Question about Fender Passport Deluxe 500watt Sound System with Deluxe Speaker Array
My Fender Passport stays in protect mode.
I was playing a show and it just stopped working when I looked at the tower I saw that it had switched to protect mode. I only had one guitar and one mike hooked up to it and it was plugged into a surge protector. The volt setting is on 115. I live in the U.S. Any ideas?
  • Fender Master
  • 5,603 Answers
I have one that has done the same. It is the next smaller size. The power supply fried a toroidal inductor in mine. Frankly, these things are a major pain to work on. You have to usually remove the front panel before you can remove the back power supply and power amp section.
If you have warranty coverage USE IT !!!
The protect feature in mine monitors the power supply load and shuts down the supply if it senses overload. They are hard to work on as you have to bypass the protect to troubleshoot and get to the root cause.
Use the old light bulb in series trick to limit the current.
Posted on Sep 24, 2009
I think I may have blown the power supply on my Fender Passport 500 (Part No. 069-1001) when I inadvertently switched the power selector from 240v to 110v. I still had the power cord plugged in and the...
BAD NEG. 15V REGULATOR AND RELATED CAPS IN POWER SUPPLY.CAUSES UNIT TO GO INTO PROTECT. main supply caps and power transformer is gone. possible you'll have to trash. good success, meder's tv service
Sep 15, 2012 | Fender Passport Deluxe 500watt Sound...
Could a bad cable connection make a fuse blow in my fender passport 250, or cuase any problemmwith ouput from my speakers...?
A shorted speaker cable could cause this... however, what you do is to replace the fuse BUT wire a 150 Watt lamp in series with the power input... This acts as a resetable fuse for testing. If the lamp stays lit, you still have a failure.
Aug 12, 2011 | Fender Pd250 Passport Deluxe 250watt...
My passport 250 goes into protect mode on occasion. The other night at a gig it would clip into protect as soon as I sent a signal from the mic or guitar. It works fine at home. Is the unit sensitive to...
These seem to be tempermental. I would look for radio frequency interference from nearby transmitter leaking into your guitar cable or mic cable that puts this on the ragged edge of feedback. DO NOT boost highs with the EQ... You can get supersonic feedback that you can't hear, but puts the amp into limiting. Any audio input can start the feedback. These amps are VERY hard to work on due to the packaging. A lot of people have smoked their units and then require repairing.
May 24, 2011 | Fender Pd250 Passport Deluxe 250watt...
Protection light came on then went of now i get nothing when i flip the switch to on.
Likely an overload failure caused the protect light to come on, and then the fuse blew so all power is off... Do NOT replace the fuse as you will LIKELY do additional damage to components. Take unit in for repair immediately.
Note: These units are really hard to work on due to the way they are packaged.
Nov 23, 2010 | Fender Passport Deluxe 500watt Sound...
We have a Fender P-250 PA system. We get the protect light on when we turn on the system rather than the green power light. We can not get it to operate. Please advise... Gary
Likely there is either a failure in one of the power amps or the power supply. The protect means excess current is being sensed.
You need to take in for repair... these are really hard to work on due to the packaging.
Sep 23, 2010 | Fender Pd250 Passport Deluxe 250watt...
Amp goes into protect mode as soon as switch is turned on. Pasport 250
There is a problem with the internal amp itself. These are extremely difficult to access. Contact Fender for a local authorized service center.
Dan
Mar 11, 2010 | Fender Passport Deluxe 500watt Sound...
Power light flashing but getting nothing through the tower
If the fuse went, there probably is a failure. To avoid further damage, if you replace the fuse, put a 150 Watt lamp in series with the hot power wire. Make an adapter to do this safely.
The lamp will light instead of the fuse blowing and hitting the amp with a high current surge that could do more damage. If the lamp goes out, it is probably safe to operate.
I would recommend carrying a spare amp with you... These Passport systems are HARD to work on due to the way they are assembled.
Nov 14, 2009 | Fender Passport Deluxe 500watt Sound...
MY Fender Passport P250 went into protect mode. I changed the FUSE at the power supply with a new fuse. Still it is in Protect mode. How to fix this
This needs to go to the repair shop. The protect mode is turned on when either the power supply has a problem or one or both power amplifiers have a problem. These are often blown components.
These units are HARD to work on. To open you have to first remove then front panel before you can remove the back panel that has the power supply and power amps/heat sinks.
Compare repairs of these units to working under an automobile dashboard!
Hint: On startup, use a series 150 wat lamp to limit current while repairing. SInce these use a switching supply operating off the input line, use an isolation transformer for personal safety.
Oct 04, 2009 | Fender Passport Deluxe 500watt Sound...
Fender passport goes in to protect
I had a problem like this that was caused by a short between the two windings of the toroid in the power supply.
The solder blob is probably supposed to be there as there are numerous common ground points.
This unit is miserable to work on....
Sep 08, 2009 | Fender Passport Deluxe 500watt Sound...
No sound from speakers
Page 8 of the owners manual explains this and suggests that if their procedure fails to take it into an authorized Fender dealer for service. The manual is dowloadable at Fender.com/support.
Dec 15, 2008 | Fender Passport Deluxe 500watt Sound...
Fender Passport Deluxe 500watt Sound System with Deluxe Speaker Array Logo
473 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Are you a Fender Music Expert? Answer questions, earn points and help others
