Question about Sony Ericsson Walkman W902i Cell Phone
The camera not working!!
I try to restart the phone or try to remove memory card still wont work..when i press camera app the only thing comes out is white screen and back to the menu..please help me solve this problem..should i update or upgrade my W902...
  • 375 Answers
Sir, it think its a Firmware problem. Just upgrade the Firmware using the phone's internet or PC Suite.
Try it and reply me. Thank you Sir, Have a nice day.
Posted on Sep 23, 2009
Camera not working
http://tinyurl.com/nphg38c This app worked for my issues with the camera in my S4 active. It requires root though.
Jul 29, 2015 | Samsung GALAXY S4
Having trouble with memory card for Samsung Note 2
the first thing i would try? move the apps back into phone memory out of the sd card.maybe put the wifi back on phone memory,shut the phone off,remove the battery,put it back in & restart phone.it may take a minute or two for the sd card to mount.
then to "my files" (under apps on home screen ).choose external memory.pick wifi,tap the top right button. you will see options.pick "move".pick "device storage".that should put it back on the device.turn wifi on & see if it works. (P.S-always before removing sd card,pick "storage" on your menu. you will see the option to
"unmount".be sure to do this every time before removing sd card.
Apr 03, 2015 | Samsung Galaxy Note 2
Sri i hav problemof automatic restarting in my cell phon 5530 pls sen the solutionn somtime network problem is comm problem??
1. Try taking out first the memory card before restarting it and restart it once the memory card is already out. It should be then restarting fine once the memory card is removed. It is not restarting because the Memory card is not helping the phone to reboot or to restart. That's the problem. 2. If it wont start try to reformat the memory card or either have the phone checked out or fixed.
Hope that solved your 5530's problem. Take care always
Dominic :)
Feb 22, 2011 | Nokia 5530 XpressMusic Smartphone
My nokia 5300 camera is not working.As soon as i open a camera mode it says camera on standby and operation failed
Switch off the phone, remove the memory card and boot again without the memory card. Now try accessing the camera, hope it's working now. I would suggest you to scan the memory card or format it (i recommend formatting the memory card so that it'll not fail).
If the problem persists even without the memory card, reset your phone's settings to Factory Default by going to the Settings > Restore Factory (open the settings, press up key once, you'll see the "Restore Factory") using the code 12345. Your phone will automatically restart. Now try again with camera.
If both the above methods don't help out, your only option is to flash the phone or update the firmware. But I don't recommend do these yourself, a small mistake or incomplete will damage the phone or will create more problems. You can visit any service center or any mobile repairing center and get it done with a small fee.
Good luck.
Thanks for using FixYa.
Aug 10, 2010 | Nokia Cell Phones
MY LG KP501 says 'Maximum limit of application reached' help!
Click the middle button and the arrow that says Running application and press "End all"..
I hope that helped ^___^
May 23, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Nokia 5800 won't turn on
"my phone just says NOKIA and its blank white- no matter what you press, no change even though it is fully charged what to do??? pleeeese help "
I had the same problem, I took off the memory card and de sim card, i turned the phone on... and then off... and then I had put back the two cards, and i turned it on again... I worked
Feb 11, 2009 | Nokia 5800 XpressMusic Smartphone
Restart of my cell....
first you try to reformat your memory card maybe it has a virus!! then try to do this just press *#7370# it will restore your phone!!! if not working try this one press this all togethere *3 call sign and power switch! make sure that you pressing that all togethere and wait until the word formatting appears
Nov 02, 2008 | Nokia 3110 Cellular Phone
Blackberry Curve 8300 Camera Problems
After reading many posts, I removed the back and and pulled out the battery, then removed the memory card and blew air all over it, put it back together in reverse order, and works like new.
Oct 07, 2008 | AT&T Blackberry Curve 8300 Smartphone
Camera wont turn on, intermittent red power coming on
This may or may not work (it's primarily a trick for certain Canon cameras with similar symptoms). Remove the cameras battery, then remove the memory card. Insert a BRAND NEW or fully charged rechargeable batteries. DO NOT insert the memory card. Instead, just turn on the camera. If the lens retracts, turn off the camera, insert the memory card, then restart the camera.
If this doesn't work, here are some other things to try. But don't get your hopes up, as they only seem to work for little less than half the cameras with similar problems:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 08, 2008 | Fuji FinePix V10 Digital Camera
Nokia N70 memory
Move pictures, videos, applications and sound files onto the FLASH card. I believe most of them are stored on your phone/sim-card. Simply browse for each of the files and select move.
Oct 23, 2007 | Nokia N70 Cellular Phone
Sony Ericsson Walkman W902i Cell Phone Logo
183 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
