Question about Canon Office Equipment & Supplies
Weird "maze" lines on projected image
An area of the projected image shows weird "maze like" lines, in the green to blue color range.. all lines are 90 degrees to each other, very pattern-like, not random squigles.. i really don't know how else to describe this..
the lines appear brighter depending on the actual image color in the problem area.. the lines do not change position between the wide and normal settings, so i don't think it's a signal transmission issue from the video source..
SOURCE: A 12" high by 4" wide block of colored vertical lines in middle of screen
I have the exact same problem as sal1965. Does anyone know which circuit board may have a problem?
Posted on Oct 07, 2006
SOURCE: Long time to power up video
My Sony KP-53XBR200 will not display any video (even from the tuner) except the internal display until it sees a video input on one of the video jacks on the back after a power hit.
I solved this by putting a video cable from Monitor out to Video 4 in (unused for other video). Voilla! Instant video on. This may not be your issue, but it fixed my set!
Posted on Nov 10, 2007
  • 10 Answers
SOURCE: Picture shows only about a 2-3" blue,green,or red vertical line down the middle
If your seeing vertical line across the screen you need to check the components in the vertical stage as well as the vertical IC could be bad, or the yoke could open.
Also check if any voltage reaching the vertical stage.
Good luck.
Was this help full.
Posted on Dec 29, 2007
  • 563 Answers
SOURCE: NEC Lt240 prblem
Hi 80camaro
You could check in the Service Menu if your RGB is the same percentage and at the same run rate.
The run rate is normally 45-60 and the percentage on 50.
I would however recommend that you take it to a NEC agent to get it serviced.
If this doesn't fix it , then you will be looking at a new Mainboard.
Thanks for using Fixya and good luck.
Posted on Apr 29, 2008
  • 57 Answers
SOURCE: Panasonic PT-L701e - colour fault, blacks are blue with lines
Can you connect a computer (vga) signal to this projector? I'd like to know what your "white" computer screen does on the projector....example, Excel spreadsheet....
I am leaning towards these problems, a bad video card...or worse delamination of one of your LCD panels and possible polarizer burn in the optical engine.
Best Regards,
Posted on Dec 12, 2008
The tv image is showing in three colors....Almost ghost like but in three colors. I checked my connections and tried my blue ray player and the image is still messed up....I did press the magic focus...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from
Sep 23, 2010 | Hitachi 53FDX20B 53" Rear Projection...
There is a blue wavy line from the left top to the middle of the top of the screen. The area above the line is yellowish. Below the line the images are clear until the bottom third where everything has a...
Convergence ICs have failed. The Sony type 1 convergence repair kit available from is the correct kit for your model. The kit contains the parts and the CD with instructions.
Jul 16, 2010 | Sony KP-46WT500 46" Rear Projection...
This tv have convergence problems,it dead.Red,green,blue misaligns colors,have colors shadows,3d colors pic like.All these problems are the convergence board have 2 STK convergence ICS some or all it resistors are dead.These parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Image is green color............what is wrong with the tv?
It means that the blue and/or red picture tube (bulb) is not working properly. It could be the tube(s) or the circuits that drive the tube. My money is on the circuits.
Apr 22, 2010 | Philips Magnavox 51MP392H Rear Projection...
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tripe image, blue, red and green color on image, not focus
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
Aug 28, 2009 | Televison & Video
How do i center the colors, red, blue and green?
Replace Both of your convergence ICs STKs, big black ICs.
STK392-560, also CK pico fuses around ics you may have 1or2 bad .
Jan 01, 2009 | Sony KP-61HS10 61" Rear Projection...
JVC AV-56WP74 56 in. Rear projection blurred image
Check that the 3 output plugs are in the right sockets (Red, Blue, Green) There is usually a felt pen colored mark on a white tape on the plug in wires. The Board sockets are marked Red, Green, Blue.
Jun 20, 2008 | JVC AV-56WP74 56" Rear Projection...
Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Good luck.
Was this help full.
Oct 31, 2007 | Panasonic PT-47WX53 47" Rear Projection...
29 people viewed this question
old marine
old marine
