Question about Whirlpool LER5636P Electric Dryer
Kenmore gas dryer
My dryer goes thru all the cycles the drum tumbles it just won't heat up
  • 2 more comments
  • denman Dec 15, 2007
    my dryer is a kenmore gas dryer it will not heat up
  • Anonymous Mar 04, 2008
    my dryer was working just fine at old home,we moved to new location an hooked up 10 year old gas dryer,turned it on an it run an tumbled but no heat.i then removed front bottem panel,turned dryer on an could not see any flame, so on the igniter tube i could see an opening on the bottom of tube so i got a match an lit it put it under opening turned dryer on an i got a flame so i shut dryer back off waited a couple of minutes turned it back on an it lit an worked fine but after leaveing it off for a couple days it failed to lite automaticly i havent tryed again to manualy lite it. kenmore gas dryer.
  • vickiedarryl Mar 12, 2008
    I have a Kenmore gas dryer, 90 plus series. Can't read model # due to fading. The igniter glows red and lites the gas, it stays lit for about 5 seconds and goes out. The cycle repeats about every 40-45 seconds. Won't dry clothes. Can't locate a thermalcoupling, may be it's a different design than the traditional couplings for furnaces or water heaters or maybe it's something else. Could you please help me. THANK YOU!
  • juantaine Feb 05, 2009
    My Kenmore dryer 80 series will tumble but will not heat, there is no orange glow, or flame. Yes it has been moved several times, needless to say yes I have wet clothes inside.
I tried just that plus stuck the wire together for and turned on the dryer and and heat so i replaced the fuse
Posted on Sep 24, 2008
  • 3 Answers
It could be the ignitor, you have to open the dryer, take the belt off and start it, if you dont see a red glowing light could be the igniter, you have to disconect it and check for voltage, if you have voltage, replace the igniter
Posted on Dec 16, 2007
  • 89 Answers
Hit it with a big BIG HAMMER!!! NO NO, I'm just kidding! It can be several things, airflow, coils, or thermal fuse. Most common problem is the fuse so thats what I'll cover... UNPLUG DRYER, take back panel off (use 1/4 nut driver) look for the thin white thing with two of the same color wires going to it.(located lower left).... take wires off, then take the fuse off and look at the back of it. is it slightly melted and black? Replace and wala!!!!! GOODLUCK!!!
Posted on Dec 15, 2007
  • Brian Gillespie
    Brian Gillespie Dec 19, 2007
    prob. the thermal fuse.... If not, then its the coils
  • 30 Answers
5 most likely culprits:
From most likely to least likely:
1. Thermal Fuse
2. Thermal Cut-Off
3. Thermostat
4. Heating Element*
5. Ignitor (GAS DRYERS ONLY)
*Cannot be tested with an ohm meter. You must inspect to make sure there is no damage along the coils of the element. All other parts CAN be tested with an ohm meter.
Posted on Mar 08, 2008
The dryer will not heat up
Instructions
    • 1 Check the cycle selector control to make sure a heating cycle has been selected. The selector should be in an "Off" position when not in use, but it should be turned to a drying cycle when in use. On some models, make sure you are not accidentally running the dryer on the "Air" cycle, which does not use heat.
    • 2 Check the gas supply valve to make sure it is open if your dryer is a gas dryer. If it is not open, just lift the valve open.
    • 3 Look at your house's main breaker box to determine whether a circuit breaker is tripped. The electric dryer runs on 220-240 volts and has a double breaker. If the breaker for the heating element is tripped, the drum may tumble the clothes without heat. Turn the dryer's breakers to off, then back on; test whether the dryer will produce heat.
    • 4 Consult a technician if troubleshooting does not resolve the problem.
Jan 15, 2013 | Kenmore Dryers
My dryer is tumbling & blowing & all the cycles seem to work but it won't heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 04, 2011 | Frigidaire AEQ8000FG Dryer
Drum tumbles fine, solenoid glows...no heat
heatman101\]
Aug 08, 2011 | Kenmore 62802 Electric Dryer
Kenmore Gas Dryer 11072212101 won't heat. we
heatman101.,/
Jun 30, 2011 | Kenmore 73102 Gas Dryer
I have had a stackable hi efficent 7.3 cap. kenmore dryer for 2 months. Suddenly it doesn't heat. No sign of vent problems or electrical but on all cycles both the dry & cooling light up at the top...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 22, 2010 | Kenmore Dryers
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
Dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Jul 28, 2009 | Kenmore 73952 Gas Dryer
Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Jul 14, 2009 | Whirlpool Dryers
Heating Issue - Gas Valve Coils?
You should be able to order the parts thru Appliance Parts Pros which is advertised on this site. Make sure all gas and electricity is cut off if you do it yourself. Hope this helps!
May 19, 2009 | Kenmore Dryers
Dryer heats but does not tumble.
Yes, it is possible that the drum belt is broken.
Please rate this a FixYa
Jan 31, 2009 | Kenmore 74642 Gas Dryer
Whirlpool LER5636P Electric Dryer Logo
391 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
