Question about Acer Computers & Internet
I cannot switch on my laptop(ACER aspire one). Now little green light is tur on, but still monitor is black and I hear little sound inside like the cooler working, but it is still death. I am in Toronto like visitor, and don`t now what to do
Black screen on acer aspire 9300
Hello, have you tried reseating the memory, taking out memory and installing another? It could be a faulty memory module and if it isnt that sounds like the graphics processor on the motherboard is faulty. That requires advanced soldering skills. Hope this helps.
Chat Live Remote Support
Facebook
Feb 22, 2013 | Acer Aspire Computers & Internet
Acer aspire 5920G- wont switch on. I can't hear
Hi Lenny,
not god news Im afraid, it sounds as though either your screen or your graphics chip are faulty. Help is at hand though, you could try connecting to an external monitor, but as your laptop is switching off, it is unlikely that this will work any better. You can remove the hard drive any install it into another machine, this should be straight forward, although if the machine in question does not have the corect connections then you will need a caddy. these are pretty cheap and plug into usb allowing access to the data on the drive. Hope this helps.
Feb 18, 2013 | Computers & Internet
Acer Notebook want boot up
Hook a spare monitor to the video output usually on the back, if okay! the inverter board just below the screen is most likely the problem, or the backlight behind the display. But if both show the same issue it is the video graphics card normally built into the motherboard.
Apr 26, 2012 | Acer Aspire One PC Notebook
I have an Acer Aspire One MiniBook. I once had it hooked up to another VGA monitor. Now when I log in it shows the ACER logo and the XP screen then turns black. i can hear the windows start up sound and...
try pressing the fn key and F5 or look for 2 monitors on one of the F keys its F5 on my acer 5520 that switches display modes also try going into the bios i think its F2 as soon as you turn on the laptop press F2 or look on the screen for the key to enter setup or bios and restore everything to default save settings restart
Nov 06, 2009 | Acer Aspire One AOA150-1635 Notebook
Acer aspire one power button comes on but screen doesn't come on.
1/ Take a close look at the display in bright light; can you see anything there? (If so then the CCFL (or its power supply) needs replacing on the display
2/ hook up an external monitor and see if that works (or at least if the light stays green on the monitor)
3/ Any boot beep? any "Windows sound"?
4/ try removing the battery and (using only external power) see if it starts.
4/ remove the battery AND the external supply, hold the power switch in at least 30 seconds. Hoojk it up again, try it.
JOAT
Oct 16, 2009 | Acer Aspire One PC Notebook
My computer screen is black
Turn your computer off.
Make sure both cords from monitor are plugged in.
Make sure you have pressed any required "on" button on front or side.
Try your monitor on a friend's computer.
Tell us whether or not it worked there and what kind of monitor it is.
Sep 25, 2009 | Acer Aspire One PC Notebook
Acer aspire 7720 start up problems
You need to try to isolate the problem. Try connecting an external monitor to your laptop. Press function screen keys. If you have a picture on your external monitor then you have a video problem - most likely an inverter, although you may need a new screen, unlikely but possible.
If you have no picture then you have a system problem. Disconnect the battery and AC adapter. Remove the memory and reseat. Repower your laptop and see what happens.
Aug 02, 2009 | Acer Aspire 7720 Notebook
Acer Aspire 5570 black screen.
This problem occurs in most Acer laptops. Its actually a bug in the mother board. Try reinstalling the clock battery or give it to your nearest service center.
Jun 26, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 5050 can't turn it on
If you dont see any green lights and you dont hear any boot up sounds ( hd, fans, etc) try to take out battery and just plug in the AC adapter to a known good power outlet. Make sure your power plug is good too. If you hear boot-up sounds, see green lights but no display then toggle on the "fn" key and or try on an external monitor.
Dec 13, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire 3100 Laptop Monitor will not turn on
1. Mainboard failed
2. Vga adapter failed
I wouldnt be suprised if the vga failed, my acer broke down on me 2 times, on the 3rd time it was too much and I sold the laptop.
Mar 23, 2008 | Acer Aspire 3100-1405 Notebook
Computers & Internet Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
