Question about Canon ImageRUNNER 3570 Copier/Printer
MACHINE SCANS THE DOCUMENT BUT IT PROCESSES THE DATA FOR A LONG TIME BEFORE IT MAKES THE COPY.
  • 1,219 Answers
Are the documents with pictures, are you using the eg. 2-side, or collate,...
When some add. functions are enabled the machine will react slow, but if not contact your service, they need to reset the machine or upgrade the firmware
Posted on Jan 12, 2010
The copy function works very slow. How can I speed it up? officejet 5740.
The reason it is slow is because it scans first, then processes the data and sends it to the printer. The only way that may speed it up a little is to reduce the resolution of the scan. For a document you only need 72dpi, and most scanners with go up to 600dpi -1,200dpi. That takes longer than it needs, as the scanner carrier travels a lot slower, and the data has to be shifted in and out of memory in blocks to be printed, deleted, reloaded and printed. Look in scan settings.
Jan 03, 2017 | Office Equipment & Supplies
Fi-6130z ScandAll Pro won't close
You probably have Roboform as well.
Launch Roboform. It will open in Internet Explorer. Open the settings option.Under the default proflie window select 'applications integration', then uncheck 'automatically attach to Windows applications'. Reboot your system. The program should now close after scans.
Aug 26, 2012 | Fujitsu fi-6130z - Document scanner -...
The task mgr process itself is eating up memory like 90-100% then stops and returns to normal for a minute then keeps repeating over and over. It never settles down for any period of time, any solutions?...
Unless you have an inordinate amount of processes running at the same time, your taskmgr.exe should not come close to that type of usage. You've stated you have done virus scans and found nothing. It might be worth trying some of the free scans online. Either your Task Manager is corrupt or you do have some type of virus on the system. Do a search on the Microsoft site for Process Explorer. This is an excellent Task Manager replacement that will show many hidden processes that the Windows version will not see. I would then check your list of processes at a site like:
http://www.answersthatwork.com/Tasklist_pages/tasklist.htm
This is an excellent site that lists a huge number of processes and what they do. I would also do the following if you haven't already done so. Bring up your Start menu and choose Run...; then type sfc /scannow and press enter. This wil check your system files to see if they are genuine. Beyond that you might want to try and do a System Restore to a date previous to the time that this issue appeared.
Aug 14, 2009 | Computers & Internet
How do I scan a document to a e-mail
Here is a link to the users guide to your printer. After it opens go down to the basic scanning section. It will show you how to scan to a file. If it is a document be sure to select the .pdf file type. Also make a note of where it is going to save the file on your computer (most of the time it's My Document > My Scans) So now that you have scanned the file to your computer, open up your email and start a new email. Find where it says "attachement" and click on it. A box will pop open asking you to browse for your file. Just go to where you saved the file and click on the file and hit OK. Your document will be attached to the email.
Please don't forget to rate this solution.
Jun 16, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Want to scan 10 pages in a document
you could scan the pages and copy paste them into a word or Adobe PDF document
Apr 08, 2009 | HP PSC 950 All-In-One InkJet Printer
Canon D860 - I get a solid black line when I use paper feeder.
I'm pretty sure you might have solved this problem already, but this might help others.
Make sure that the platen glass is clean near the right side of the machine, where the document is scanned when going through the document scanner. Remember, when placing a document on the glass to copy it that way, you would place it on the glass on the left side of the machine. When scanning through the ADF, the scanning unit itself moves to the right side of glass and scans the document as it moves through.
We had the same issue and found out that there was a little spec of dirt on the glass. After cleaning it, the problem was solved.
Feb 03, 2009 | Canon ImageRUNNER 1670F Copier
Missing the manual - how to collate??
By using the Duplex button on your machine, you can set the machine to
print copies on both sides of paper.
1 Press Duplex.
2 Load originals face up in the ADF.
3 Press the Scroll buttons until the binding option you want appears.
Off: Prints in Normal mode.
1->2Side Short: Prints pages to be read by flipping like a note
pad.
1->2Side Long: Prints pages to be read like a book.
2->1Side: Scans both sides of the original and prints each of them
on separate two papers. (SCX-6322DN only)
2->2Side: Scans both sides of the original and prints them on both
sides of a paper, this function produce exactly the same print out
from the original. (SCX-6322DN only)
2->1Side Rotate2: Scans both sides of the original and prints one
of them on separate two papers, but the information on back side
of the original is printed 180° rotated. (SCX-6322DN only)
4 Press OK to save your selection.
If the mode is enabled, the Duplex button is backlit.
Collation
You can set the machine to sort the copy job. For
example, if you make 2 copies of a 3 page original,
one complete 3 page document will print followed by a
second complete document.
1 Press Copy.
2 Load originals face up into the ADF.
For details about loading an original, see
page 5.1.
3 Enter the number of copies using the number
keypad.
4 Press Menu until Copy Feature appears on the
bottom line of the display and press OK.
5 Press OK when Copy Collation appears.
6 Press the Scroll buttons to select Yes.
7 Press OK or Start to begin copying.
One complete document will print
http://www.websitetoolbox.com/mb/copierquestions
Jan 23, 2009 | Samsung SCX-6322DN All-In-One Laser...
Is the Minolta cs pro 5000 strickly a copy machine or is it a printer too?
Im pretty sure this is an analog machine. One way to test this for sure is to make multiple copies of one original. If the light scans the paper each time, then it is a analog machine and can't be hooked up to a computer. Digital machines generally scan the document only once then print many.
Dec 04, 2008 | Minolta EP4000/5000 CS/PRO Copier
90 people viewed this question
old marine
old marine
