Question about EliteGroup P4M800PRO-M Motherboard
System fans come on but no start up. - EliteGroup P4M800PRO-M Motherboard
  • 3,153 Answers
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Sep 23, 2009
  • 3,051 Answers
Hello there
if the power supply fan comes on and the other fans comes on and their is not beeps please try this first unplug the computer and open the case locate the power supply cord that hooks into the motherboard and unplug now press the power button on the computer and hold there for 20 seconds and if it has a reset button press this too now plug in the power cord to the motherboard and plug in the power to the computer and restart and see if this helps ok. if not please let me know ok
best regards michael
Evaporator moter wants to start (BUMPS) ,will not run,Motor is free
System froze because the fan motor stopped working, could be that the fan motor is bad, or if it is a PSC it could be a bad capacitor.
Jan 10, 2013 | Heating & Cooling
Replaced the side fan with the factory part. Now get an f61 error. reconnecting the old fan correects the f61 error. What can be done?
return the new fan as defective and start again with another and mention your issue, either new fan bad or wrong one.
Dec 03, 2012 | Panasonic SC-HT441 Theater System
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
Why does IBM fans stop spinning after opeating system loads?
Some system fans start when powered on as a test then go idle till needed went gets hot.
If they don't come on then it could be a bad capasitor on the main board.
Aug 28, 2012 | IBM Computers & Internet
System won't start, power retries every 1-2 seconds
Make sure your smps power supply of cpu is working fine.
Make sure motherboard is not ground with cabinet cover.
Pull cmos cell from motherboard for 10 minutes then put it into it's position.
reattach the RAM memory into slot also make sure ram is fine.
Clean dust from all parts.
Reattach processor and it's fan.
Reconnect pci card or vga card if any.Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
May 03, 2010 | Intel Motherboard
"NO DISC" and no power to fan--Common Cause???
REPLACE THE LASER- THE FAN WORKS WITH VOLUME,AS YOU GO LOUDER THE FAN STARTS TO WORK
Jul 19, 2009 | Panasonic Home Theater System System
PC does not boots / does not start
Since your system reboots even if you stay in the Bios setup the problem with your system might be because of heating up of the proceesor, which might be caused if the fan CPU fan is rotating slowly or is not rotating at all. If the fan is rotating slowly change the cpu fan and try to reinstall XP
Jun 29, 2009 | Computers & Internet
Cooling fan don't work when i start up the hifi system
in fact the cooling don't turn when you power up the system but only if you increase the power at a certain amount with just one woofer connected
Phil
Dec 13, 2008 | Panasonic SC-AK75 Shelf System
DELL DIMENSIONS 2300 COOLING FAN
Your system will run fine until the processor starts overheating... why not just replace the fan?
Oct 26, 2008 | Dell Mini Fan. Dimension (W x H x D) in....
H8DAE-0 Fan issues, stopping and starting.
Sounds as if you have a motherboard fault or a processor fault, as, if the processor is faulty, everything will stop, especially if the temperatures arent being read correctly by the motherboard causing the system to shut down before any damage is done.. It's a process of illimination i'm afraid
Aug 21, 2007 | SuperMicro H8DAE Motherboard
EliteGroup P4M800PRO-M Motherboard Logo
138 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
