Question about Saniflo Sanicompact 48 - One Piece Toilet with Macerator Built Into the Bas
My sanicompact c43 motor is running constanly.And sometime it filles up the toilet without flushing out
picatudo
  • 239 Answers
SOURCE: Toilet fills up slowly
buy a universal fill valve and replace it
Posted on Jan 03, 2009
kachbibi1
  • 979 Answers
SOURCE: Saniplus motor (flushing noise) keeps repeating
I believe you have a problem with a leak. The pump is filling back up. See is the water is leaking out somewhere. Hopefully, you don't have a leak under the house. The water coming into the pump is going somewhere when it comes on.
Posted on Jan 28, 2009
  • 34 Answers
SOURCE: Replacing Sanicompact toilet seat
I have asked around they take a normal seat on most us models
Posted on Feb 05, 2009
  • 34 Answers
SOURCE: Running water in Geberit Starck Toilet
I hate to say it but you may need a pro on this one, if you want I can try to walk you threw it but let me know. bigslimaba@yahoo.com
  • 6 Answers
SOURCE: Toilet will not fill up
Some Toto fill valves have a plastic debris screen located at the inlet connection. Turn off the supply valve and remove the supply connection at the bottom of the tank. Use a mirror to inspect the screen for debris.
I agree w/ Smithbrother, the Fluidmaster fill valves are cheap and work well. The only thing they ever need is an occasional seal for $1.50 and 5 minutes to replace.
Posted on Mar 14, 2009
Sanicompact
Take off lid and check flushing mechanism if all engaging timely. Adjust if necessary. Good luck. BTW when pressing the button make sure you do it with a bit of pressure.
Jul 29, 2013 | Home
Toilet wont flush
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will may help.
Oct 22, 2012 | Saniflo Sanicompact 48 - One Piece Toilet...
I have a sanicompact 43, if the water pressure is low will this b the reason for flushing problems , please ?
Its a Cisternless ceramic toilet with built-in Macerator Pump.So the water pressure should not make much of a difference as most of the job is done by the pump
Regards.
plz. Don't forget to rate my suggestion.
Jul 13, 2011 | Elite Saniflo SaniCompact- SaniCompact One...
Sanicompact motor operates continuously but bowl doesn't clear. Have emptied bowl manually and poured Saniflo cleaner in.
This problem occurs when the flush button is damp after cleaning the whole toilet with a shower. Solution: Wait till it dries up 2) if you have installed a main switch put it on and at the same time press the flush button.
Dec 26, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
Involuntary flushing operation occurs every 10 minutes
hi,
i was having same problem with my sanicompact48,it was flushing continuously after few minutes.i opened and cleaned every thing still it was the same thing.and i noticed irreguliar flushing due to SOLONOID VALVE.just replaced and works fine.yo can order by phone # 1 800 571 8191 to "saniflow".tale them your problem and your toilet model.
good luck
garry
Sep 06, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
My Saniflo sanicompact does not flush away, when i press the flush botton it does not work, the toilet buzzes all the time. when the water gets to a level it use to pump away but has stoped doing this.
saniflo buzzing all the time means that the motor is trying to run but cannot. indicates that something is blocking the pump impeller from rotating. unit needs to be removed, cleared and tested. if fault contiues you may blow the fuse (if you are lucky) otherwise the motor will eventually burn out. get this checked soon.
Apr 12, 2010 | Saniflo Sanicompact Elite - One Piece...
My saniflow toilet is blocked and a plumber has told me i need a new motor. where can i get this and how much are they?
If you hear it making noise the motor isnt blown, but it could be clogged.
A quick an easy fix is by filling a 5 gallon bucket with hot water (or warm water) and slowly pouring it into the bowl. The warm water breaks the particles up further, and will help flush the unit out. Make sure you run the water alot after its cleared out (to flush the debris). You can do that by turning on the shower or sink (if connected). If you dont have a shower or sink just keep flushing the toilet.
Sep 03, 2009 | Saniflo Sanicompact 48 Toilet With Pump,...
Fills but wont flush
take off the lid on the tank. there should be a chain from the handle to a rubber flapper at the bottom of the tank. sometimes they fall off
Jul 25, 2009 | Elite Saniflo SaniCompact- SaniCompact One...
Check the electric power to the unit first as the compact is all controlled via a printed circuit board
Feb 03, 2009 | Saniflo 005 Toilet Tank White
Saniflo Sanicompact 48 - One Piece Toilet with Macerator Built Into the Bas Logo
173 people viewed this question
Top Saniflo Home Experts
Paul Carew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
