Question about Dishwashers
I have a whirlpool dishwasher the clean button blinks 7 times trying to find out what code is
  • 5,911 Answers
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Sep 23, 2009
The dishwasher will not come on and the clean light is flashing.. We have hit the cancel button but the light is still blinking. We have also un plugged the dishwasher to try to reset it and the light is...
I have wrote a tip about resetting the control which i have posted below. My question though is how many times in a row does the light flash,depending on the consective times it flashes before pausing them flashes the same number of times indicates what error code it is...example if it flashes 7 times in a row that is error code 7 if it flashes 4 times that is error code 4 and so on
here is that tip of what ya need to do to reset the control board
http://www.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
please reply with how many times it flashes then pauses then flashes again and i will determine what error code is being displayed
GENE
Sep 17, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My Whirlpool GU2400XTP83 stopped during the wash cycle and there is a blinking light above the "light" cycle button. I can not reset the dishwasher, stop or start it.
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times ina row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 05, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
Hi my dishwasher won't turn on because the CLEAN Button is blinking what does this mean?
Maybe it blinks 7 times? Most likely the unit did not see the correct temp of water and thinks the heater is not working. you can usually clear this code with a "button dance". usually the 2 buttons are dealing with heated dry cycles or sanitary cycles. press one then the other repetitively 3 to 5 times, eg.(sani-cycle>heated dry>sani-cycle>heated dry...)
Apr 14, 2011 | Whirlpool Dishwashers
Whirlpool model du1100xtpq6 machine will not start clean lite flashes 7 times stops and repeats must be code 7 blinks only drain pump runs when drain/cancel button pushed
Hi, this is an indication that the water did not heat properly. Follow this link to some instructions I put together to help solve this and reset the control so you can use the machine again.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 08, 2010 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Blinking Clean light in Whirpool dishwasher
Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). Control blinks the Clean LED 7 times repeatedly and disables the Start/Resume key until cleared. Running Diagnostics clears the control and allows it to operate again. The water heating problem must be fixed or the control will stop running again. See potential causes below. Heater circuit problem: ■ Open in heater. ■ Open connection or component in heater circuit. ■ Faulty heater drive circuit on control. 1. Check operation of heater in Diagnostics cycle. 2. Unplug dishwasher or disconnect power. 3. Check resistance of heater and all components and connections in the water heating circuit or heat dry circuit.
dont forget to vote hope this helps thank you
Jun 20, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Dish washer 665.13824k601
LOCK LIGHT STAYS ON AND WILL NOT START. I HAVE TURNED THE POWER OF AT ELECTRICK PANEL AND IT STARTED ONE TIME. BUT DID NOT START ANYMORE.
HELP
Nov 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher
look behind the lower acess panel( toe kick) for the tech sheet, there is aspot cleary labeled "clean light ' blinking 7 times.
Nov 25, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Blinking Green Light
Here's what I could find on the your error code:
A blinking clean light that flashes 7 times and cannot be reset, occurs when the electronic control does not detect a water temperature increase during the main wash. This could be an indication of a failed heating element, in line thermostat, electronic control board and/or wiring. This problem can also occur if the main wash pump becomes clogged and it not spraying sufficiently. I hope this helps you.
PS A faulty door latch can also cause this error code.
Jun 23, 2008 | Dishwashers
Whirlpool quiet partner I won't run just keeps blinking
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
Apr 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gu2400 clean light is blinking 7 times
Yes this is a heater fault detection error. The unit may not be heating the water resulting in unsanitary dishes so the unit shuts down in this fault. Also the door may not have completely shut resulting in the heater not working, but everything else does (the heater common line is broken at the door switch. Clear the fault by entering diagnostics with this key dance heated dry, normal, heated dry, normal. All the leds will light, you can then press cancel and try another wash cycle. If fault occurs again, you must repair heater problem.
Dec 23, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
