How to replace the power button on a Gateway ml6732
    President:
  • 2,022 Answers
You need to show it service center because it require lot of things to do.
Posted on Sep 24, 2009
3 Suggested Answers
djfrankn
  • 100 Answers
SOURCE: how do i replace the disk drive in a gateway
Ok. First thing, remove the battery and the power cord. Make sure you have backed up all your important information. Then, get a set of phillips screw drivers and a small flat head screw driver.
Flip your laptop so the bottom of it is what you see. With the keyboard/touchpad area facing towards you, look at the cover on your left hand side with a rectangular shape (next to it, above it, is another one square-shape. Just for reference). Loose up the two screws that secures the hard drive/bay cover against the laptop and slide the cover out towards the outside of the laptop itself. If it is sitting tight, use a pen tip or the flat head screw driver (just be careful while using this one not to scratch the plastic of your pc) to push it gently. The Hard Drive comes attached to the hard drive cover, so be careful to pay attention not to damage the cover component. Remove the hard drive and secure the new one in place. Now do this steps the opposite way. Good luck, hope it helps.
P.S.: If this explanation helped you out, please leave a review.
Posted on Jan 10, 2010
domotek
  • 591 Answers
SOURCE: my gateway ml6732 laptop will not power up...no
Check if the power supply (AC ADAPTER) outputs power (you can verify with a ordinary multimeter)
if you have the correct power rating, than it could be the connector in the laptop, then it could be the power button as you mention, ther is the battery (it could be shorted) take out the battery pack and try to power it up.
If nothing of the above worked, your out of luck sorry!
Posted on Dec 30, 2010
My power button is stuck into my computer, how do I get it out? Like how do I dissemble my laptop to get it?
I tried to find a picture that would help you out a lot more, it's not 100%, but most laptops have a removable plastic bevel along the top, and when they do they always have a small slate worries screwdriver can slide into to remove it easily and pop it off little by little. The setups are also different it's hard to say what actually happened, if the plastic pieces on the power springs broke off then you're going to have to replace the entire power board underneath that that will, but even worse if it's not directly connected underneath the bevel, you can have to take the whole computer keyboard off and everything underneath access that little connection.
Oct 24, 2013 | Gateway ML6732 Notebook
Gateway laptop ml6732 has a startup repair screen and won't boot
Please re install OS .
Please specify what exactly went wrong when u used setup cd to re install
Jan 05, 2013 | Gateway ML6732 Notebook
Gateway ML6732 Laptop Fan warning
I would replace the fan right of the bat, it has a high failure rate, also remove the heatsink to check the thermal grease is not hard, if it is, remove with rubbing alcohol and paper towel along with the processor, then apply fresh compound to both and assemble.
May 19, 2012 | Gateway M Computers & Internet
My Gateway ML6732 says the operating system isn't found. What can I do to reinstall the OS?
buy a copy of Windows OS or you can download Linux that is free like ( Ubuntu, Fedora, Debian, LinuxMint). insert the disk on the computer and just follow instructions. you should have a working os i no time.
Mar 08, 2011 | Gateway ML6732 Notebook
My gateway ml6732 laptop will not power up...no lights come on when plugged into the power. Could there be a problem with the on/off switch?
Unlikely as even with the power switch off the power led would show current from the AC adaptor was reaching the laptop. Try testing the AC adaptor first by plugging a volt meter into the DC jack, with one probe set to the inside of the jack and the other to the outside, set at 20 volts and see if you get a reading.
If the power is reaching the DC jack, then check the connection at the jack port for tightness and make sure the jack is a good fit
Try removing the battrey and using it on AC power alone, sometimes a failing battery will cause problems
If this fails, it is possible that the internal fuse on the motherboard has gone
Dec 30, 2010 | Gateway ML6732 Notebook
How do i replace the disk drive in a gateway ml6732 laptop?
Jan 10, 2010 | Gateway ML6732 Notebook
Gateway ML6732 Sound Malfuction
sOUNDS LIKE YOU HAVE DONE SOME SERIOUS DAMAGE TO YOUR LAPTOP
Jan 02, 2010 | HP Pavilion dv9000z Notebook
I can't get my mouse to work properly on my ML6732. The right button and center pad isn't working properly...
if its on warrenty : take it back to shop not on warrenty: Take it back to shop If u wanne Experiment and try urself: Look under the pad.
Jun 05, 2009 | Gateway ML6732 Notebook
Gateway ML6732 Crashed ...NEED help
Seems you have OS (first guess) problem so if you have recovery disk then insert it in DVD/CD driver and reboot your laptop.
And follow the instructions appeared on sreen and when you reach installation mode choose repair one if you wanna repair OS otherwise choose fresh Installation.
once you are done you should be good to go and if you have Hardware problems then your system will show the bugs on screen during installation period.
oh! if you have any external drives (Thumb drive, Ipod) plugged in then remove before you start above procedure because due to external drives also it happens if you dont have any plugged in external drives then follow the above procedure.
Thank you and post back if any thing changes.
Jan 02, 2009 | Gateway ML6732 Notebook
Computers & Internet Logo
233 people viewed this question
David Payne
David Payne
