Digital Camera
Sony Cyber-shot  DSC-W200 Digital Camera Logo
129 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
