Question about IBM NetVista A40 PC Desktop
My computer shut down automatically when i run a video on internt
With my new window i m facing the problem of shutting down my computer after ruining a video file on internet or when i start video cal on skyp it shut down in only couple minutes. I don't know about the problem while every thing is working all right and widow works normal without shutting when i work any thing without video files, So please help me out that how i can solve this issue.
  • 3,153 Answers
Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
I would suggest getting a can of compressed air made for computers
take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
While you are in there just check that the CPU cooler itself is not loose
If it is it will have to be re-seated.
If it needs re-seating don't just take it off and put it back on as that might make things worse with your temperature problem the have to be cleaned and new thermal grease put on
I think this may be your problem before you buy a new CPU make sure you check the cooler assembly and make sure you use new thermal grease ($2-5)
DON'T remove the CPU just the fan/cooler assembly.
You must clean both the surfaces without scraping anything off. Use isopropynol alcohol and cotton bud sticks until both surfaces are clean, you can use your finger nail to scrape harder residue if you wish but nothing else.
DON'T pour the alcohol over the CPU
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are
some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business
Posted on Sep 23, 2009
  • Project NOMAD
    Project NOMAD Sep 23, 2009
    It may well be some form of virus or spyware.
    It may also be that you have too many applications running at once eg. lots of toolbars and instant message typ programs.
    It can also happen on graphic intensive applications.
    You should rule out nasty stuff first.
    MBAM !
    for a free one its pretty darned good !
    From a CLEAN computer download and put on a flash drive.
    Copy to your DESKTOP on the suspec computer.
    Run it but dont change any options just use what it offers.
    When its done let it clean anything it finds.
    Its where I always start with an infected machine.
    As for antivirus AVOID Norton or Mcafee but try the AVG FREE version MBAM should clean up without buying
    Only continued use would require purchase As for too many applications that would be up to you to decide what you REALLY need and dont. Most toolbars are a waste of both time and space and can hog computers down. Maybe a good clean up is in order ?
    It may just be a "leaking application"
    These are badly coded programs that dont release memory when they should and just keep taking more to do the same job.
    May I suggest you download
    "hijackthis"
    It is a program that can make a report on what you have running in such a way that you can post that information to certain sites and experts there will look at it.
    They will then give you reccomendations as to how you can remove programs or fix some issues that may be upsetting your computer.
    Dont post the log here but follow the nstructions and help the program offers to send it to one of the sites it will offer you.
    If you understand startup lists you may even be able to spot som things yourself that you dont want to run and disable them from hijack this.
    "hijackthis"
  • 3,866 Answers
1. video GPU overheat
2. cpu overheat
3. virus
Check all of these things rule them out 1 by 1 there is no true way for me to 100 percent point out the issue without seeing your computer personally. May I suggest a hat session with us? We can figure out and repair 1000's of issues via chat try it.. This answer is 100 percent free please do rate the best thanks.
Why does my computer automatically shut itself down on the same day each week.
There are a couple possibilities...first, when you say shut down, do you mean that it restarts, or it actually shuts completely off? Windows update will auto-run weekly and restart the system if necessary. Otherwise, I'd suspect something with your antivirus scanner settings.
Jan 10, 2015 | Computers & Internet
My laptop turns itself of after 3 - 5 minute
Check the charger of your laptop if there is any place that has problem or cut? check the voltage of your laptop whether is the same thing with the charger. If everything are fine, then reload your operating system, because I have noticed this problem with my clients. Good luck
Feb 03, 2011 | Dell Latitude D600 Notebook
My computer will shut down automatically..
your PC got a Dangerous Virus.
the Virus Shuts down or resets The PC in order to spread (in whole of the PC) more.
so download and install a new anti virus.(Like Nod32 or Norton etc)
then update it and run a full scan.
Jan 15, 2011 | Microsoft Windows XP Professional for PC
I was running the program "windon Defender" on it and walked away. When I returned the computer was off and wasn't turn back on.
The Windows Defender Application is the Antivirus Software which will be pre-installed with the Windows Operating System(Windows Vista, Windows 7).
The Computer will always Shut down after any Windows Updates or any Operating System Updates are downloaded and installed.
If you are connected to the Internet and running Windows Defender, the Computer will automatically download the Updates for the Windows Defender Application.
Once the Updates are downloaded and installed, the Computer will prompt for a shut down.
The count down will be for 10 seconds.
After 10 seconds, the Computer will install the downloaded Updates and shut down.
This might be the reason for the Computer to shut down while using the Windows Defender.
If the Computer still shuts down randomly, the issue might be due to overheating.
All the Processors in Notebooks are designed to shut down automatically, if there is any overheating issues.
The overheating issue mainly occurs due to the malfunction of the Cooling fan.
If the Computer shuts down frequently, the issue might be due to the above factors.
It would be better to get the Unit examined at the Service Center.
Jun 22, 2010 | Acer (56.04145.901) (5604145901) Power...
FS X shuts down computer after running about 2-3 minutes. I have the program installed on a new Gateway laptop running Windows 7. Acceleration expansion pact has been installed but not service pack 2. So...
FSX needs alote of memory and a good video card to run like it should how much memory do you have in the gateway and how much video memory does it have if its not enough this may couse it check this first then we go from there.
May 14, 2010 | Microsoft Flight Simulator X for Windows
IBM 2647 -41U automatic shut down
How old is your computer??? is it getting overheated?..what operating system did it have before xp? does it give you any messages before shutting down?
let me know
Apr 10, 2009 | IBM ThinkPad T20 2647 Notebook
Laptop locks up during shut down
fist of the click the start and click the run and type the recent and click.......ok and remove the all file in new windows
second method click the start and click the run and type the chkdsk and click.......ok
thard method click the start and click the run and type the temp and click.......ok remove the all file in new windows
Apr 01, 2009 | Dell Inspiron 1501 Laptop
COMPAQ CQ60-104Tu goes blank... improper shutdown
It might be a problem with the computer. I would advise going back to where you bought it and returning it to either get a new one or a different one. Glad I Helped!
Jan 28, 2009 | Compaq Presario Notebook
Installed a video card xfx on windows xp pro now computer shut of
its a normal process when you installed a new Video Card. the only problem there is, if its not compatible with the chipset of your main board. it will create an error and slow down your system/computer later on. to check it, see the manual of your main board and find what its chipset.
Dec 17, 2008 | Acer Aspire T310 PC Desktop
IBM NetVista A40 PC Desktop Logo
185 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
