Question about Hoover Vacuums
Hoover 1900w keeps cutting out - Hoover Vacuums
Opened it up little senser near the moter on a wire moved away from the motor dont cut out anymore
Posted on Sep 16, 2011
  • David Ennis Sep 19, 2013
    Ah, good man, glad you got it sorted.
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
Electrolux gazelle 1900w
Clean filters and check hose for obstructions
Oct 09, 2013 | Hoover Vacuums
Hoover c1810 bagged upright - power keeps cutting out - is there a reset button?
there might be a reset button on there but its not meant for continuous use. we need to figure out the problem why the power cuts out. what condition is the cord in? cuts nicks. also check the prongs on the plug. if not that could be a bad switch but it sounds like a loose connection
Jan 02, 2010 | Hoover Commerical Conquest C1810 Bagged...
Why does my miele 700 revelution hoover keep cutting out? The bag is not full just loses power?
  1. i have a miele revolation hoover, it doesnt pick up. it has hardly no sucktion. where and how do i get the filter out to clean it??? it was given to me working. ive changed the bag so thats not the problem. and checked the hose. still no joy. need sucktion.. Thankyou jacqui
Jan 01, 2010 | Miele Revolution 600 Bagged Canister...
Hoover 1900W bagless vacuum that only blows out - does not **** in - what is wrong?
check for a blockage. start at the bottom and work your way up thru the hose all the way up to where it goes into the body of the vac. also check your belt.
Nov 02, 2009 | Vacuums
I have a large lego stuck in the middle of the hose on my hoover
Ok This same thing happend to my wifes vacuum. If its on the straight part use a small broom handle. If its down deeper you can cut the handle in short pieces as if to make a small train. Drill a small hole in the center of the blocks or broom handle pieces. I cut mine 1 1/2 inches long so they can make the turn. Next take a stick and force the clog back words.keep tapping and shacking the hose and stick till it drives the clog back. Keep your tool hanging In a good place till you or someone else needs it. I had to make 2 of them, Because she has a small light weight vacuum with a smaller hose on it. i got a dial rod that fit just right in the hose, And made a uncloger for the small vacuum also.
hope this was helpfull
Sawdust
Aug 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
Filter keeps clogging
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=719779
Generic problem for all Vacuums
Posted by ozandcaza on Jun 29, 2008
Report abuse
Dust etc collects in the filter above the dust container. The dust container remains empty. Hoover then over heats and cuts out. Collect in replaced new filters in Hoover but problem still remains.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. My question is how old is the Hoover vacuum? If it less than a year you should really see an Authorized Hoover vacuum cleaner dealer that the problem might be covered under a factory warranty. This should not be happening and it sound to me like there is a clog somewhere in the vacuum fill area that is causing it to do this to you and the vacuum. You are lucky that you have a thermal switch that does shut it off. If not and it is over the one year factory warranty then you should see a local vacuum cleaner dealer in your area or contact Hoover Cust Serv @ the website and or phone 3 listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 29, 2008 | Vacuums
Vax 1900w hoover
Take the motor out and check the fan, outside of that, you may have to replace the motor.
Jun 07, 2008 | Vacuums
Vacuums Logo
238 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
